YOKOMO Touring Car BD-7
#4984
#4985
hello, i am looking into this car and have a few questions:
thank you!
- what is the difference between the B7-BBP14 Super-precision Bearing Set 2014-2015 and B7-BBC15 BD7-2015 Ceramic bearing set and which bearings are included in the kit?
- is the B7-BTCB Aluminum Belt Teansion Adjust Cam a usefull upgrade or just weight and bling?
- what material are the included turn buckles?
- what is the use of BD-010RW Rear Double Joint Universal Shaft i thought DJ was only useful for the front while turning?
- is BD-500GA Aluminum gear diff shaft an upgrade for the kit part or a spare?
- i see a lot of people advice this bladder: YS-8HD Fluorine Rubber Hyper Diaphragm what does this improve over the kit one?
thank you!
#4986
thank you!
thank you!
It comes with aluminum belt tentioner
Steel turnbuckle ti saves weight
Aluminum Gear diff post saves a little weight.
#4987
The standard shock bladder works fine in terms of performance but swells and makes rebuilding the shock difficult.
The black bladders last for ages, and make building shocks easier.
#4989
arrived
mine arrived today......
#4990
The 2013 to the 2014 was barely any different (I have both), whilst the 2015 theoretically has lower CG and differences in shocks (volume). If you already run a 2013 I am also interested to know though not sure you will be over the moon with a 2015. Would be very interested myself to find more input from real world owners of the black edition and 2015. I have decided to wait this one out for the moment and continue to run the black and 2013.
#4991
I have all 3. I also agree 13 and 14 not much difference. But with the 2015 I installed the front motor conversion and feel a big difference. Car has more grip and is more responsive.
The fastest guy at our local track also have all three cars and he feels 2015 is much better.
#4995
I have had all 3 and I can say I got faster with each car. I now have 2 15s with FMC and the cars are fast and very planted on carpet
