Old 01-13-2015, 06:54 AM   #5236
b20btec's Avatar
Originally Posted by EDWARD2003 View Post
Besides the standard Pink/Blue carpet setup. Is anyone using Blue/Blue with any great effect?
I usually run blue/blue 388-425 cst on our indoor carpet track when traction is high. With a little more droop all around it seems to settle the car in mid way through the turn, the only thing that did slightly suffer was going through the chicane. When traction is normal (medium) pink or yellow/ blue works just fine.
This Thursday i'm going to run a setup with aeration short shocks without FMC. I've been running a 15 on short shocks (without aeration) and FMC and I thought it was pretty good, but then I had an mechanical issue so I had to put my other 15 on the track. This particular setup was with standard shocks no FMC and it ran a couple tenths faster consistently on carpet.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 01-13-2015, 06:58 AM   #5237
b20btec's Avatar
Originally Posted by Lonestar View Post
What servo arm do you guys run? Long or short?
Thanks!
Paul
Once in awhile on tracks that could potentially blow my servo gears up I would use the Xray servo saver. Majority of the time yokomo B7-204-SK servo arm (fits sanwa and ko propo).
Soap
Old 01-13-2015, 07:06 AM   #5238
corally's Avatar
Hello
someone have experience to use BD7 '14 chassis on BD7 '13 ? about handling is better or worst?...
corally is offline   Reply With Quote
Old 01-13-2015, 11:01 AM   #5239
Fjeld's Avatar
Blue/blue is awesome saw Ronald also used for DHI
Fjeld is offline   Reply With Quote
Old 01-14-2015, 02:36 AM   #5240
Lonestar's Avatar
Thanks - sorry if my Q wasn't clear. On the plastic tree sold with the car, there are two lengths of arms... 17mm and 20mm (For all 3 spline stds, 23/24/25). They both will have obviously different characteristics on the steering response, if only because of their size (but not only - the geometry of the command to the steering link is different too, then).
Good idea on the xray SS i must say... either because of track, or driver
Thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-14-2015, 06:25 AM   #5241
b20btec's Avatar
Thanks!
Paul
Use the taller one if you require more steering throw.
Soap
Old 01-14-2015, 08:03 AM   #5242
unwritten's Avatar
Default BD7 2014 Aluminum Chassis
does anyone use the Yokomo aluminum chassis on their 2014? especially on low to medium carpet track.
unwritten is offline   Reply With Quote
Old 01-14-2015, 08:09 AM   #5243
Lonestar's Avatar
thanks for your input - it isn't really the level of info I expected, to be honest
anyone else?
Paul
Old 01-14-2015, 08:30 AM   #5244
niznai's Avatar
anyone else?
Paul
Dude, the geometry of the command to the steering link bears no effect on the steering response (whatever the characteristics you talk about are - I have no idea apart from speed and arc/travel per servo throw, neither of which is affected by anything other than servo speed/setting and horn size). That is the whole point of the steering link. Doesn't matter what you control it with, you can use rods, cables, gears, heck, use Panda bears if you want.
Good luck.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-14-2015, 09:14 AM   #5245
Lonestar's Avatar
Well - the angle of the steering link is what makes the "interesting" difference, the steering angle as a function of the servo input will be different with different servo arms and I'm not just talking longer arm => more throw. It's funny how people love to talk about 0.5mm of shim here and a quarter degree of camber there but oversee that one! Simple geometrics, really, dude
Old 01-14-2015, 09:33 AM   #5246
What I've found is that it "mellows" the steering response when you use the short one vs the long one. That is, of course when all end points have been readjusted to be the same. Not by much, and it may very well be just my imagination, but that's what I found.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 01-14-2015, 09:47 AM   #5247
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Those are the exact conditions at our track
My 14' is setup for indoors only, and it is very easy to drive with the Yokomo alu chassis
I highly recommend it
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-14-2015, 10:50 AM   #5248
Fjeld's Avatar
I think it is ment for high grip, removing traction roll. Volker did use it at DHI, but Prumper did not.
Old 01-14-2015, 10:57 AM   #5249
Care to share your setup or one that's relatively close to yours?
Robbob is offline   Reply With Quote
Old 01-14-2015, 11:12 AM   #5250
Trader Rating: 15 (100%+)
Where have you seen setup sheets from DHI? Just curious - would like to check them out.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
