Like Tree5Likes
Old 07-30-2015, 11:15 AM   #5971
Originally Posted by Wascheck View Post
From Yokomo website.
Cheers for that, makes life abit easier for the front of the car
tiny tom is offline   Reply With Quote
Old 07-30-2015, 11:38 AM   #5972
RC MARKET's Avatar
Originally Posted by RedBullFiXX View Post
New front DCJs from Yokomo
Yes onsale now !!
RC MARKET is offline   Reply With Quote
Old 07-30-2015, 02:51 PM   #5973
Just a heads up on the new DCJ's, the axle is shorter than standard so the common flanged lock nuts are annoyingly too deep for the axle threads to make full contact with the material in the nut. So I'd recommend using unflanged nuts and reversing them so the material goes on first.
nwagner is offline   Reply With Quote
Old 07-30-2015, 03:00 PM   #5974
Korey Harbke's Avatar
I feel like a serrated face, flanged nut would be the best option in this case. Then you maintain wheel hub support, and still have a locking feature. The serrated nuts do an excellent job of securing wheels, and they are light
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-30-2015, 03:06 PM   #5975
-Korey
I did try the serrated nuts after my non-serrated came off, the tires still ended up spinning off. It's possible the nuts were too worn. I ended up preferring the reversed unflanged because they are flush with the end of the axle instead of the flanged ones hanging past, that's just my OCD though
The action of the new DCJ's are super smooth though so the pro's outweigh the con for me.
Old 07-30-2015, 06:53 PM   #5976
Yokomo sells low profile serrated nuts for the bd7 so I'm assuming those would work perfect. I use them on radtec/roche ones cut down pretty far and never lose wheels
2uzferunner03 is offline   Reply With Quote
Old 07-30-2015, 09:16 PM   #5977
TChan's Avatar
Send a message via Skype™ to TChan
Originally Posted by CristianTabush View Post
The rear shaft should be 44mm. You are using front shafts if they are 45.5mm.
hmmm I thought so! its a bit odd though because in the kit I only got the front DCJ's (40.6) and the "front shafts" which are 45.5. Did the kit leave out the 44mm rear shaft??
TCX~TCXX~BD7~Montonica P81~Tamiya F104~SC10 RS~HPI F10~Atomic VM2~LRP
TChan is offline   Reply With Quote
Old 07-31-2015, 02:40 AM   #5978
Nice! Thanks for the heads up, wish they would've included 2 with the DCJ's.
Old 08-01-2015, 04:39 AM   #5979
Stuff Of Legend's Avatar
Questions??
Hi all
Short arm conversion on the front of the car only does what?
More traction or just more steering response?
Short arm conversion on the rear of the car only does what?
I understand camber rise with the rear upper arm in the rear of the car, but with the lower front and rear i am lost on how they would affect the car separately.
Last edited by Stuff Of Legend; 08-01-2015 at 04:41 AM. Reason: lost on how they would affect the car separately.
Stuff Of Legend is offline   Reply With Quote
Old 08-01-2015, 11:44 PM   #5980
Trader Rating: 23 (100%+)
Hi everybody. Been running the 2015 bd7 for a few races now and very happy with the pace. But just having a few niggles and wondering if anybody has some suggestions:
- My shocks seem to be leaking through the bottom. I am using double blue o-rings with thin collar. Anybody got a suggestion? I seem to remember reading something about using neoprene o-rings or something like that, but I can't seem to find the post
- Also the rear diff has about 0.5mm of side to side play. I assume this can be shimmed out but does anybody know which shims to use?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 08-01-2015, 11:47 PM   #5981
mikeygar's Avatar
Trader Rating: 14 (100%+)
Correct my theory if I'm wrong, but as far as I understand:
-shorter arms = faster suspension response, more roll and traction at front end = since in front, = more steering, possible oversteer in the tightest corners if rear isn't planted enough
--shorter arms = faster suspension response, more roll and traction at rear end = since in rear, = less steering overall in all situations unless balanced with softer front suspension
- sorry i don't understand your question here
mikeygar is offline   Reply With Quote
Old 08-02-2015, 05:38 AM   #5982
Thumbs up
Thank you
The last one was not a question, it was a statement saying i understand camber rise/camber change with the upper arm/link.
Which is what i was guessing/reasoning was happening with the lower shorter arm conversion.
Old 08-02-2015, 08:37 AM   #5983
Trader Rating: 15 (100%+)
Originally Posted by Stuff Of Legend View Post
Thank you
This is incorrect - the shorter arms should free up the car. I wouldn't recommend only using short arms on one end of the car - it will make the car feel broken.
Think about the length of the 'lever' that is exerting force on the tire with a longer lower arm vs. a shorter lower arm. Same shock position, same spring, but with a shorter lever (inboard mounting location is moved outwards.)
If you really want to feel a huge difference, try going short shocks and short arms...
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 08-02-2015, 06:51 PM   #5984
EDWARD2003's Avatar
Anyone still running the original BD7?
The reason I'm asking is I'm looking for a relatively recent carpet setup. I don't get the chance to run touring car often and want to get up to speed with this car.
How often do you replace the shock o-rings (blue) do they swell?
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-02-2015, 08:40 PM   #5985
Default Yokomo bd7 2015 chassis weight install
anyone got any pics or videos on how this is installed on the bd7 2015.. or if it even fits
Yokomo BD7 2015 Center Balance Weight (20G) #B7-BW20 is the part number
BruceCampbell is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
