Like Tree6Likes
Old 12-18-2014, 07:20 AM   #5131
Originally Posted by MrSaab View Post
Does anyone know if the new(2015) alu chassisplate would fit the BD7'14?
Will not fit, bulkhead screws are in different locations.
Smartypants is offline   Reply With Quote
Old 12-18-2014, 12:55 PM   #5132
b20btec's Avatar
Originally Posted by RC MARKET View Post
Yokomo New Option Parts
You guys get the 2015 aluminum chassis yet?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 12-18-2014, 01:06 PM   #5133
G4ZZ4's Avatar
Will this fit on bd7 14?
G4ZZ4 is offline   Reply With Quote
Old 12-18-2014, 03:59 PM   #5134
evochick's Avatar
yes the shorter arms and mounts and bearing sets will fit a 14 no problem.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 12-18-2014, 08:28 PM   #5135
G4ZZ4's Avatar
Thank you
Old 12-19-2014, 01:54 AM   #5136
Lonestar's Avatar
Hi guys
I have yet to start building mine (offroad races then sickness) and at the moment I'm compiling some info and setup sheets... There are a few things I'm not sure I understand:
- what's the "number of orings" spec in the setup sheets shock sections? It's either 1 or 2... are these outside downstop orings on shock shafts?
- I see some setup sheets mixing short and std front towers F and R... is this correct? What's the desired effect here?
- Generally speaking - can someone please school me on short vs normal shocks?
Thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-19-2014, 02:18 AM   #5137
Normal shocks are great in asphalt, for carpet you will see someones using shorts shocks, but mainly long for asphalts and low grip carpet.
The shocks are inside the shock, for the shaft, no for downstop.
The shocks came with 1 oring, but yoy can use 2 if you change the oring collar for another une smaller.
Regards
jimjav is offline   Reply With Quote
Old 12-19-2014, 02:19 AM   #5138
Default springs
do you find with the long springs the pink is softer than blue and yellow?
T2 SLOW is offline   Reply With Quote
Old 12-19-2014, 05:07 AM   #5139
Lonestar's Avatar
Old 12-19-2014, 07:26 AM   #5140
Jorge T's Avatar
has anyone tested to see if the '15 bulkhead caps fit the '14 lower bulkheads?
540 Tuning
RSD
Jorge T is offline   Reply With Quote
Old 12-19-2014, 08:16 AM   #5141
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Black: 6.0 x 1.4mm (1460L)
0.2429 Kgfmm
242.9 Gfmm
13.60 lbf
Blue: 5.75 x 1.4mm(14575L)
0.2486 Kgfmm
248.6 Gfmm
13.92 lbf
Yellow: 5.5 x 1.4mm (1455L)
0.2629 Kgfmm
262.9 Gfmm
14.72 lbf
Purple: 6.75 x 1.5mm (15675)
0.2629 Kgfmm
262.9 Gfmm
14.72 lbf
Pink: 6.5 x 1.5mm(1565L)
0.2771 Kgfmm
277.1Gfmm
15.52 lbf
Green: 6.25 x 1.5mm (15625L)
0.2943 Kgfmm
294.3 Gfmm
16.48 lbf
Orange: 6.0 x 1.5mm(1560L)
0.3057 Kgfmm
305.7 Gfmm
17.12 lbf
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-19-2014, 09:47 AM   #5142
0.2429 Kgfmm
242.9 Gfmm
13.60 lbf
0.2486 Kgfmm
248.6 Gfmm
13.92 lbf
0.2629 Kgfmm
262.9 Gfmm
14.72 lbf
0.2629 Kgfmm
262.9 Gfmm
14.72 lbf
0.2771 Kgfmm
277.1Gfmm
15.52 lbf
0.2943 Kgfmm
294.3 Gfmm
16.48 lbf
0.3057 Kgfmm
305.7 Gfmm
17.12 lbf
yes i know the rates but if you compress one on top of the other the pink compresses first ?
Old 12-20-2014, 04:32 AM   #5143
niznai's Avatar
If you knew the rates, you should know which is softer.
The purple and yellow seem to have the same rate in the list above? Is that right?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-20-2014, 04:46 AM   #5144
what i am trying to say is i don't think the rates are right?
Old 12-20-2014, 05:39 AM   #5145
Yes I thought the same when you put the springs together the pink compresses first .so as far as I'm concerned the pink is softer than the blue even tho the pink is suppose to be harder
vwvrt is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
