Like Tree6Likes
Old 02-20-2015, 05:15 AM   #5491
Stuff Of Legend's Avatar
Thumbs up
Thanks for all the advice
Stuff Of Legend is offline   Reply With Quote
Old 02-20-2015, 07:48 AM   #5492
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rc_square24 View Post
So I'm about to place an order for a 2015 BD7 but I've never owned a Yokomo so have some questions. I'm gonna get some spares like arms and c-hubs steering blocks. Are all bd7 suspension parts (especially the composite ones) throughout the BD7 models the same so far? I'm asking because shops list some items as "BD7" only without indicating the model year. Now for DCJs, Roche seems to be what most people get, but how do Spec-R compare (they have version 2 and P8, not sure the difference)? What about the ones that 3-racing makes? Most will work with the kit spool outdrives?
Thanks!
BD7-15 Parts List
fyi
c-hubs are not the same as BD5
"B7" reference are BD7 parts
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-20-2015, 09:21 AM   #5493
b20btec's Avatar
Ran the excellence lab chassis last night during club race on carpet. I arrived at the track really late and missed a qualifier, so tuning time was very limited. Overall impressed by the fit and finish although bit pricey compared to the factory aluminum.
I'm not the top racer at my track, to run a fast race lap/time I always had to be near perfect to achieve this with my other 15 with aluminum chassis. Overall I was able to shave approx 5 seconds off total race time on this 15 with a slower motor. Next outing I will swap to a faster motor and see what it can do.
I'm not very technical at explaining things so bear with me. If I were to compare this chassis stiffness based off driving feel it would be in between the factory carbon and factory aluminum.
YOKOMO Touring Car BD-7-img_3920.jpg   YOKOMO Touring Car BD-7-bd7-15-2-tc-rsd-02.19.2015.jpg
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-25-2015, 08:28 AM   #5494
vicdamone11's Avatar
Send a message via AIM to vicdamone11
Where can I find a 4.2 arm mount and an aluminum chassis?
TLR | Horizon Hobbies | Team Orion
Spektrum | Jconcepts
Team Tekin | 92zero designs
Gator Graffix | Timewarp Raceway
Hobbytown USA - Lake in the Hills... Not enough droop!!
vicdamone11 is offline   Reply With Quote
Old 02-25-2015, 09:43 AM   #5495
Trader Rating: 15 (100%+)
Good luck with the 4.2 arm mount. You can get them in blue from almost anywhere, but the black ones are impossible to find right now.
Aluminum chassis is available from any of the asian retailers. I recently ordered one from Banzai, but I think rcmarket also has them in stock.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-25-2015, 10:44 AM   #5496
b20btec's Avatar
asian retailers have them, our usa distributor is a complete joke.
Soap
Old 02-25-2015, 01:06 PM   #5497
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
very clean trf418, looking to trade for a BD7, if anyone is interested
TRF 418 Tamiya Roller
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 02-25-2015, 07:43 PM   #5498
policeman0077's Avatar
Which parts do I need to convert a BD7 to BD7 2014?
main chassis
top deck
motor mount
center pulley shaft
whats the difference between YOKOMO B7-630B and YOKOMO B7-630? can I fit BD7 steering on BD7 2014 chassis?
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 02-25-2015, 08:04 PM   #5499
evochick's Avatar
main chassis
top deck
motor mount
center pulley shaft
B7-00214
B7-00314
B7-32L (or B7-32LB)
B7-32S (or B7-32SB)
B7-644T14
B7-674B
B7-630B
I wouldn't worry about changing the steering the 13 steering fits fine and geometry didn't change. You do need to use the new pulleys they have a better fit for the smaller bearings.
I think that's it.
Beth.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 02-25-2015, 08:15 PM   #5500
Originally Posted by evochick View Post
B7-00214
B7-00314
B7-32L (or B7-32LB)
B7-32S (or B7-32SB)
B7-644T14
B7-674B
B7-630B
I think that's it.
Beth.
THANK YOU VERY MUCH
多情自古伤离别。更那堪、冷落清秋节。
Old 02-25-2015, 08:48 PM   #5501
evochick's Avatar
I should also add I am convinced the 15 motor mount B7-32L15 should fit the 14 chassis, It is a stronger mount. I just havnt had time to test to see and swap it between my 2 cars.
Unretired
Old 02-26-2015, 12:29 AM   #5502
rc_square24's Avatar
Does anyone know the difference between the two kinds of Yokomo belts available? For instance the YOK-BD-516L and YOK-BD-516LB? The L belts are black on the toothed face while the LB ones are tan/brown.
The pictures are front and rear belts but I'm referring to the difference in the toothed face.
rc_square24 is offline   Reply With Quote
Old 02-26-2015, 02:21 AM   #5503
BD7 Parts List
Low Friction Belt
Ideal for stock class of touring car, it is low friction rear drive belt for BD5 / 7. Use a flexible material than conventional, to prevent the drive loss.
Old 02-26-2015, 05:57 AM   #5504
evochick's Avatar
The low friction belts are very good but even in 13.5 dont last very long.
And without warning they go all puffy.
Unretired
Old 02-26-2015, 07:16 AM   #5505
Lonestar's Avatar
Those of you with a Hudy setup bench... can you please drop your car on the setup station and check whether you have symmetrical rear toe? Mine sure isn't... I've tried wiggling all the three a-arm blocks, as well as replacing the RR block by a 2.5deg one, my right wheel is still 1deg off...
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
antlockyer
