Old 12-22-2014, 03:41 PM   #5161
The travel of the spring when measuring it is absolutely the most critical item to the spring test. The spring tester that "Redbull" has shown in his post I built just for comparing springs to make it as perfect pairs as possible. What my son Kyle, myself and a handful of freinds have learned about RC springs is amazing in the last week since I built the tester. This was definitley not a cheap venture at all to build. The GForce tester for the money is probably a very good tool, but being consisitent on how you test will determine what you learn. With my instrument I can get precise measurement on spring free height which is needed to know first to match consisitent springs. Then in my initial test I used 1mm increments to measure and took those readings. Not all springs are equal there are some better than others that's for sure. Like "Redbull" has stated knowing where your spring is starting under compression and to how far it is traveling is important to know when doing the test.
Phil Goodwine
Phil Goodwine is offline   Reply With Quote
Old 12-22-2014, 08:11 PM   #5162
cyba888's Avatar
Originally Posted by Jochim_18 View Post
Anymore update why Naoto Matsakura living yokomo?
no one really knows... my guess is that he probably asked for more money after winning the worlds and was declined. Since his contract will end this year someone offered him more money
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 12-22-2014, 08:13 PM   #5163
BardSmith's Avatar
Trader Rating: 58 (98%+)
Default BD7 2015 FS
Hey everyone, I'm going to post my BD7 2015 on the national thread but I thought I'd check here first to see who might want the opportunity to pop for it. PM me.
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 12-24-2014, 06:23 PM   #5164
fpart's Avatar
Trader Rating: 38 (100%+)
Send a message via Skype™ to fpart
Has anyone tried the short arms yet on carpet? Is it a lot of difference?
fpart is offline   Reply With Quote
Old 12-25-2014, 10:51 AM   #5165
reg
Originally Posted by policeman0077 View Post
And do not use tekin motor. There is no chamfer on the side, so the upper deck would block the motor.
Sent from my iPhone using Tapatalk
Hi, I notice your running the X20,what brand pinion are you running,I'm finding if I put the RW pinion on the way you have yours,and how it should be,the grub screw won't hit the flat spot on the motor shaft if I line it up with the spur,if I turn the pinion round so it lines up with the spur,the grub screw is only half on the shaft,not good!
reg is offline   Reply With Quote
Old 12-25-2014, 04:15 PM   #5166
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
You want to use Panaracer brand pinions they fit perfect on the shaft and line up centered on the spur
Racing4Evo is offline   Reply With Quote
Old 12-25-2014, 08:44 PM   #5167
mac853's Avatar
Could anybody suggest me what kind of option parts should use on BD7 2015 in case of TITC track of this year, RC addict?
I think the only option main parts should use is short arm conversion kit.
About using FMC, i am still doubted.
X brace shoule be removed, i think.
Best regards
mac853 is offline   Reply With Quote
Old 12-26-2014, 12:07 AM   #5168
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default bd7
well i got a 2013 that was updated to a 2014(only the chassis and motor mount he said).i traded my 417 for it thanks dan.now lets see what happens this sat. at the so cal race held at tq raceway plan on running it as a gt 10 car.
coyote hobbies raceway,tq raceway,kenon hobby.apex speed shop
futaba 4px,hobbywing,schuur speed,associated b6 b5m t5m sc5m,mini z,ta05 v2,some rock crawlers,and still counting....
slowpoke68 is offline   Reply With Quote
Old 12-26-2014, 08:18 AM   #5169
EDWARD2003's Avatar
For those who are running the BD series and wanting to get the most out of their chassis setup. Check out RC Crew Chief and the amazing product review.
http://www.thercracer.com/2014/12/rc...eview.html?m=0
EDWARD2003 is offline   Reply With Quote
Old 12-26-2014, 10:17 AM   #5170
reg
Thanks buddy they look perfect
Just Puting my Roche Edition together,bloody nice I have to say,
I was surprised how tight the drive train was though,I just had the diffs and belts down,so I rigged up the motor and just let it run slow for a couple of hours,it's all jolly nice now ,Iv put a then shim to stop the piston moving,drilled a 1mm hole in the shock top and gone for the black bladder and double blue o ring.now I just need a good starting setup for a technical med/high grip carpet track
Old 12-27-2014, 03:33 AM   #5171
Want to buy yokomo yrf2
erick13 is offline   Reply With Quote
Old 12-28-2014, 05:08 AM   #5172
reg
Hi,those that have the Rochie Edition,how have you fitted the arial in the floating servo mont,could you post a pic please.
Old 01-04-2015, 05:14 AM   #5173
EDWARD2003's Avatar
TN racing plexiglass chassis tweak plate and stand.
Old 01-04-2015, 05:41 AM   #5174
choisan's Avatar
can someone please suggest what other brands produce quality alternate double joint universal axles? thanks
choisan is offline   Reply With Quote
Old 01-04-2015, 06:37 AM   #5175
2-Bad's Avatar
Trader Rating: 24 (100%+)
Roche - Radtec
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
MDawson
SEO by vBSEO 3.5.0
