Like Tree6Likes
Old 05-14-2015, 05:06 AM   #5746
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
No STD tires, but I do think most run solaris.. thanks for the parts info
Ultraspeed84 is offline   Reply With Quote
Old 05-14-2015, 06:45 AM   #5747
RC MARKET's Avatar
Originally Posted by Ultraspeed84 View Post
Does the BD7 have the short arms? YOKBD-008RS and YOKBD-008FS? also anyone running gear diff front and rear on pavement? should I order 1 just in case?
Also what belts just get the Low friction Yokomo?
and is everyone just running the HPI silvers on the car? bout to place a order
Also what tires should I go with? Sorex? solaris? sweep? what last long and hold there speed the best?
Yes this 2 parts no. is short arms
Sorex , 2nd choice can RUSH tire
RC MARKET is offline   Reply With Quote
Old 05-14-2015, 07:20 AM   #5748
rc_square24's Avatar
RUSH = Rush by Much More?
rc_square24 is offline   Reply With Quote
Old 05-14-2015, 07:30 AM   #5749
In Australia we run MM rush mostly, as it gives the best balance between grip and wear. Sorex is the best over 1 run, Ride's have pretty good grip but the quality isn't always great and the rims break pretty easy
nitro_cortex is offline   Reply With Quote
Old 05-15-2015, 12:10 AM   #5750
RC MARKET's Avatar
RUSH had OEM to MM
Old 05-15-2015, 04:47 AM   #5751
Bar
Originally Posted by evochick View Post
If anyone wants a guaranteed no leak super smooth 15 diff. Then install Kyosho p5 O rings and remove the small outside black O rings.
Isn't the whole point of the small o-rings on the outdrives to stop it leaking out the side, surely without them it will still leak out the side?
Luke Burr
Bar is offline   Reply With Quote
Old 05-15-2015, 05:58 AM   #5752
Trader Rating: 23 (100%+)
She means replace the kit o-rings with the kyosho P5 ones
Zhangesh is offline   Reply With Quote
Old 05-15-2015, 07:55 AM   #5753
Bar
She mentioned the little ones that go on the outdrives as well
Luke Burr
Old 05-15-2015, 02:42 PM   #5754
evochick's Avatar
Sorry let me explain some more. The kyosho o rings swell a little and this causes the outdrives to bind up. By removing the outer o ring it makes the clearances just right with the slightly swelled Kyosho inner o ring.
The other option would be to install slightly thinner metal inner washers. But all the 15 diffs i have built for me and friends have been great and leak free.
I should also point out that there is nothing wrong with just using the kit seals, but i can tune the diff more consistent with the kyosho o rings and requires less rebuilds.
As with anything you read on these forums. You can either try it or not and see if it works for you. I am just sharing what i have found works for me
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 05-15-2015, 03:13 PM   #5755
Bar
Always interesting to here peoples thoughts , I have been running the 15 diff as standard, just takes a few meets to bed in, big improvement over the 14 diff which leaks out the outdrives. Had no leaking at all with the 15 diff. It's never going to be as smooth as an Xray one but I actually think it is a better diff overall
Luke Burr
Old 05-15-2015, 03:38 PM   #5756
evochick's Avatar
agreed, I could get my 14 diffs not to leak for a few meetings but would eventually wear and leak, these are a 1000 times better which ever way you build them.
Unretired
Old 05-15-2015, 03:45 PM   #5757
Bar
Definitely . I have been running heavier rear diff oil of late compared to the 14 car, even when using the old diff, I have noticed the likes of Ronald and Yannic have been doing this also
Luke Burr
Old 05-20-2015, 12:30 PM   #5758
capellone24's Avatar
hi to all,
i need to replace my 2014 graphite chassis, does anyone know if 2015 one is compatible on 2014 car?
visit my yokomo blog:
http://yokomo-fan.blogspot.com/
capellone24 is offline   Reply With Quote
Old 05-20-2015, 12:41 PM   #5759
Originally Posted by capellone24 View Post
hi to all,
I asked pretty much the same question a few pages ago and never got an answer. Hopefully someone can chime in to help. The bd7 forum is strange. You can ask a setup question or chassis question and get no answers but an oring question will get pages of response. Go figure.
2uzferunner03 is offline   Reply With Quote
Old 05-20-2015, 12:42 PM   #5760
Does anybody here know the difference between the sss and slf shocks?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
