Like Tree2Likes
Old 10-31-2014, 04:50 AM   #4891
b20btec's Avatar
Purchased some purple springs a few weeks ago and didn't notice this until I started building the 15. Anyone have any idea why the yellow spring is flipped or its a new yellow spring that I'm unaware of? Yellow and pink is flipped on the charts.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 10-31-2014, 05:17 AM   #4892
cyba888's Avatar
just test the springs with your fingers and see if the chart is correct.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 10-31-2014, 06:15 AM   #4893
b20btec's Avatar
The yellow spring is stiffer than pink. My question was pertaining to the chart being flipped and a new yellow or pink spring being introduced to go along with the added purple.
Soap
Old 10-31-2014, 07:22 AM   #4894
John.C's Avatar
Trader Rating: 36 (100%+)
Did you get the new spring chart (white paper) with your 2015 kit or with your purple springs?
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-31-2014, 08:20 AM   #4895
To me it looks like the paper is wrong... If you go on Yokomo's website, it looks like the Yellow spring is between Purple and Blue.
http://www.teamyokomo.com/partslist/...ys_15675l.html
Martin
rhodopsine is offline   Reply With Quote
Old 10-31-2014, 12:22 PM   #4896
b20btec's Avatar
It came with the purple springs.
Martin
Good catch. Glad to know, I was confused and thought maybe there's a new yellow and pink spring rate also.
Soap
Old 10-31-2014, 01:10 PM   #4897
Jochim_18's Avatar
Of guys ordered my BD7 2015 today I just can't pass it up with 10% and my discount I got a good deal. So my I need all the part # to make the shocks and different butter smooth.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-31-2014, 01:59 PM   #4898
b20btec's Avatar
The tialn coated shafts is a must in my book. I have setups with double Oring and me no likey. Some people swear by it so it's up to you.
I rarely have problems with my diffs and they're all smooth without me doing anything additional. Certified owner of many yokomo BD.
Double seal setup
Spacer BD-S2W
Oring YS-7HG
Soap
Old 10-31-2014, 03:49 PM   #4899
BardSmith's Avatar
Trader Rating: 59 (98%+)
Experimentation time!
YOKOMO Touring Car BD-7-1.jpg   YOKOMO Touring Car BD-7-2.jpg   YOKOMO Touring Car BD-7-3.jpg
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 10-31-2014, 04:38 PM   #4900
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
wow ..are you running the 4 deg caster block in the rear?
it make it really shorter wheel base .
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-31-2014, 04:48 PM   #4901
BardSmith's Avatar
Ya. Shimmed way back and shorter wheel base. Not by much though. About 2-3 mm. Its wider by about 1/2 mm each side.
"Bard"
On-Road Only!
Old 11-01-2014, 04:29 AM   #4902
Bar
I'm sure you probably already know this, you have a top deck screw missing !
Luke Burr
Bar is offline   Reply With Quote
Old 11-01-2014, 08:31 AM   #4903
Trader Rating: 20 (100%+)
Default experiment
Very interested to know how it works out. I have a lot of ARC cars at my track and the new kit has that setup and waiting for one of those to hit the track. The concept is nice. What parts did you use?
Donny Banks is offline   Reply With Quote
Old 11-01-2014, 09:55 AM   #4904
BardSmith's Avatar
The observation skills are strong in that one! ::using my best Darth Vader voice::
"Bard"
On-Road Only!
Old 11-01-2014, 10:01 AM   #4905
BardSmith's Avatar
Hey Donny, I've very interested to find out also, wednesday is next race day. I basically used the whole front end set up including the CVDs. I had to tap a hole in the front of the arms to sink a set screw in to accommodate anti-roll bars and added 16mm screw through the front suspension mount to hold the ball. Add a turn buckle and bingo...
"Bard"
On-Road Only!
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
