Like Tree6Likes
Old 04-02-2015, 07:31 AM   #5671
What are you guys using as far as rear diff oil goes.
I'll be racing a very small carpet track a medium sized parking lot track and a large permanent track (full throttle). Racing 17.5
2uzferunner03 is offline   Reply With Quote
Old 04-02-2015, 07:35 AM   #5672
Bar
Originally Posted by Lonestar View Post
stop crashing
more seriously - replace balljoints, threads are likely stripped by now and they are moving as soon as you hit anything. I was also told the m3 thread depth of the stock turnbuckles is a bit on the shallow side, as opposed to (for instance) the optional yokomo titanium ones.
HAving said that - the yokomo isn't known for being as consistent under constraint as, say, an xray for instance (which never tweaks, never moves, even under crash...). This is the one thing I'm missing from my T4 '14 (and the non-leaky shocks too!)
Paul
Excluding the latest Xray 2015 the Xray tweaks quite a bit, only ever tweaked my old BD7 2014 after some major crashes at a large outdoor track that shifted the battery as well. In my opinion the only thing Xray does better on quality over other cars including the Yokomo is their plastics are better quality
Luke Burr
Bar is offline   Reply With Quote
Old 04-02-2015, 08:32 AM   #5673
Lonestar's Avatar
Did you have both? I had both BD7 '15 and T4 '14 for a couple of months until a few days ago (sold the T4)... believe me, I have played with the 4 scales extensively. The BD7 '15 has way more tweak hysteresis than the T4 '14. like WAY more. About double, actually. The T4 will shift about 30g left to right, the yok about 50 to 60g. It's shocking. Talking both CWF lower decks here (with an Al chassis, the hysteresis is about zero as there is so much torsional "spring"). Imagine if the T4 had a single-piece motor mount...
Agree with you though - xray's plastics are second to none. Yokomo's are okay.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 04-02-2015, 09:52 AM   #5674
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by AllyITA View Post
just a little question from a novice (of touring)
i bought a used bd7 2014, tried a couple of times at the track and i noticed that almost every time i hit something or crash, the steering/suspension links of the front wheel change lenght, trowing completely off trim, camber etc..
is this to be expected in this kind of vehicle or are the plastics worn and in need of replacement? (they seem fine to me).
i know the right answer is "just don't crash", i'm getting there
i'm just not used to this kind of issues; i usually drive 1/8 buggys so i'm used to a bullet proof car.
I'm almost certain your servo mount is moving after a crash. If you don't have it already, use 3 screws to reinforce the mount to the chassis. Have a look on petiteRC for photos.
Racing4Evo is offline   Reply With Quote
Old 04-02-2015, 11:26 AM   #5675
Trader Rating: 24 (100%+)
i bet one of your ball cups is stripped. Replace the one that keeps moving. Secondly, use a servo saver from xray. Thirdly, make sure your cvd threads arent sticking out way past the outside of the wheel when mounted.... if so, shave those down flush with the wheel. Lastly, quit sucking and hitting stuff
gocoogs is offline   Reply With Quote
Old 04-03-2015, 07:14 AM   #5676
Bar
Paul
I currently have a 2015 BD7, I don't race indoors and don't crash that much, scales can be helpful, although I don't use any for balancing, more interested how the car performs on track.
Alloy chassis is great until it bends lol, no call for them for outdoor racing thankfully . Both are excellent cars though
Luke Burr
Old 04-03-2015, 02:35 PM   #5677
I have a couple of questions about some changes and how they effect. Maybe someone can answer me and tell me if my opinion is right:
- front motor conversion: when I use it the car has less steering in fast wide corners and more in small tight corners?
- short arms in the rear: the car has less grip in the rear and rotates better in tight small corners. It also is "harder" to drive trough fast wide corners because of less rear grip
- last year i drove my 2014 with 0.5mm shims under the FF and RR arms like \ /. I don't really now what the effect of that was but it ran pretty good. I'm thinking of testing this in my 2015 too but i want to know what the theory behind that is.
I run the car on asphalt on a bumpy track with 17.5T blinky
walzjer is offline   Reply With Quote
Old 04-05-2015, 05:17 PM   #5678
Your FMC findings sound about right since there should be less weight transfer with the motor further forward.
I'm not a big fan of shorter arms but I can't speak from experience since I've never had a desire to try it. It seems counter intuitive to reduce the stance when you could just reduce rear toe-in for a similar effect but you also get less rolling resistance which is a big gain in top speed for 17.5.
Shimming the arms like that effects the squat or anti-squat, there's already plenty of discussions about that in other threads here.
nwagner is offline   Reply With Quote
Old 04-06-2015, 12:15 AM   #5679
Racing4Evo's Avatar
The short arms are supposed to give you more grip. It slows down weight transfer and roll making the car more responsive off center and more stable. The car feels very different with the short arms. I didn't like it on carpet and haven't had the chance to try it outside but others that have tried it on outdoor asphalt and say it is hands down faster.
Old 04-06-2015, 05:23 AM   #5680
Paul
Both great cars but the xray is by far more resistant to tweak.
Yoko plastics are better than the standard t4 plastics.
DamianW is offline   Reply With Quote
Old 04-07-2015, 02:41 AM   #5681
Lonestar's Avatar
cannot agree more on the first one as discussed earlier
Can you elaborate on the second one? Judging by slop alone (which might be just the tip of the iceberg), I'm struggling with that statement...
Paul
Old 04-07-2015, 05:50 AM   #5682
DRKSYDE's Avatar
I recently picked up a bd7 rs to try my hand at tc. Are all the 2014/2015 parts compatible if or when I choose to update?
DRKSYDE is offline   Reply With Quote
Old 04-07-2015, 07:05 AM   #5683
Paul
I have just switched to the xray graphite plastics. From what I can see they are very similar is not equal to the yoko graphite parts so the below applies to both.
Stiffer and freerer. They should provide more grip and more stability.
The yok plastics effectively don't wear and after lots of use had less slop than a few race day old stock xray plastics.
The trade off is the graphite parts are more brittle and may lead to the chassi being more easily tweaked.
Old 04-10-2015, 12:19 AM   #5684
32819toon's Avatar
Default RS BD7
Is the RS BD7 any good ? I'm thinking of buying one. Are the plastic bulkheads strong enough ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 04-10-2015, 12:39 AM   #5685
EDWARD2003's Avatar
You're better off buying a used BD7 13' or wait for the BD7 RS ver 2.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests)
