Old 11-05-2014, 10:48 PM   #4951
blackshark3's Avatar
Originally Posted by BardSmith View Post
Experimentation time!
Wonder whether the "ARS" mod is working good
blackshark3 is offline   Reply With Quote
Old 11-06-2014, 04:43 AM   #4952
Bar
Originally Posted by donnie_p View Post
I'm referring to top deck screws
There 2 additional screws in front and rear. One to the motor mount and one to the steering bridge. I removed the one connected to the motor mount
Hardly ever run the one in the steering bridge, never tried taking the one in the motor mount out, does it make much difference to the handling?
Luke Burr
Bar is offline   Reply With Quote
Old 11-06-2014, 05:14 AM   #4953
cyba888's Avatar
anyone tried yokomo motor?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 11-06-2014, 11:56 AM   #4954
Jochim_18's Avatar
On low to medium grip it does help a lot with traction because the car generate more side flex on the chassis.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-06-2014, 11:57 AM   #4955
Jochim_18's Avatar
My YOKOMO BD7 2015 arrived today... quick question does it come with the floating servo mount?
Old 11-06-2014, 12:21 PM   #4956
Trader Rating: 20 (100%+)
No floating servo mount
Donny Banks is offline   Reply With Quote
Old 11-06-2014, 12:50 PM   #4957
Jeff773's Avatar
So on medium to low traction tracks completely take out the steering bridge?
Hot Bodies Racing-Hpi Racing-REDS Racing-PM Hobby Craft
D815
D8T TTE
Pro5
Jeff773 is offline   Reply With Quote
Old 11-06-2014, 12:58 PM   #4958
Without!!! I think that I haven't used it yet. With high temps I use the motor mount screw, now in winter i remover it.
Cheers
jimjav is offline   Reply With Quote
Old 11-06-2014, 04:12 PM   #4959
Originally Posted by b20btec View Post
I have the Slf shorts on my 15, you must buy the option short towers for the 2015. I race mainly on carpet medium to high traction smooth surface so it suits me.
The tensioner is non adjustable, works in the higher rpm ranges to keep the belt tensioned.
Thanks for your info
Have you tried the shocks on asphalt? Do you think they'll work just fine?
donnie_p is offline   Reply With Quote
Old 11-06-2014, 04:14 PM   #4960
Originally Posted by Ivan Dickson View Post
Congrats on your success with a your new car.
Thanks Ivan
The car really rocks!
Old 11-06-2014, 04:23 PM   #4961
Originally Posted by Jeff773 View Post
Haha unfortunately for me I didn't know this information so I bought the LTCr when I bought the car. Thanks for your help.
From what I know, LTCR is good for asphalt not carpet
Old 11-06-2014, 04:32 PM   #4962
Yes indeed. With the one on steering bridge attach the car has good initial response and quick on chicanes. Combine with removed the one attach to motor mount the car feel somewhat forgiving and provide good traction even on somewhat low grip track
The combination will take away a bit of high speed corner but you'll get more stable at the rear for a change
Old 11-06-2014, 04:36 PM   #4963
I don't know for carpet but for asphalt I do the other way around, remove one on the motor mount and use one on the steering bridge
Old 11-06-2014, 04:38 PM   #4964
I only race on asphalt and I think the car got plenty of cornering speed and stability the way it is
Does Yokomo got ARS option?
Old 11-06-2014, 08:41 PM   #4965
b20btec's Avatar
I don't see why it wouldn't work on a not so bumpy asphalt track and technical. I have yet to try it because the asphalt tracks I race at are parking lots and bumpy. Take notice, the short shocks do come with spring holders that let the springs sit closer to the track surface. I also believe running a lot of droop is a factor with short shocks, the window is smaller compared to standard, thus the reason behind running the Slf shorts on a smoother surface with less droop.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
