YOKOMO Touring Car BD-7
#5611
Just remove the 0.02 washer. I havnt run it on both my 14 and 15 due to it locking up the assembly.
My other thought was what spur gear are you running ?? as only the thinner ones fit like panaracer and leespeed, you can use thicker ones with different screws.
#5616
Can anyone tell me if getting these would be benificial.
http://www.excelllab.com/#!/cdql/!/A...668/category=0
#5618
#5620
Where I race at RSD, there's aluminum chassis galore along with the AVID chassis. Both companies are Texas locals so you do see a lot of testing. Regardless you can break anything and I've seen only one bent aluminum chassis due to a brutal high side. Anyways back to the excellab chassis, i'm not a sponsor driver and it is thin on the edges but so far I have zero issues with bending on carpet and asphalt. I did have some nasty crashes also and fortunately nothing but scratches and chassis is good to go. The guys running AVID chassis looks to have great success also. Aluminum sees to be the norm now for med to high traction, at least in my area.
#5621
I run the RW type of spur gears. also have the 3 bearings in the layshaft disintegrate on me today, so im getting in touch with CML Distribution tomorrow
#5625
Okay, I'm having trouble deciding Which Aluminum chassis to get. The Factory Yokomo or the Excellence Labs. I hear pros and cons of each one. Would appreciate some more input to hopefully sway me one way or the other. If anyone knows of any other manufacturer who makes one by all means let me know. Thanks
