Like Tree6Likes
Old 03-25-2015, 07:15 PM   #5641
b20btec's Avatar
Originally Posted by onroad dude View Post
does anybody have a photo of how the chassis weights are supposed to mount?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-25-2015, 07:18 PM   #5642
b20btec's Avatar
Which weights do you have? There's two versions of the front and rear. New versions front 10g with pin as oppose to 15g and rear is 30g with pin.
Soap
Old 03-25-2015, 08:03 PM   #5643
the 15g ones
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 03-26-2015, 05:56 AM   #5644
b20btec's Avatar
the 15g ones
I will take a picture for you later today installed on a chasses. Keep it mind the 15g will not fit if you're running a xray servo saver, you will need BWF10, the 10g version.
Soap
Old 03-26-2015, 08:46 AM   #5645
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default DCJ rebuild
I had a DCJ fail on me and was wondering is there a good way to prevent failure it was the nub on the axle that connects to the axle bone. Any help would be good thanks Chris
bigcracing is offline   Reply With Quote
Old 03-26-2015, 11:25 PM   #5646
El Asso Wipo's Avatar
Default Who's Running Yokomo USA now
Is Robert still team manager these days?
El Asso Wipo is offline   Reply With Quote
Old 03-27-2015, 04:30 AM   #5647
Lonestar's Avatar
Interesting comments a few pages ago about what is the one single setup change to modify the car
re chassis weights... I run wheel balancing weights on the electronics side. Cheaper than the yokomo ones, and 15g fits easily with the xray servo saver
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-27-2015, 06:51 AM   #5648
b20btec's Avatar
the 15g ones
I took a picture for you, but unfortunately it's no help, I forgot my phone at home.
Quick google search revealed a picture that may help you.
Soap
Old 03-27-2015, 06:54 AM   #5649
b20btec's Avatar
Which version DCJ is it? Pin type with set screw or the DCJ version with locking clip? If you're running the pin type it's prone to breaking, even with a slight bump of the wheel. Most have switched to the locking clip or other brands like MR. Roche and Spec R. I like the Roche, it has served me well.
Soap
Old 03-28-2015, 04:42 PM   #5650
bigcracing's Avatar
It is the pin type with set screws. Should I switch to the clip type? Or just get a Roche
Old 03-28-2015, 04:46 PM   #5651
b20btec's Avatar
I had success with either, including the spec R, as long as it's the C clip type.
Soap
Old 03-28-2015, 07:23 PM   #5652
Moderator
DaveVera's Avatar
Yes he is, but there no longer is a Yokomo USA. However, you can pretty much get everything from Amain, Tq hobbies, etc....
Motiv, Gravity RC, Joe Conte Racing ,Blast RC Paint, Sanwa, #~MASAMI~ . ROAR#27050. #FSEARA
DaveVera is offline   Reply With Quote
Old 03-29-2015, 06:47 AM   #5653
Bought myself a yokomo 15 second hand
Didn't come with the double jointed shafts
What's the size of the inner bearings needed for the roche double jointed shafts
And what's the size of the pin that goes through the roche double jointed shafts
CLovely is offline   Reply With Quote
Old 03-29-2015, 03:24 PM   #5654
When filling the rear gear diff with fluid, whats the proper fill point? In the manual it looks like they just cover the satellite gears. But People say to just cover the top pin.
Futaba 7PX---Xray T4 '18 ---R1 Wurks---EAMotorsports---Hobbywing
kobiwan is offline   Reply With Quote
Old 03-29-2015, 04:29 PM   #5655
bearing is a 5x10x3
the pin is a 1.6mm
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
