Like Tree2Likes
Old 12-09-2014, 12:28 AM   #5086
mac853's Avatar
Just want ensure if kawada spurs fit bd7?
mac853 is offline   Reply With Quote
Old 12-09-2014, 02:14 AM   #5087
64p super ex definitely do.
cplus is offline   Reply With Quote
Old 12-09-2014, 09:24 AM   #5088
mac853's Avatar
I tried recently, it can fit with rc square spur screws but not sure with normal screws.
Old 12-10-2014, 04:19 AM   #5089
mick355's Avatar
Trader Rating: 14 (100%+)
Default '15 belts
Anyone else having dramas with the kit belts. Two weeks ago I snaped the front. Tonight the rear. Is there a better alternative available?
Running 6.5T in open
Mick
Yokomo BD7'2015 Bmax2MR Factory Edition
Tamiya M05
Bezerk RC Chassis, Hobbywing, Futaba
**BRCCC www.brccc.org**
mick355 is offline   Reply With Quote
Old 12-10-2014, 05:10 AM   #5090
mac853's Avatar
Mick
Maybe:
BD-189LB
BD-516LB
or team bomber TB20022 TB20023
Old 12-10-2014, 05:23 AM   #5091
Originally Posted by mac853 View Post
Maybe:
BD-189LB
BD-516LB
What is the difference between the kit BD-189L and the available BD-189LB?
atomic garden is offline   Reply With Quote
Old 12-10-2014, 06:38 AM   #5092
mac853's Avatar
They said is for stock, but i guess is low friction
Old 12-10-2014, 09:27 AM   #5093
Jochim_18's Avatar
Mick
I never had issue with mine running 4.5T... you need to soak the belt with WD40 to break them in this will make the belt soft and make sure your belt tension is not too tight.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-10-2014, 01:59 PM   #5094
Nearly 12 months of racing with 13.5T boosted, and 4.5T with the same belts.
The belts are very free and last.
How tight is your belt tension?
DamianW is offline   Reply With Quote
Old 12-10-2014, 02:14 PM   #5095
mick355's Avatar
Maybe just got a bit unlucky then. The track can be a bit dirty off line. May have just picked up a small stone
Tamiya M05
Old 12-10-2014, 04:00 PM   #5096
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Check your pulley's and belts every run for trapped debris
Not necessary on a clean track, but I check them often anyway
Same set of belts with mod TC for over a yr now, never treated them with anything but a handful of throttle
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-12-2014, 05:53 AM   #5097
Dear Mike - As Redbull... says, it is propably a dirt issue. The stock belts are very durable. I have mine on for a whole season with no problem. The white bomber although softer - hence make the car freer - tend to strip at the teeth. It all depends what you want out of the belts. Racing go with team bomber but would change them every 3 to 4 races, if not racing go with stock and keep them a bit loose but not too loose.
buzz777 is offline   Reply With Quote
Old 12-12-2014, 06:01 AM   #5098
Originally Posted by policeman0077 View Post
My oil diff starts leaking at drive cup? Any advice how to fix it? ??? (I new to a gear diff ;D)
There is a sequence to use when tightening screws:
- 1 o
3 o O o 4
- 2 o
If nothing is broken they should not leak. Double check everything.
Old 12-12-2014, 12:13 PM   #5099
b20btec's Avatar
It could've been his belt cams, it's possible that they weren't symmetric.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is online now   Reply With Quote
Old 12-12-2014, 03:41 PM   #5100
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
Where can I get a solid setup for asphalt on my BD7-2015. Running 17.5 non ramp.
Thx-John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
