Like Tree5Likes
Old 07-13-2015, 09:01 AM   #5941
CristianTabush's Avatar
No, the standard ones. This is why there is a lot of camber.
On the low bite carpet set ups, I am using our teflon coated ball ends which are 1.5mm shorter and usually have a little bit less slop than the Yokomo parts while still staying free.
https://reflexracing.3dcartstores.co...ds_p_2480.html
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-14-2015, 08:33 AM   #5942
Default gear ratios for bd7
Hi,
I have 2 bd7 ( stock and super stock)
I know asking for the ideal gear ratios or good spur/pinion gears combo depends on a lot of variables.
What im asking for are a good base to start from.
basically i want suggestions for a tight small track and a medium to big track
my stock is 21.5 speed passion 3.0 running on blinky mode while superstock is 13.5 reedy sonic on dualsky esc running with boost.
If anyone can suggest few options or at least point me towards the right direction
Will smith is offline   Reply With Quote
Old 07-14-2015, 11:46 AM   #5943
RC MARKET's Avatar
ARENA New BD7 Hardened Steel Double Cardan Joint Set
YOKOMO Touring Car BD-7-ar-bd-010fwc.jpg   YOKOMO Touring Car BD-7-ar-bd-010fwc-3.jpg
RC MARKET is offline   Reply With Quote
Old 07-15-2015, 05:45 PM   #5944
RocheRCUSA's Avatar
Radtec Yokomo BD7 parts are now available at RocheRC USA. Nearly every available option in stock now. http://shop.rochercusa.com/index.php...ory&path=85_92
2016 ROAR On-Road National Champion 1/12 Modified
North American Distributor for Roche RC and Radtec
http://shop.rochercusa.com / http://www.rochercusa.com
Rapide P12 1/12, Rapide P10 200mm WGT and Rapide F1-16 F1 kits in stock!
RocheRCUSA is offline   Reply With Quote
Old 07-15-2015, 06:29 PM   #5945
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Nice
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-16-2015, 06:40 AM   #5946
I'm trying to help a buddy out for this Friday race night. For the summer season we are just running USGT 21.5. The issue is he has a 2013 BD7 and we cant get the gearing to work. Wondered if there is a different motor mount set up? We went to smaller spur gear to allow for a bigger pinion. But the support just in front of the motor mount is in the way. Suggestions please. or does he have to buy a 2015?
XCRAZYBENX is offline   Reply With Quote
Old 07-16-2015, 07:38 AM   #5947
Korey Harbke's Avatar
Awesome! The double joints and spool outdrives are excellent.
Korey Harbke is offline   Reply With Quote
Old 07-16-2015, 12:09 PM   #5948
mikeygar's Avatar
Trader Rating: 14 (100%+)
You can try to grind away a bit off of the mount support with a dremel. What gearing are you trying to hit and with what spur/pinion combo?
For 21.5 gearing, maybe a 48 pitch combo would be cheaper to do than changing kits. :-)
mikeygar is offline   Reply With Quote
Old 07-16-2015, 12:38 PM   #5949
spur 95T-54T pinion
OR
spur 94T-53T pinion
I believe we are trying to get 3.0 -3.1 would be nice.
The issue isnt the motor mount we massaged it a bit i believe. But the support that is in front of the motor mount is in the way of a big pinion.
Old 07-16-2015, 12:40 PM   #5950
bigbank66's Avatar
U r going to have to change the motor mount...I don't know Where u r on gearing..but if u want 4.0-3.5 use a 92-88 spur an u should be fine!!!
bigbank66 is offline   Reply With Quote
Old 07-16-2015, 12:58 PM   #5951
it is for 21.5 class 4.0 will be totally wayy to slow definitely need under 3.5. soo if u have recommendation. is there a upgraded motor mount for the old car?
Old 07-16-2015, 01:28 PM   #5952
buddy is going for 3.0-3.5 range. realy he needs to get closer to 3.0 for our track. but th elower he can get in this car
Old 07-16-2015, 11:27 PM   #5953
skyball's Avatar
spur 95T-54T pinion
OR
spur 94T-53T pinion
If you buy a 82 or 83 spur you can keep your 53/54 pinions and should be fine, see http://www.petitrc.com/reglages/yoko..._GearChart.pdf
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 07-17-2015, 02:11 AM   #5954
DirkW's Avatar
Christian
That's for the 2014 version though - he said he has the 2013 version. And IIRC, there were changes made exactly for allowing different gearings for stock classes between those 2 versions.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Yokomo YR-10F | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17| Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 07-18-2015, 04:04 AM   #5955
evochick's Avatar
I just checked with an old 2013 motor mount I had floating around,
best I could get with what I had was 88T spur and 55T pinion, it just fit.
This will get him down to 3.2
This was without any grinding of the motor mount to get some more pinion clearance, so with a little massaging there is probably a few more teeth you could fit.
A 14/15 motor mount with greater clearance will not install on a 13 chassis.
Beth.
UnRetired
evochick is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
