Like Tree6Likes
Old 02-27-2015, 11:20 PM   #5536
Trader Rating: 15 (100%+)
Originally Posted by tiny tom View Post
Only 2hrs into the build, and running the forward motor upgrade. The problem is I can't run it with belt tensioner on it? Anyone come cross this?
Nope - belt tensioner fit just fine for me with FMC. Why can't you use the belt tensioner?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-28-2015, 08:00 AM   #5537
It isn't sitting right, and the belt is to far over, and belt rubs on the carbon. Will take pictures and put them up later
tiny tom is offline   Reply With Quote
Old 02-28-2015, 07:09 PM   #5538
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
Brand new TRF419. Looking to trade for a bd7. If anyone is interested.
Tamiya TRF419 brand new !!!! WTT for 2015 yokomo bd7
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 02-28-2015, 07:12 PM   #5539
EDWARD2003's Avatar
Does anyone have a BD7 14' conversion they're not using? Pm me
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-28-2015, 07:30 PM   #5540
b20btec's Avatar
I have a motor mount and complete bulkheads. Split blocks I'm not sure where I left them.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-28-2015, 10:25 PM   #5541
rc_square24's Avatar
Is there a rule of thumb for setting the belt tension? Like 3mm slack on center of the belt?
rc_square24 is offline   Reply With Quote
Old 03-01-2015, 12:01 PM   #5542
Problem resolved, the hole in the top deck was a bit to small and the belt tenisoner wasn't sitting right. But drilled right now
Old 03-01-2015, 03:02 PM   #5543
Default Low friction belts
Just fitted some low friction belts to my 2015.the rear belt is 2 notches slack same as old belt.but front belt is 4 notches slack to get same tension as before.has anybody else found this.
T2 SLOW is offline   Reply With Quote
Old 03-01-2015, 03:57 PM   #5544
evochick's Avatar
Yep mine were the same, I dont think they stretched much after break in either.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 03-01-2015, 04:31 PM   #5545
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
If you are saying theses belts require less notches than kit belts
That would be good, as it would align the diffs closer to lowest possible position
Old 03-01-2015, 06:06 PM   #5546
evochick's Avatar
sorry other way as in they were much tighter then stock belts, so the front and rear diff do sit a little higher.
Unretired
Old 03-01-2015, 07:02 PM   #5547
Ok. So I have the option to get a brand new 2014 car, As a trade. Is it worth it? Or should I not mess with the 14 and get a 2015?
Is the 2015 a far superior car?
Nick George
Old 03-01-2015, 07:41 PM   #5548
BD7 2013,14,15
Are all fantastic cars
Old 03-01-2015, 09:52 PM   #5549
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Not a big difference between the 14 and 15. Lower chassis is interchangeable.
Racing4Evo is offline   Reply With Quote
Old 03-02-2015, 04:23 AM   #5550
cyba888's Avatar
get the 15... you have the option to run front motor conversion
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
