Like Tree6Likes
Old 03-12-2015, 09:05 AM   #5596
Trader Rating: 15 (100%+)
Originally Posted by Lonestar View Post
what is the single suspension geometry adjustment you found to have the biggest effect on the car's balance, guys?
Paul
Not sure if you consider it a suspension geometry adjustment, but I have found that having the right droop, both amount at each end as well as balance from front to rear, is absolutely vital with this car. Not sure anything else has made as large of a difference in my testing.
Going from the 6.4 rear block to the 5.7 rear block also makes a huge difference in car feel.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-12-2015, 07:58 PM   #5597
EDWARD2003's Avatar
'what is the single suspension geometry adjustment you found to have the biggest effect on the car's balance, guys?'
I would say there isn't one single suspension adjustment that has the biggest effect on a cars balance. I think starting with your shock package is the most important aspect to any cars balance. Once you got that down you can then focus and fine tune the cars suspension geometry.
When it comes down to it, each geometry setting has it's primary and secondary effect on a cars overall balance (Entry, Mid, Exit).
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-12-2015, 08:28 PM   #5598
evochick's Avatar
For me its getting the diff where it needs to be, over all setup doesn't change much, might go up a spring rate or a little extra rear tow, but If i can get good rotation and drive out of corner that's where you make up the most time.
Other than that constantly checking and making sure the ride height hasn't changed due to tyre wear after a run.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 03-15-2015, 08:10 AM   #5599
cyba888's Avatar
Originally Posted by RedBullFiXX View Post
Rear Hub Carrier are different, for Left and Right
Look for dot below ball stud
Align both dots both to front
Yukijiro Umino aka Volkers mechanic said the there are no difference between left and right side...he said both are the same. Just asked him today on Facebook message. I believe the dot is from the molding process.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-15-2015, 12:52 PM   #5600
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Interesting
Well, he would know
Old 03-18-2015, 12:12 AM   #5601
Nice. I just took my car apart and flipped them because everyone said the dot has to go forward
hershey66 is offline   Reply With Quote
Old 03-18-2015, 03:51 AM   #5602
the manual does say : pay attention to the direction of the part
not sure why the tekst is there, if it was for the dot it is not very clear.
if it isn't about the dot, i can't see what other part it could apply to
atomic garden is offline   Reply With Quote
Old 03-18-2015, 05:51 AM   #5603
NuttsnBolts's Avatar
Been watching the topic about the rear hubs, little dots and the toe direction and I do think that some people are "SERIOUSLY" over thinking the instructions.
So before I go to explain I want people to clear their thoughts about the build, marking on the parts and any other information that was injected into the topic over the past few days.
Done?... Good.
Now look at the picture below that was posted up a few weeks ago and just answer the question that is posted just after...
Could the "Pay attention to direction of part" be in regards to the arm so that you don't accidental assemble two left hand, or right hand arm assembly?
= Castle Hill Raceway =
NuttsnBolts is offline   Reply With Quote
Old 03-18-2015, 05:52 AM   #5604
no because the arm has his own pay attention box, there is a 2nd box pointing at the hub
Old 03-18-2015, 06:07 AM   #5605
Exactly!!! There are Two ways to get this assembly wrong.
The Arms and the Hubs are interchangeable meaning that if you flip either one of the parts, not swap parts, you will end up with the opposite arm assembly.
You know I'm making sense here.
Old 03-18-2015, 06:09 AM   #5606
that does make sense
maybe we did just freak out because of the little marks on the hubs
but didn't someone measure a difference?
Old 03-18-2015, 06:21 AM   #5607
That could be because of many different reasons. Tweak being one of them and how many shims he had between the suspensions shafts. The bearings may be slightly misaligned thus altering the shaft angle and the hex nuts do clamp onto a pin that can twist if the nut centre hole is a little large. I know when I measure Toe angle on the front I turn my steering one way and measure; turn it the other way and measure; and then lift the front and place it down in neutral and measure, all because of the slop that can be present within a car.
Old 03-18-2015, 07:49 AM   #5608
b20btec's Avatar
Some of you guys seriously went overboard with the rear hub.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-18-2015, 08:33 AM   #5609
Haven't the rear hubs been the same since the BD5?
Serzoni is offline   Reply With Quote
Old 03-18-2015, 01:58 PM   #5610
hydrakermit's Avatar
Default Screw in layshaft
Hi all,
My names Josh,
I wonder if someone can help, sorry if this has been asked previously,
When I first assembled my BD7 15, I couldn't tighten the little M3x6 flat head screw that goes into the layshaft, if i do, when the drivetrain runs forward the whole drivetrain locks up, as the car was new i didnt want to over tighten it, so i decided to slacken it up (maybe a little to much) on the first run with the car, the screw and bearing flew out during a race and I lost them.
Is there anything i can do to prevent this?
I have brought new screws and the washer and bearing that I lost and put a little thread lock on a M3x6 flat head screw, this has so far worked for 5 rounds.
Ive heard I can use a button head screw without the washer, but im unsure what size screw, maybe M3x8 Button head?
Just wondered if anybody has/had this problem and what you have done to prevent it, also wondered what you lot are running.
I have attached a pic of the screw in question, the pic shows someone using a button head screw with no washer, hence the question.
Any replies and help is appreciated.
hydrakermit is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
antlockyer
