Like Tree5Likes
Old 03-02-2015, 06:13 AM   #5551
AL1983's Avatar
Need help! My BD7'15 rear end to loose, I have ton of front grip and steering, but rear end doesn't feel planted and slides in high speed corners. Our track layout is much the same as RCaddict (TITC 2015) track. Asphalt track, outdoor!
See pic for my current setup:
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-02-2015, 08:35 AM   #5552
Trader Rating: 15 (100%+)
If you are running on carpet with medium-low grip, you can try adding rear toe (3 degrees instead of 2.5 degrees.) Also, I would recommend trying the normal Yokomo pink/blue springs instead of HPI silvers, since you are running on carpet and not asphalt.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-02-2015, 09:39 AM   #5553
AL1983's Avatar
Post Asphalt
Sorry forgot to select asphalt, I'm running on Asphalt.
Old 03-02-2015, 09:45 AM   #5554
Go to standard wheel base at the front 0.5mm and 0.5mm and go back to 3.5mm block at the front and it will be sorted
jordan.norwood@ is offline   Reply With Quote
Old 03-02-2015, 11:06 AM   #5555
Originally Posted by evochick View Post
sorry other way as in they were much tighter then stock belts, so the front and rear diff do sit a little higher.
My rear is the same 2notches slack from centre but front now 4 notches slack from centre. Instead of 2. So front diff is slightly higher than rear.some people say they don't notice any difference with duffs high or low. But it does mean the shafts are back a little more.
T2 SLOW is offline   Reply With Quote
Old 03-02-2015, 12:50 PM   #5556
NuttsnBolts's Avatar
Maybe try more toe on the front. 0.5 isn't much so try 1 or 1.5
Also, double check your droop and ride height. Your car may not be rolling efficiently thus possibly looking traction.
//Yokomo BD-7, 2015 Black Series
//Sanwa MT-4
= Castle Hill Raceway =
NuttsnBolts is offline   Reply With Quote
Old 03-02-2015, 03:28 PM   #5557
AL1983's Avatar
Thx nuts, will try these out
Old 03-02-2015, 07:06 PM   #5558
Stuff Of Legend's Avatar
Thumbs up
Thanks NuttsnBolts, RedBullFiXX
Yokomo DJS introduced Page 83, Post #3309
Stuff Of Legend is offline   Reply With Quote
Old 03-02-2015, 08:40 PM   #5559
Also add more front droop then try softer rear by going to hole 1 or 2 on the rear shock tower.
DamianW is offline   Reply With Quote
Old 03-03-2015, 04:51 AM   #5560
Lonestar's Avatar
hey guys I just built a spare differential for my bd7 15
I ordered the reference called out in the spares parts list the one that ends with GS
except it's not the same as the one in the kit its looks like an older version there is no oring for instance although it seems to work perfectly fine on the workbench once I put some lonestar magic in it as well as broke it in on the drill
what is the proper reference I need to order next time I think I will keep this one as a front one with 2.5 million grade oil
thank you, Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-03-2015, 06:46 AM   #5561
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Smile
thank you, Paul
B7-500GS (2015)
BD-500GS (BD-5 --> BD-7 14')
Yokomo Products
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-03-2015, 06:53 AM   #5562
Lonestar's Avatar
i guess i can only blame myself!!! thank you.
any big no-no running the older one at all?
thanks!
Old 03-03-2015, 08:30 AM   #5563
Anyone know where I can find a toe chart? Also, where can I find where it tells me the poundage of the springs? I'm new to the car, not sure what spring is stiff or soft.
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 03-03-2015, 08:35 AM   #5564
http://www.petitrc.com/reglages/yoko...hubsExplained/
Old 03-03-2015, 08:49 AM   #5565
Jorge T's Avatar
thanks!
Just leaks more w/2k-5k cst oil than the new ones. (they still leak a bit), but if you plan to run it with 1million cst or putty in the front it won't matter.(probably won't leak)
RSD MS
Jorge T is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
