Like Tree5Likes
Old 03-03-2015, 10:58 AM   #5566
Lonestar's Avatar
Thumbs up
Originally Posted by Jorge T View Post
Just leaks more w/2k-5k cst oil than the new ones. (they still leak a bit), but if you plan to run it with 1million cst or putty in the front it won't matter.(probably won't leak)
Thanks Jorge
Does it tend to leak via the outdrives or main ring side?
Plus i thought xtian and you were xray guys
Cheers
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-03-2015, 12:56 PM   #5567
I have built my new 15 edition, but my steering is binding up. But it moves freely after moving it side to side, but went to install the servo and checked it again and not moving free. I have stripped it down seven times and in is in the steering rack area, not in the hubs and caster blocks.
Going to try my 14 edition steering rack to see if that is the problem. Anyone else had this?
tiny tom is offline   Reply With Quote
Old 03-03-2015, 10:11 PM   #5568
rc_square24's Avatar
Nearly completed my build as well but haven't had your problem with my steering rack. You say you narrowed it down to the rack area that's causing the bind but that could the the left or right steering post or in the center piece. Did you check for binding after each part was installed, or each screw tightened?
rc_square24 is offline   Reply With Quote
Old 03-04-2015, 01:13 AM   #5569
Found the problem, had to strip my 14 down at the same time as the 15 and found a small bure on the steering rack and problem solved.
Old 03-06-2015, 05:55 PM   #5570
AL1983's Avatar
Hi,
which chassis protector decal is best for the BD7'15? Want to protect my chassis from asphalt scratches.
Thx, if possible post pics.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-07-2015, 05:12 AM   #5571
cyba888's Avatar
Originally Posted by AL1983 View Post
Hi,
I use associated it's thicker but very good protection. No need to cover entire chassis just use a few strips. Can show you pic if you want
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-08-2015, 03:06 PM   #5572
I just purchased a used 2014 bd7 that I haven't received yet. I'm looking for lipo battery advice as this is my first modern day touring car. I'm going to be running blinky 17.5.
I'm looking at the turnigy Nano tech ultimate 90c and they come in three flavors. 6000mah/340g, 6600mah/340g and 7500mah/350g. Weights are with wires and plugs. My electronics servo,motor, esc and motor fan weigh in at 310g.
Thanks for any advice
2uzferunner03 is offline   Reply With Quote
Old 03-08-2015, 03:32 PM   #5573
b20btec's Avatar
If your track follow roar rules 1380g stick to a pack 300 grams and under, then balance car left to right. There's no need for anything 6000mah and above for a 5min race with a 17.5 motor.
Orca power plus 265g
Orca HV series is around 285
Muchmore
R1
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-08-2015, 05:58 PM   #5574
EDWARD2003's Avatar
How many of you fill up your gear differentials up to 100%?
I personally do and the differential works beautifully, no leaks, nothing.
What is the reasoning behind filling it up only to 70%?
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-08-2015, 06:56 PM   #5575
NuttsnBolts's Avatar
I'm guessing pressurisation within the diff and on the o rings. Plus, if you fill to 70/80% the large gear will take up that last portion of free space. So filling up to 100 will only be wasting oil by forcing it out during assembly.
//Yokomo BD-7, 2015 Black Series
//Sanwa MT-4
= Castle Hill Raceway =
NuttsnBolts is offline   Reply With Quote
Old 03-08-2015, 07:41 PM   #5576
EDWARD2003's Avatar
True. Good to know
I'll fill the differential up to the very edge with oil. Then I'll leave two of the four screws out to allow for excess oil to bleed out. Once I feel most of the oil has been removed, I then add the remaining two screws. Then back all four screws out and tighten them down uniformly.
                 VBC 12M - D08 - FX
Old 03-08-2015, 11:51 PM   #5577
XSLR8's Avatar
Well it looks like Umino takes Diff filling a little more seriously...Lol
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 03-09-2015, 01:52 AM   #5578
G4ZZ4's Avatar
Is that in gram? And how much
Thanks in advance
G4ZZ4 is offline   Reply With Quote
Old 03-09-2015, 02:52 AM   #5579
Lonestar's Avatar
what really matters is you fill it consistently time after time... you can't measure exactly how much there will be in anyway unless you COMPLETELY clean it up before each refill ,which is unrealistic. So just measure the total diff weight
(that's the way I do it, at least...)
Old 03-09-2015, 03:34 AM   #5580
XSLR8's Avatar
Thanks in advance
LOL... you should know, that's Scotty's car he's working on @ TITC
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
