Old 01-14-2015, 11:29 AM   #5251
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Robbob View Post
Care to share your setup or one that's relatively close to yours?
Sure.
I make minor changes to this basic setup, for different layout, tires, etc
But rarely veer to far away from the base
To be honest, I've never had a t-roll issue with a BD7
The Alu chassis is just easier to drive for my pan car style
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-14-2015, 11:45 AM   #5252
niznai's Avatar
Originally Posted by Lonestar View Post
Well - the angle of the steering link is what makes the "interesting" difference, the steering angle as a function of the servo input will be different with different servo arms and I'm not just talking longer arm => more throw. It's funny how people love to talk about 0.5mm of shim here and a quarter degree of camber there but oversee that one! Simple geometrics, really, dude
If you understood geometry as you claim you'd realise the fallacy of your own argument.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-14-2015, 11:48 AM   #5253
Trader Rating: 15 (100%+)
Originally Posted by RedBullFiXX View Post
Sure.
What happens if you run Jaco blues or the Gravity tires? I agree re: traction roll if you run Sorex, but my experiences are far different with Jaco Blues, especially after the first run on a new set.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 01-14-2015, 12:32 PM   #5254
unwritten's Avatar
thank you for all the input guys...
and RedBullFiXX for sharing your setup.
unwritten is offline   Reply With Quote
Old 01-14-2015, 12:36 PM   #5255
Fjeld's Avatar
Originally Posted by LloydLoar View Post
Where have you seen setup sheets from DHI? Just curious - would like to check them out.
Have not seen any setup sheet. But I was driving there
Fjeld is offline   Reply With Quote
Old 01-14-2015, 12:51 PM   #5256
Sure.
Appreciate that, thanks.
Robbob is offline   Reply With Quote
Old 01-14-2015, 01:13 PM   #5257
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Please stop.
Lonestar is actually correct. The resolution of the steering input changes with different length servo horns.
Racing4Evo is offline   Reply With Quote
Old 01-14-2015, 01:37 PM   #5258
Lonestar's Avatar
no worries - my key takeout is that noone uses this as a tuning aid, which is perfectly fine with me
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-14-2015, 01:41 PM   #5259
I know some people feel they are empowered on the internet. But I've noticed you generally are a smart ass on every chat room. And feel you have to put your opinion on everyone's questions. Just the other day I seen your post when someone asked in one of those "what car to buy threads". Your first words were basically calling him a dumb ass for asking. I can beat you with nearly any chassis from 2002 on. If you think you have to be an ass. Just don't respind to people's "stupid" questions.
Juan Aveytia is offline   Reply With Quote
Old 01-14-2015, 01:43 PM   #5260
For me the gravity tires have the least side grip of any spec tires I have tested
Have not tried Jaco Spec in over a year, they used to be quite hard, I believe the new vers is much softer ?
i like the RIDE Rex30 ETS tire
But track owner will always have us on Sweep QTS32 for a spec tire
And remember folks
The "ignore" feature is very helpful here
Old 01-14-2015, 02:17 PM   #5261
nolo148's Avatar
Ran the 2014 BD7 with the aluminum chassis last weekend at WCICS Round 5 IROCC Victoria race with over 230 entries, car was quick and easy to drive. Tires were the Sweep QTS 32 and I ran Hardman's setup found here:
http://www.petitrc.com/reglages/yoko...eGate20141026/
Try it out!
Owen Ren
ll ORCA ll Pro-Spec ll
Overgeared Racing BOD (Facebook - Overgeared Racing)
nolo148 is offline   Reply With Quote
Old 01-14-2015, 02:39 PM   #5262
And remember folks
Yep, new version is much softer. When I run Hardman's setup here at 5280 with new Jaco Blues, the inside rear will unweight and lift in a rather aggressive fashion. If I drive really smooth the car stays relatively level, but my driving style doesn't necessarily mesh well with that trait...
If I make changes to reduce grip and loosen the car up it helps, but I think that if traction was much higher (cough, snowbirds) the car would be traction rolling left and right. Sadly, I don't think the 2015 aluminum chassis will be available prior to Birds, so I will need to figure out some other setup changes to make it work.
Old 01-14-2015, 04:14 PM   #5263
What's your setup ?
Old 01-14-2015, 04:56 PM   #5264
Well i ran my 2015 in rubber touring this past weekend for the first time! wow the car is awesome! few small changes to keep it planted on high bite carpet. But a huge improvment over the tc6.1 i was running! as far as tires go i ran some sweep true blu 32's and some jacos back to back i feel the sweep had much better grip and felt more consistant through the whole race!
i have a BD7RS that i also run in usgt class. I put a arrow maxx chassis on it to make it stiffer and am very impressed with how it works!
TEAM GENESIS R/C, Roche P12 2016, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 01-14-2015, 04:57 PM   #5265
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Hi Guys, on my BD7 2015 the front stearing end bell seems to have a little play in it, it almost "tweaks" when the servo turns full lock left and right. It sort of rocks rocks, I've tried shims etc to try hold it in place more but it still rocks slightly. I end up with almost a degree of toe in our out based on this play when the car is sitting on my setup station. Is this an issue of over tightening or has someone else experienced the same?
svndayNZ is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
