Like Tree5Likes
Old 11-05-2014, 07:03 AM   #4936
grapejuice's Avatar
Trader Rating: 131 (100%+)
I run the xray servo saver when running carpet.
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 11-05-2014, 07:33 AM   #4937
b20btec's Avatar
I do too but only on tracks with boards. Only downside is that you can't run the yokomo front weights if you need too because the servo saver is rather large. Hands down on open tracks, the aluminum horn is king.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 11-05-2014, 09:24 AM   #4938
Jochim_18's Avatar
Servo saver sucks... aluminum horn just don't hit the boards lol
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-05-2014, 04:52 PM   #4939
Jeff773's Avatar
Originally Posted by dawgmeat View Post
Dudes are running 5k in the rear diff for 17.5 down in FL, this is for all cars
Is this on carpet tracks aswell? I just had a 3 day long event I raced in and the car felt a bit nervous. The fastest lap I did the whole weekend was a 12.6 and the fast guys were running like 11.7's. I even had the fastest guy there run my car and he could only pull 12.9's and also agreed the car felt nervous. I'm going to start by putting softer springs on but I thought heavier diff oil might be good aswell. If 5k is what everyone is running than I might try that.
Hot Bodies Racing-Hpi Racing-REDS Racing-PM Hobby Craft
D815
D8T TTE
Pro5
Jeff773 is offline   Reply With Quote
Old 11-05-2014, 04:55 PM   #4940
What is your complete setup on the car?
HEWITT is offline   Reply With Quote
Old 11-05-2014, 05:08 PM   #4941
Jeff773's Avatar
Everything is stock including oils, camber, toe, and ride height is 5 and just barely over 5 in the rear. The only thing I've played around with was the shock position in the towers. The car had excellent grip just didn't feel right on my conditions. The track I run on has 5 rolls of carpet so its pretty large and has medium traction on club nights.
D815
D8T TTE
Pro5
Old 11-05-2014, 05:09 PM   #4942
dawgmeat's Avatar
Outdoor bumpy med traction
dawgmeat is offline   Reply With Quote
Old 11-05-2014, 05:14 PM   #4943
evochick's Avatar
I would probably invest in some different toe block for the front of the car, as well as possibly some blue springs for the front of the car
and change to a harder diff oil,
there are a few new stock setups for carpet for the 2015, like
http://www.petitrc.com/reglages/yoko...cers20141102//
UnRetired
evochick is offline   Reply With Quote
Old 11-05-2014, 05:19 PM   #4944
Jeff773's Avatar
Ok thanks everyone for your help.
D815
D8T TTE
Pro5
Old 11-05-2014, 05:38 PM   #4945
Trader Rating: 24 (100%+)
What body are you running? The Mazdaspeed6 body calms the car down a lot compared to the LTCr body.
gocoogs is offline   Reply With Quote
Old 11-05-2014, 05:44 PM   #4946
arn671's Avatar
Trader Rating: 14 (100%+)
Default 2014 vs 2015
Has anyone run the 2014 and 2015? is there a noticeable diffeence between the 2 cars? for medium to high grip carpet what toe block combinations are people running? I know it's a driver dependent question but in general which are people using, I'm trying to avoid buying all the possible toe block combinations if possible. Thanks in advance.
arn671 is offline   Reply With Quote
Old 11-05-2014, 05:50 PM   #4947
Blue springs all round work well for me but without other setup adjustments they may make the car more nervous.
Are you using the lower ball studs on the upper inner links? I would suggest raising the rear roll center and using thicker diff oil, 3k would be a good place to start.
If the car still feels nervous mid corner increase the ackerman by reducing the shims on the bell crank. If the car feels nervous at initial turn in raise the front roll center.
frozenpod is offline   Reply With Quote
Old 11-05-2014, 06:28 PM   #4948
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Did you buy Donny BD7?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 11-05-2014, 07:17 PM   #4949
Jeff773's Avatar
Haha unfortunately for me I didn't know this information so I bought the LTCr when I bought the car. Thanks for your help.
D815
D8T TTE
Pro5
Old 11-05-2014, 09:36 PM   #4950
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
From my limited experience, 2015 is easier to drive at the edge but I only drove it on carpet.
Standard Toe blocks included work well everywhere with the standard arms. The other blocks you see in majority of setups are 44.2 FF block which adds arm sweep and 45.7 RR block which decreases rear toe to 2.5 deg. I think everyone has those in their parts box.
Racing4Evo is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
