Old 11-30-2014, 05:41 PM   #5056
evochick's Avatar
Originally Posted by policeman0077 View Post
[IMG]
can I use robinson racing's 64p spur? seems I will lose 2 screws to secure the belt pulley, if I can mount it on belt pulley....
I have tried this a long time ago but they are too wide and they don't run true running just 2 holes
just stick with panaracer and leespeed,
Originally Posted by FLAT OUT View Post
Im running these driveshafts in my BD7 2015, I broke one of the pins in it today. Are these driveshafts the same as the Spec R items ??? I wondering If I can use a Spec R pin ????
I thought they are the same as Tamiya pins and clips (that's what the packet says anyway)
UnRetired
evochick is offline   Reply With Quote
Old 11-30-2014, 06:02 PM   #5057
I use one in my 2014 as it was the only spare spur I had when I stripped the stock spur.
I mounted it with 2 holes at first (ran fine) but later drilled 2 additional holes using the old spur as a guide. It has been in the car for months running 13.5T boosted and mod without issue.
DamianW is offline   Reply With Quote
Old 12-01-2014, 11:45 AM   #5058
policeman0077's Avatar
Thank you very much for all those one replied me.
Finally I mounted a Robinson Racing 81t spur on my BD7. It's a little thicker, but Tony helped me to make a sink hole on it. So I can use two flat head screws to mount the spur on drive pulley while not touching the pulley. ;D
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 12-02-2014, 03:33 AM   #5059
Lonestar's Avatar
Hey guys
just ordered my '15... first time running yokomo since the Mr4TC-SD SSG (which I still have...) after years driving xray. It was time for a change I guess
I already have the DCJ + servo mount on order but I was advised to also get the black shock bladders and blue shock seals... that's a bit cryptic for me, and as per my memories of the brand, the part refs are a pain to navigate through. Anyone has part numbers they could kindly share?
are we talking these?
seals: http://www.amain.com/yokomo-high-gra...blue-8/p242398
diaphragms: http://www.amain.com/yokomo-fluorine...-set-4/p242399
Additionnally - I'm old school and 48DP does it very well for me... anyone can recommend widely available (read: amain... or tower. I'm overseas) spurs that fit the Bd7 without coutersinking/redrilling/customization while still running tue? No japanese exotica please...
One more Q: why isn't the fancy rollbar mounting system used in the rear, but just the front?
Thanks in advance folks!
Paul
EDIT: looks like the P3's are the right ones!
EDIT2: yay - ditto for the black bladders
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-02-2014, 03:54 AM   #5060
Yes, you are right about those two parts.
For spurs, I am using arrowmax or serpent ones I use 64p, but they have 48p so you can use them for sure, you will need to remove the shim in the shaft as they are a bit more wide, but only removing the shim and everything is ok.
You can use the same system than in the front, but the cars feel better using the other system, it's more soft
cheers
jimjav is offline   Reply With Quote
Old 12-02-2014, 05:02 AM   #5061
Lonestar's Avatar
cheers
Thanks... serpent it is then
if the old system is softer, then wouldn't going with the new system and a thinner ARB do the same trick?
Thank you!
Paul
Old 12-02-2014, 05:28 AM   #5062
No, it's not the same, maybe I wasn't precise, it is smoother.
Cheers
Old 12-02-2014, 07:46 AM   #5063
Lonestar's Avatar
Cheers
I guess I'm even more confused now
Old 12-02-2014, 02:26 PM   #5064
Mmmm car was really easier to drive and seems to work better.
And I think that in the front we use the other system due to lack of space
Old 12-04-2014, 08:15 PM   #5065
mac853's Avatar
Could anybody tell me if blue orings is really "free" use green slime?
About orange orings of diff, if they really need green slime, please?
Best regards
mac853 is offline   Reply With Quote
Old 12-05-2014, 12:53 AM   #5066
Blue o rings are very good, tbh I have not used green slime in years
Smartypants is offline   Reply With Quote
Old 12-05-2014, 10:32 AM   #5067
mac853's Avatar
Thanks.
How about diff's orings?
About carpet medium grip small track?
Could keep using normal version top deck, fmc is just for asphalt?
Really need use taper piston, x braces and 6 degree caster?
Best regards
Old 12-05-2014, 12:17 PM   #5068
My oil diff starts leaking at drive cup? Any advice how to fix it? ??? (I new to a gear diff ;D)
多情自古伤离别。更那堪、冷落清秋节。
Old 12-05-2014, 02:51 PM   #5069
jdm19turn's Avatar
Originally Posted by mac853 View Post
Thanks.
Best regards
I'm using the fmc on my car for carpet it works great I'm using green slime on my diff orings too no leaks the diff gets smoother after you break it in good
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 12-06-2014, 04:12 AM   #5070
Bar
Default Leaking Diff Issues!
If you are having diff leaking issues on the new car, read back over the last few pages, very helpful
Luke Burr
Bar is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
