Like Tree2Likes
Old 01-21-2015, 11:40 AM   #5341
Lonestar's Avatar
Originally Posted by DaveVera View Post
To eliminate the trim issue, use a 2mm shim on the bottom of the servo mount where the open area is. This will keep it from moving
yep done that already
thanks tho!
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-21-2015, 11:55 AM   #5342
bigbank66's Avatar
Default spurs??
Fellas looking to change out My spur gear...I need a 88... which other brand spur will fit the yok??
bigbank66 is offline   Reply With Quote
Old 01-21-2015, 12:22 PM   #5343
b20btec's Avatar
Panaracer and Xenon
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 01-21-2015, 01:30 PM   #5344
Teodoras's Avatar
Hi guys,
Is it worth to upgrade BD7 rs to 2015 car? Is it even possible? I'm trying to make a decision on my first TC car - to go with RS version, or go from the very beggining with BD7 2015. Is it good car for a guy who's new to TC class?
“Being second is to be the first of the ones who lose."
Ayrton Senna
Teodoras is offline   Reply With Quote
Old 01-21-2015, 01:45 PM   #5345
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Teodoras View Post
Hi guys,
Do you want to race, or just play ?
Old 01-21-2015, 02:20 PM   #5346
Hi guys,
a TC car will be so expensive if you get all electronics and consumables/spare parts that the price diff between a rs and 2015 will not matter that much in the end
go for 2015 if you start with the RS and start "upgrading" you will spend even more
also i think a beginner car doesn't exit, the 2015 is a lot easier to drive than a cheaper TC
atomic garden is offline   Reply With Quote
Old 01-21-2015, 04:07 PM   #5347
niznai's Avatar
Yes, it is possible, and can be marginally cheaper if you pick and choose wisely and buy on the internet from SE Asia (and don't pay import tax).
However, if you have such questions, I am not sure you'd get the full benefit of a full blown racer.
The main benefit is that you could in theory buy only what you need, as you need it. You will need a front spool straight off the bat though.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-21-2015, 10:04 PM   #5348
The plastic spool that comes with the RS is made of glass. And not solid either. Think intricate blown glass that shatters if you look at it funny.
cplus is offline   Reply With Quote
Old 01-22-2015, 12:01 AM   #5349
the difference between a 2015 (480 euro) and a RS (190 euro) will be gone in a few upgrades and you will still have an inferior car
42 euro for the spool
+ whatever of the other aluminium/ carbon parts you want
the 3 upgrade sets yokomo sells would set you back 221 euros
http://www.fast-webshop.com/tonispor...omo-BD7-ver-RS
even if you pick the bare essentials, you will save very little money over a real 2015, and you will be chasing setup problems all on your own because of your special mix car no-one else is racing
this is not clear if you start out racing, i made the same mistake, the 290 you save when you buy the car seems like a lot of money, but if you go race you will spent so much money on parts, consumables and electronics that after one year the difference will be very small and you just had a year with a cheap car for a lot of money
get the 2015, you can share setups with other racers and you won't be chasing setup problems with a cheaply made car.
Old 01-22-2015, 05:43 PM   #5350
303slowdown's Avatar
Trader Rating: 19 (100%+)
Could someone measure a rear swaybar for me ? I need the measurement of the middle where it mounts and the measurement of the end part ( or wing part) of the wire . Thanks
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-22-2015, 05:52 PM   #5351
35-108mm
Old 01-22-2015, 08:31 PM   #5352
Thank you.
Ryan Borgheiinck
Old 01-22-2015, 09:09 PM   #5353
Hi guys,
if you ned to save money buy a used 2013 / 2014
I have tried the cheap route before and honestly the cheaper components just don't seem to hold setup changes well and you chase your setup all day, not to mention all the upgrades you are going to buy . . . .
mupchu is offline   Reply With Quote
Old 01-23-2015, 02:36 PM   #5354
Jochim_18's Avatar
Originally Posted by Lonestar View Post
I assume you had to buy a bigger helmet too...
Nope.. the car is just that good and very pleasant to drive.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 01-23-2015, 06:22 PM   #5355
Default Question about different gearing
Hi everybody,
I dont know if someone can help me.
My question is about what is the difference gearing a 13.5t boosted motor in a yokomo 2013 , with 105/41 64p ( this is the gearing I am using now , the motor temp is about 82š celsius , The track is about 200m , straight about 60m.
and the other gearing is : 90s spur / 40s or 50s pinion . What of these two are better and why?
Iam trying to reduce my laps time and reduces the motor temp.
The motor will run cooler, with the second way of gearing?
I will really appreciated your help.
Thank you!!
Nick1
nick1 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
