Like Tree5Likes
Old 02-03-2015, 01:27 PM   #5401
porsche928gs's Avatar
Originally Posted by mac853 View Post
Could anybody tell me if Yokomo BD7 High Traction Upper Deck (YOK-B7-003H) fits on BD7 2015, please?
Best regards
Don't need it. Just get the aluminum chassis.
porsche928gs is offline   Reply With Quote
Old 02-03-2015, 01:29 PM   #5402
Originally Posted by reg View Post
Does anyone know which is the bigger weight saving,
Ti turn buckles or ti screw kit?
Close to the same. But if I had to choose it would be the turnbuckles as they are higher up on the chassis.
Old 02-04-2015, 04:05 AM   #5403
EDWARD2003's Avatar
Since the BD7 14' and 15' is without out the right lay shaft support, do you think this modification is good or bad idea?
Or will this open a whole new can of handling problems and ultimately damage the spur gear or lay shaft?
EDWARD2003 is offline   Reply With Quote
Old 02-04-2015, 04:06 AM   #5404
EDWARD2003's Avatar
Continued.
Old 02-04-2015, 09:33 AM   #5405
reg
Thank you good advice 👍
reg is offline   Reply With Quote
Old 02-04-2015, 08:39 PM   #5406
mac853's Avatar
OK, thanks for your reply.
About aluminium chassis, i am so doubted if use it in carpet track with tight layout and medium traction use panaracer carpet as control tires.
Best regards
mac853 is offline   Reply With Quote
Old 02-05-2015, 10:21 AM   #5407
anyone else having side to side play in the spool?
Keeven is offline   Reply With Quote
Old 02-05-2015, 10:39 AM   #5408
Best regards
I've used it on carpet and asphalt. Is a good setup tool when having high traction. It makes the car drive easier at the same pace.
Old 02-05-2015, 10:41 AM   #5409
Check Andrew Hardman's 13.5 setup for snowbirds.
Old 02-05-2015, 11:00 AM   #5410
reg
Where do we find it 😫
Old 02-05-2015, 03:10 PM   #5411
Fjeld's Avatar
You can just remove the right lay shaft support. Did that with a 4,5 bosted modified car and dit not brake any more spur
Fjeld is offline   Reply With Quote
Old 02-05-2015, 03:18 PM   #5412
stiltskin's Avatar
Trader Rating: 102 (100%+)
Andrews car looked great on mains day. He struggled a bit to find the right setup for his 13.5 car but it looked pretty good when it counted.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-05-2015, 07:11 PM   #5413
mac853's Avatar
Old 02-06-2015, 07:19 AM   #5414
Lonestar's Avatar
I second that question... thnaks!
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-06-2015, 10:22 PM   #5415
evochick's Avatar
Ok, I think I have found the way to build the perfect smooth 15 diff, that doesn't leak after a while
I really wasn't happy with how tight the kit red o rings were so was using the black GOB o rings. I had a little success with these but would eventually leak after a few weeks of use and required a rebuild. After a little bit of experimenting I have found that Kyosho Red o rings, were a much better fit in the 15 diff, but would swell a little and make the outdrives tight over the course of a weeks. The solution was then to remove the really small outer washer. This just gave the Kyosho O ring a little more room freeing it up.
So far so good and no leaks.....
UnRetired
evochick is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Gayosaka
