Like Tree5Likes
Old 05-30-2015, 10:37 AM   #5806
Jochim_18's Avatar
Originally Posted by carpetburner View Post
I noticed rcmart has the bd7 ver.rs2 for $245 vs amains $349. I wonder if yokomo has made running changes to this kit making the amain one with more upgrades to justify the $100 price difference?
It's usually cheaper if you buy the kit overseas but shipping is redicoulous.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-30-2015, 01:22 PM   #5807
antivert's Avatar
Can anyone tell me the total length of the Yokomo SLF short shock? From end to end. Thanks in advanced.
antivert is offline   Reply With Quote
Old 05-30-2015, 01:48 PM   #5808
b20btec's Avatar
Between center of balls - approx 2.0"
End to end - 2.3"
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 05-30-2015, 01:51 PM   #5809
antivert's Avatar
End to end - 2.3"
Thank you...
Old 05-31-2015, 07:35 AM   #5810
Trader Rating: 23 (100%+)
Hi guys... So I built my new bd7'15 2 weeks ago n ran 13.5 blinky with no issues.
However i put a 4.5t boosted on n down the main straight the rear driveshaft pin keeps getting thrown off the car, and then the dogbone goes flying and I end up with a 3-wheel drive car. I've tried thread locking the set screw, even tried thread locking the 2 ends of the driveshaft pin to the axle - no luck. Does anybody else have this problem n how can I fix it?
Zhangesh is offline   Reply With Quote
Old 05-31-2015, 03:38 PM   #5811
b20btec's Avatar
You can try two things, lightly dremel the pin so the set screw can have more contact or try using heat shrink over the axle area. I've used Heat shrink in the front but never in the back so you're going have to experiment. I have experience a pin backing out before so I do dremel a small flat.
Soap
Old 05-31-2015, 04:36 PM   #5812
Thanks. How can you heat shrink it? Won't that restrict the axle freedom? Are you able to take a pic?
Old 05-31-2015, 05:32 PM   #5813
b20btec's Avatar
It doesn't restrict it. There's a write up on it at RSD website. I can take a picture of a front axle that I had heat shrinked. Don't overdue it, you put a strip just enough to cover the pin.
Soap
Old 05-31-2015, 06:17 PM   #5814
Found the RSD guide, thanks i'll give it a go
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Old 06-01-2015, 05:27 AM   #5815
b20btec's Avatar
Just a FYI, I wouldn't use heat shrink all the way across like the way it's shown, just a small strip 2-3mm enough to cover the pins.
Soap
Old 06-01-2015, 09:37 PM   #5816
bigbank66's Avatar
Default car wont turn....help??
I have a 14 black yokomo bd7...im running usgt wit hpi silver springs all around....the car has great rear traction but pushes like a dog going into a corner..i have 30wt associated in the shocks wit 3.0 toe in the rear...can some one give me a setup that will give me more steering...thanks
bigbank66 is offline   Reply With Quote
Old 06-01-2015, 09:52 PM   #5817
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
http://www.petitrc.com/reglages/yoko...USA2014052325/
If you need more use 1.5mm for the center link and/or lower front shock to #2 hole.
Racing4Evo is offline   Reply With Quote
Old 06-01-2015, 10:37 PM   #5818
bigbank66's Avatar
Will this give me good corner speed also??
Old 06-01-2015, 11:48 PM   #5819
Racing4Evo's Avatar
Post your setup and track condition and I'm sure the guys in here can help you get close to what you want.
The setup I linkedis just a good all around setup that works well from low bite to medium from my experience.
Old 06-02-2015, 05:29 AM   #5820
Bar
Oil is very thin, I run 450cst, usually use 2.5 rear toe as well
Luke Burr
Bar is online now   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
