Old 11-21-2014, 01:50 AM   #5011
jdm19turn's Avatar
Originally Posted by regets ama View Post
Two questions please:
- Hardman's Halloween classic set up for mod has small print (I can not make it out) on his front inner camber link shim setting?
- also, his front suspension blocks list 4.2/3.5 ?
if anyone could clarify that would be great.
if it's good enough for him, it's good enough for me.
His front shims are 2.5mm under the ball stud the rear shims are Alittle blurry not the front the rear shims are 1mm under the ball stud in case you got it mixed up and the 4.2 and 3.5 is referring to the toe blocks the kit comes with 3.5 in front on both front blocks the 4.2 is a optional block that adds arm sweep i hope this is what you wanted to know
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 11-21-2014, 07:49 AM   #5012
b20btec's Avatar
Tested the x brace front and rear on technical carpet track last night. I didn't run the fastest time, in fact slightly slower than a 14 that's setup for the track, around .2 - .3 per lap. I like the way the car feels with the brace and I believe it will be faster when I actually have time to properly dial the car in. The only setup change I wanted to do before the club racing night was over was try the FMC and it gave me more steering than I needed and the car was really nervous out of the corners.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 11-21-2014, 11:19 AM   #5013
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Looking for a setup for 17.5 blinky running sorex 28 on indoor carpet low-mid grip. Running the new BD7'15 car with Mazda speed 6 regular weight body.
bozzplayer is offline   Reply With Quote
Old 11-21-2014, 11:39 AM   #5014
b20btec's Avatar
Basic carpet setup for the 14 will work fine as a base, as long as you're not using fmc and x brace.
Soap
Old 11-21-2014, 12:07 PM   #5015
FMC = ??
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 11-21-2014, 12:13 PM   #5016
dawgmeat's Avatar
Originally Posted by FLAT OUT View Post
FMC = ??
Forward Mounted Conversion
dawgmeat is online now   Reply With Quote
Old 11-23-2014, 01:44 AM   #5017
Hi
Does the 14 gear diff fit in the 15? Don't feel like buying another diff for the front.
Has anyone driven an xray t4 15 and a bd7 14 or 15, what is the difference in driving style required to make the cars work? The bd7 always feels fast but you have to drive it carefully.
Marc
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 11-23-2014, 04:36 AM   #5018
RC MARKET's Avatar
you can buy bd7'15 diff case & O-ring to update you gear diff.
RC MARKET is offline   Reply With Quote
Old 11-23-2014, 08:46 AM   #5019
Trader Rating: 20 (100%+)
Default yokomo spares
I have a big list of parts that will for all the yokomo BD7'S. I will be making a list as most of it in new in package. Pm me if interested
Donny Banks is offline   Reply With Quote
Old 11-23-2014, 10:25 AM   #5020
Jochim_18's Avatar
What front bumper you guys use? Is P-dub still around?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-23-2014, 10:44 AM   #5021
bigcracing's Avatar
Trader Rating: 32 (100%+)
Can you pm me alist please thanks Chris please include prices
bigcracing is offline   Reply With Quote
Old 11-23-2014, 12:45 PM   #5022
Thanks for the info but are you then saying it doesn't fit?
Marc
Old 11-23-2014, 02:44 PM   #5023
RC MARKET's Avatar
Marc
need b7-503gh & b7-500gm with ok !
Old 11-23-2014, 03:07 PM   #5024
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Hi
Marc
Yes the diffs cross over between cars. 14 can be used in a 15 car.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-23-2014, 03:58 PM   #5025
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
