Like Tree5Likes
Old 01-12-2015, 02:01 AM   #5221
Originally Posted by niznai View Post
But you needn't buy those. You can use 5mm dia shims. The idea is that the hex should push against the inner bearing race rather than who knows against what or worse, against the shield. Of course, the bearings need to have a spacers between them, again pushing against the inner race. That way, you know you're not going to crush anything no matter what and even in case of impact you might be able to save the bearings (the outer bearing might suffer though given its inner race takes the hit and the outer race is fixed against the knuckle)
Ah, so the 5mm shims that TRF cars call for is useful for more than just taking out tamiya slop
cplus is offline   Reply With Quote
Old 01-12-2015, 03:52 AM   #5222
EDWARD2003's Avatar
+1
EDWARD2003 is offline   Reply With Quote
Old 01-12-2015, 04:29 AM   #5223
Default BD7-2015 Alloy Rear Driveshafts ?
Hi,
I know you can get the alloy rear dog bone but is there a complete Alloy Rear Driveshaft available ?
Yokomo BD7 2015 (x2); Futaba 4PKR-S; LRP Flow; Teamwave Motors; Savox servos;
http://demonpowerproducts.co.uk/
mcdoogle is offline   Reply With Quote
Old 01-12-2015, 06:28 AM   #5224
Lonestar's Avatar
Both.
What I found on all cars (Xray, Tamiya, Yokomo) is that proper gear diff mesh is best achieved when the back of the gears is sanded and shims are used. This is perhaps due to inconsistencies in housing molds or whatnot. Butter smooth may not mean anything though. The gears have rather coarse teeth so profile is crucial. Material used is also important and for my money, the xray plastic is the best here. Metal gears are pointless and heavy (perhaps more durable, but short of running stupid motors in mod, I don't think they bring any advantage over the increase in rotating mass they come with). Then again, running stupid motors in mod is not making the situation any better if the rotating mass is high. On the contrary.
thanks - thanks also to the person who answered my Q on double o-rings (lost your name now)
paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-12-2015, 06:36 AM   #5225
Lonestar's Avatar
Originally Posted by EDWARD2003 View Post
In Japan they run 13.5 boosted and was my first time running this setup. I felt really confident with this car and it's setup on carpet. I was driving it as hard as I could, getting it as close as I can to the board and dots. I think with a little tire prep it should be a contender with the rest of the guys at the track.
https://m.youtube.com/watch?v=q6WOwUwUp6k
Nice, clean driving Care to share your ratio and speedo setup? I run 13.5 boosted too and I'm struggling with finding the sweet spot... thanks!
Old 01-12-2015, 07:03 AM   #5226
EDWARD2003's Avatar
6.105 ~ 5.800 is the final ratio. Speed control is a Speed Passion Pro 1.1. I just use the StockHybrid mode. I don't know the timing settings. Motor is a G-Force Sonic with 40 degrees of timing on the can.
Old 01-12-2015, 07:26 AM   #5227
niznai's Avatar
Originally Posted by mcdoogle View Post
Hi,
Why would you want that? Aluminium would go totally wacko if you took the slightest hit in the wheel not to mention what the steel pin would do to the alloy axle.
There is another option though for a lightweight (rear) driveshaft. If you find one of the (old) Tamiya Titanium axles, you can use that with an alloy bone.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-12-2015, 07:26 AM   #5228
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default SCRCSS
We have a fun new series in SoCal, consisting of:
Realistic GT bodies
17.5 blinky motor
Open tire, spoke wheels only
1, 3m qualifier, 5 fastest consecutive laps for grid
3-10m mains, with a pitstop
Posting here to encourage others around the globe to try this new format
It's very fun
+ YouTube Video
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-12-2015, 01:25 PM   #5229
Gearing depends on the motor and track.
I normally use a 12.3mm rotor for 13.5T boosted and most of the time gearing will be around 6.8:1 to 7.5:1.
Start with low can timing real timing of 15-20 deg, esc 35 deg of boost and 15 deg of turbo once the rpm points are roughly current you can add a little extra timing.
DamianW is offline   Reply With Quote
Old 01-12-2015, 05:56 PM   #5230
EDWARD2003's Avatar
Anyone using the short arm conversion? What are you findings?
Old 01-12-2015, 07:03 PM   #5231
evochick's Avatar
I have them but still in packets
Looking forward to trying them on our higher grip tarmac track next week when we return to club racing (ok where we are racing at the moment is high grip but they have chosen the wrong control tyre IMHO (Ride 36 Blue))
UnRetired
evochick is offline   Reply With Quote
Old 01-12-2015, 07:53 PM   #5232
I'll try it this weekend. Will see what gives.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 01-12-2015, 08:05 PM   #5233
EDWARD2003's Avatar
Besides the standard Pink/Blue carpet setup. Is anyone using Blue/Blue with any great effect?
Old 01-13-2015, 05:03 AM   #5234
Lonestar's Avatar
thanks - long-ish ratio in my books but then again 40deg hard timing, sooo... cheers!
Old 01-13-2015, 05:05 AM   #5235
Lonestar's Avatar
What servo arm do you guys run? Long or short?
Thanks!
Paul
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
