Like Tree6Likes
Old 01-28-2015, 02:23 PM   #5386
Originally Posted by EDWARD2003 View Post
The measurement is measured at the pin. You"ll have to use a ruler to get those readings. You can just watch the video which covers this measuring method and many others.
https://www.youtube.com/watch?v=GYVcEPO3FME
thanks for the vid! i guess i just feel like the arms would be angled up huge all the time with the setups they post is all..
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 01-28-2015, 04:31 PM   #5387
bigbank66's Avatar
Originally Posted by onroad dude View Post
i run on carpet. but i could fill out a sheet for you and post it up if you would like!
Cool...im running on asphalt an i need all the corner speed i can get...we have a lot of 180 turns on our track..
bigbank66 is offline   Reply With Quote
Old 01-28-2015, 04:34 PM   #5388
bigbank66's Avatar
Default hpi springs
I cant find the silver hpi spring anywhere....is there another spring similar out there??? Or do someone has a set they want to sell??
Old 01-28-2015, 04:42 PM   #5389
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Wink
TQRC has them
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-28-2015, 04:51 PM   #5390
i would say order up a oneway for the front if thats the case
Old 01-30-2015, 09:43 AM   #5391
Lonestar's Avatar
Hey Folks
something weird happening to my car - top shock caps sitting askew on the shock bodies...
I've inspected the thread on the shock body, replaced the cap by a brand spanking new one (thinking I had stripped the thread), and, well, it still doesn't sit "flat". What's weird is that it sits flat when I assemble it "empty" with no bladder and top plastic mount... but when assembled for real, it's tilted. Of course, that shock leaks. The delta is about half a millimeter from one side of the shock body to the other.
Any suggestions? I'm really puzzled on this one
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-30-2015, 09:49 AM   #5392
reg
Originally Posted by Lonestar View Post
Hey Folks
Paul
Mine were the same when I fitted them dry,when I built them though for real I just did them up as tight as I could and they are fine,if you have 2 sets just go for it,but you won't stip them,
reg is offline   Reply With Quote
Old 01-30-2015, 12:54 PM   #5393
Hey Folks
Paul
Replace bladders with black ones if you haven't already
Old 01-30-2015, 01:43 PM   #5394
Lonestar's Avatar
Brand spanking new black ones on top of (actually, below...) brand spanking new top caps
Old 01-30-2015, 02:18 PM   #5395
Have you pushed the piston up into the shock before placing the plastic shock cap into the bladder ?
Old 01-30-2015, 02:58 PM   #5396
Do it like this:
Fill the shocks. Set your rebound (if zero rebound) push the piston up till you have 2mm left between your shock end and your shock. I use an old Xray caster clip to make sure it is 2mm http://www.teamxray.com/teamxray/pro...2,1mm%20%20(2)
Keep your piston/shock shaft pushed in, with the caster clip in between. After that, slowly, gently, slide your bladder in its place. Let it sink by itself. After that gently push the bladder down until it sits in its place.
Now, this is important, put the cap end (plastic top part) on the bladder and push the cap end down and thus your bladder as well. Hold it like that and just push a little bit, let the excessive oil leak out and just turn the cap end a few times, making sure everything sits fine and does not bind or sticks out too much. So hold the cap end down, still pushing the shock shaft up, and now take the cap nut and put it on the thread. First turn the opposite direction, against the thread, in this way you will "find" the start of the thread. After that, screw the cap nut on, while still pressing down the cap end (gently). Keep doing this until everything sits fine. Check rebound and you're done...
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 01-31-2015, 03:29 AM   #5397
fasfury is offline   Reply With Quote
Old 01-31-2015, 06:04 AM   #5398
Lonestar's Avatar
Originally Posted by Govert View Post
Do it like this:
you pretty much exactly described how i do my shocks, except i dont turn the top plastic part onto the bladder before screwing the top cap on... i use a 3mm shim too that i built from old fuel tubing... and my plastic tops are drilled for no parasitic rebound.
it s always that one same shock where the top sits sideways... but the thread looks fine both on body side (hard anodized) and top cap ( brand new...)... thinking about defectove machining now...
Old 02-03-2015, 11:45 AM   #5399
mac853's Avatar
Could anybody tell me if Yokomo BD7 High Traction Upper Deck (YOK-B7-003H) fits on BD7 2015, please?
Best regards
mac853 is offline   Reply With Quote
Old 02-03-2015, 01:31 PM   #5400
reg
Does anyone know which is the bigger weight saving,
Ti turn buckles or ti screw kit?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
