Like Tree2Likes
Old 11-28-2014, 09:59 AM   #5041
Just finished. Going to test tomorrow!
Marten is offline   Reply With Quote
Old 11-28-2014, 01:54 PM   #5042
JR Race's Avatar
Exclamation
Looks good
How does the spur balance with no bulkhead on the other side?
Give it the JANDAL!!!
Adelaide RC Team Driver
www.adelaiderc.com.au
JR Race is offline   Reply With Quote
Old 11-28-2014, 02:00 PM   #5043
Originally Posted by JR Race View Post
Looks good
Balances quite nicely,runs very free and quiet.
Old 11-29-2014, 09:14 AM   #5044
Picking mine up tomorrow. I'll have a 13,14 and 15
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 11-29-2014, 07:45 PM   #5045
policeman0077's Avatar
My BD7 is the first generation and I find the motor mount post is kind of blocking the pinion. So if I am using a 64p 96t spur, what's the biggest spur I can use?
What is the smallest 64 spur I can find to use on BD7? Can I use kawada SM6476 Spur on BD7?
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 11-30-2014, 12:07 AM   #5046
caltek1's Avatar
Trader Rating: 33 (100%+)
What we did in the past was to dremel the motor mount post, so we could fit a bigger pinion. We could get down to 3.3 fdr and lower. You dremel the top and bottom of the post.
In 64 pitch for 13.5 blinky I was using a 86 tooth spur and either a 52 or 53 tooth pinion. Gives a fdr of 3.31,(52) or 3.25,(53).
Hope that helps.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 11-30-2014, 07:47 AM   #5047
Hope that helps.
Regards,
Calvin.
I don't want to dremel it.... But thank you very much anyway
多情自古伤离别。更那堪、冷落清秋节。
Old 11-30-2014, 07:54 AM   #5048
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
You could just pick up the newer part
I believe it was a running change
Both of my 13s came with the later edition part
Old vers
New vers
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-30-2014, 08:12 AM   #5049
niznai's Avatar
If 64 pitch is not a strict imperative, you can use 48p with a 63 or smaller spur and a spread of pinions to give ratios around 3.xxx (60/41 gives 3 exactly).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-30-2014, 08:33 AM   #5050
where can I order this part? And how much?
多情自古伤离别。更那堪、冷落清秋节。
Old 11-30-2014, 08:35 AM   #5051
what's the difference if I use 48p spur? less smooth? larger steps of adjustability?
多情自古伤离别。更那堪、冷落清秋节。
Old 11-30-2014, 08:38 AM   #5052
http://www.amain.com/robinson-racing...ear-81t/p30556
can I use robinson racing's 64p spur? seems I will lose 2 screws to secure the belt pulley, if I can mount it on belt pulley....
多情自古伤离别。更那堪、冷落清秋节。
Old 11-30-2014, 09:33 AM   #5053
niznai's Avatar
You can run a lower tooth count for both pinion and spur for the same final drive. That means smaller diameter hence pinions that fit with the motor mount you have. You didn't notice the difference in numbers?
Team Greasy Weasel
Old 11-30-2014, 01:02 PM   #5054
Jochim_18's Avatar
You can use it just counter sunk the hole.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-30-2014, 02:42 PM   #5055
Default Roche Front Double Joint Driveshafts
Im running these driveshafts in my BD7 2015, I broke one of the pins in it today. Are these driveshafts the same as the Spec R items ??? I wondering If I can use a Spec R pin ????
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
