Like Tree5Likes
Old 03-29-2015, 03:30 PM   #5656
Originally Posted by kobiwan View Post
When filling the rear gear diff with fluid, whats the proper fill point? In the manual it looks like they just cover the satellite gears. But People say to just cover the top pin.
there is really no real right or wrong fill point. you can change the feel of the diff by just putting in less oil. myself i fill to the top of the pin.
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 03-29-2015, 10:35 PM   #5657
AL1983's Avatar
Hi,
Thinking about replacing my BD7'15 bearings, which set is better? The Yokomo super precision or the ceramics? Are they worth the upgrade? Any other set better? Recommendations please.
Thx,
Albert
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-29-2015, 10:42 PM   #5658
El Asso Wipo's Avatar
Originally Posted by DaveVera View Post
Yes he is, but there no longer is a Yokomo USA. However, you can pretty much get everything from Amain, Tq hobbies, etc....
thanks
El Asso Wipo is offline   Reply With Quote
Old 03-30-2015, 01:32 AM   #5659
Lonestar's Avatar
Just do it consistently so you can feel the impact of a fluid change. A scale helps!
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-30-2015, 02:33 AM   #5660
cyba888's Avatar
on my Bmax4 offroad car it says 1mm above the pin...I now also do this on the BD7. if you cover the satellite gears I think it will be too much and overflow.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-30-2015, 10:16 AM   #5661
Originally Posted by AL1983 View Post
Hi,
Thx,
Albert
I'm using the Yokomo BD7 ceramic bearing package. Didnt felt much difference other than less maintaining lubricant for it.
jimmylim85 is offline   Reply With Quote
Old 03-30-2015, 10:17 AM   #5662
Btw guys, any opinions and advice for me to upgrade my front drive shaft to 3Racing race proven SSK drive shaft? Is it better in handling and powering during cornering? Thanks
Old 03-30-2015, 12:13 PM   #5663
Lonestar's Avatar
any DCJ will be smoother, give less chatter, provide more front end, than a single joint. The noise change is striking.
Old 04-01-2015, 02:16 PM   #5664
What effect does having the centre steering bridge in make?
And having the centre top deck screw in?
CLovely is offline   Reply With Quote
Old 04-01-2015, 05:14 PM   #5665
May I know what does DCJ means? Any recommendation? Thanks
Old 04-01-2015, 05:28 PM   #5666
b20btec's Avatar
Double Cardan Joint.
Yokomo, Spec R, Mr. Roche
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 04-01-2015, 11:43 PM   #5667
AllyITA's Avatar
just a little question from a novice (of touring)
i bought a used bd7 2014, tried a couple of times at the track and i noticed that almost every time i hit something or crash, the steering/suspension links of the front wheel change lenght, trowing completely off trim, camber etc..
is this to be expected in this kind of vehicle or are the plastics worn and in need of replacement? (they seem fine to me).
i know the right answer is "just don't crash", i'm getting there
i'm just not used to this kind of issues; i usually drive 1/8 buggys so i'm used to a bullet proof car.
AllyITA is offline   Reply With Quote
Old 04-02-2015, 12:30 AM   #5668
Lonestar's Avatar
also had very good luck with Arrowmax in the past, at least the old design with two grub screws, the quality was outstanding.
I also recall there was a hack to install TRF joints, as they were supposed to be the best in business... can someone help on that one?
cheers
Paul
Old 04-02-2015, 12:34 AM   #5669
Lonestar's Avatar
stop crashing
more seriously - replace balljoints, threads are likely stripped by now and they are moving as soon as you hit anything. I was also told the m3 thread depth of the stock turnbuckles is a bit on the shallow side, as opposed to (for instance) the optional yokomo titanium ones.
HAving said that - the yokomo isn't known for being as consistent under constraint as, say, an xray for instance (which never tweaks, never moves, even under crash...). This is the one thing I'm missing from my T4 '14 (and the non-leaky shocks too!)
Paul
Old 04-02-2015, 03:07 AM   #5670
NR
NR's Avatar
Trader Rating: 52 (100%+)
Always best to use a scale, the factory guy's are adding between 1.4 - 1.7 grams of oil. Most of the time 1.7, so I suggest go with that.
Nathan
NR is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
