Like Tree5Likes
Old 10-04-2012, 08:27 PM   #496
Nuno Gancho's Avatar
Shrink warp the joints will still came out.
Nuno Gancho is offline   Reply With Quote
Old 10-04-2012, 10:52 PM   #497
B00t13g's Avatar
I have real rw spurs ordered from speed tech and my screw heads barely clear the pulley. They are associated standard button head screws. I have has no issues with losing pins or anything on my t3 12 or my bd7 now that I shrink wrap the joints.
B00t13g is offline   Reply With Quote
Old 10-05-2012, 02:47 AM   #498
Originally Posted by Yokomo_Ant3 View Post
Ive never had an issue with the gasket, just replace it when it gets squashed a bit.
If anyone is having trouble building the shocks, get rid of the blue bladders, they are pretty much useless. Get the black ones and replace the bottom o-rings with the optional ones. You wont say anything bad bout the shocks again
What about the pistons I have a massive gap each side (over exaggerated) u have massive side to side play. I got the hg lower rings I'm ordering the black caps also the double o ring set, plus I built mine with the ti shaft set.
Jampot is offline   Reply With Quote
Old 10-05-2012, 03:34 AM   #499
Post a pic mate when u can. I'm sure ive not got ae screws but I honestly cannot see them being over .5 mm shorter which is required.
Is it the fact u ordered the spurs already that ur telling yourself they fit?
U can ask Speedtech to order the bd7 spurs from rw I have 2 hours and 10 mins for my delivery so within 3 I will know if any good.
These spurs are good for any 2.5 mm centered spur. TCX and TCXX although std rw fits
Old 10-05-2012, 05:30 PM   #500
B00t13g's Avatar
Lol yes I'm so worried about a $6 spur that I would lie and give out bad information. I currently have a panaracer spur on my car so no pictures sorry.
Old 10-05-2012, 06:37 PM   #501
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
I noticed this aswell and found it pretty strange, it means this car will generally need heavier shock oil. The shocks feel good after the option parts are installed
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-05-2012, 07:32 PM   #502
masterhit's Avatar
Trader Rating: 15 (100%+)
The pulley does rest against the 4 screw heads when using the Xenon and RW spur gears.
However, it does not cause any issues. You just leave off the extra shim included in the instruction supplement. In fact it makes you think this was their original intention hence the updated instructions (the instructions do show an interference fit with the screw heads). The Xenon Panaracer style gears are thick as well.
No extra wobble (perpendicular to the chassis) over the Panaracer set-up. I have loads of packs on mine and there are just slight marks from the screw heads.
*Shrug* To each their own! I will take the one less spacer to worry about personally.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 10-06-2012, 02:14 AM   #503
anyone notice their front spool gears are really wobbly when u apply power?
zzztech is offline   Reply With Quote
Old 10-06-2012, 06:28 AM   #504
NolanP's Avatar
So has anyone actually sat down set a lap time then using the same battery/motor/esc/tires/track/track temp. measured the lap speed difference between the stock plastic's and the graphite stuff?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-06-2012, 08:47 PM   #505
mikeygar's Avatar
Trader Rating: 14 (100%+)
curious too - have tons of leftover spares from my BD5's, mostly graphite so I'm curious if graphite has an advantage. In my BD5, it was always really edgy and aggressive, and I was very fast but inconsistent. Wonder if it has the same effect on the BD7...
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 10-06-2012, 09:34 PM   #506
B00t13g's Avatar
Volker layer it down this weekend at iic!
Rw 96t
Old 10-06-2012, 09:56 PM   #507
B00t13g's Avatar
Does anyone know how much weight I can save using the titanium turnbuckles and titanium screws? I need to lose 38+ grams of weight.
Old 10-06-2012, 10:00 PM   #508
Nico''s Avatar
On my BD5 I've looked that, is was only about 10 grams for the screws if I remember well
Nico' is offline   Reply With Quote
Old 10-06-2012, 10:14 PM   #509
B00t13g's Avatar
That's not bad. That would put me at about -30 if I remove the center 20g weight. I'm assuming the titanium turnbuckles would save me quite a bit.
Old 10-06-2012, 10:26 PM   #510
haywood's Avatar
Trader Rating: 48 (100%+)
Default Yokomo
I am at the IIC in Las Vegas and spoke with a very reliable source that mentioned A Main Hobbies will soon be the U.S. Distributor!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
