Like Tree5Likes
Old 10-28-2014, 07:23 PM   #4876
THX~Do you know if it has agents in the US?
Originally Posted by RedBullFiXX View Post
Just have a look at the Yokomo web site
Jusitick is offline   Reply With Quote
Old 10-28-2014, 07:33 PM   #4877
Trader Rating: 20 (100%+)
Just a main but if you order from the yokomo site. Mibosport you can have in 3 days.
Donny Banks is offline   Reply With Quote
Old 10-28-2014, 09:29 PM   #4878
mick355's Avatar
Trader Rating: 14 (100%+)
Originally Posted by evochick View Post
Dimensions are on the yokomo part list site
Outer Suspension Arm Pin (φ223mm) BD-009A
Front Inner Suspension Arm Pin (φ342mm) BD-009BF
Rear Inner Suspension Arm Pin (φ345mm) BD-009BR
Yokomo BD7'2015 Bmax2MR Factory Edition
Tamiya M05
Bezerk RC Chassis, Hobbywing, Futaba
**BRCCC www.brccc.org**
mick355 is offline   Reply With Quote
Old 10-28-2014, 11:50 PM   #4879
kiwidave72's Avatar
Send a message via MSN to kiwidave72
Default waiting
I've order mine, and should be here in two weeks....fingers crossed.
Yokomo YZ-4 / Speedpassion 17.5. / Hobbywing v3 ESC
Yokomo BD7 / Speedpassion 13.5 v3. / Hobbywing v3 ESC
kiwidave72 is offline   Reply With Quote
Old 10-29-2014, 11:24 AM   #4880
dawgmeat's Avatar
Editable Set-up sheet
http://www.petitrc.com/reglages/yoko...SetupSheet.pdf
dawgmeat is offline   Reply With Quote
Old 10-30-2014, 06:50 AM   #4881
Ho1aw's Avatar
I never run TC but i am planning to try this. I am looking at BD7 and read this thread. Since it is too many pages i can't read them all. I plan to have Hobbywing v10 +120A V3.1, what about the servo? any suggestions?Thanks!
Ho1aw is offline   Reply With Quote
Old 10-30-2014, 07:05 AM   #4882
Trader Rating: 23 (100%+)
What class will you be running? Savox 1251 is a cheap good low profile servo for its specs. Otherwise you have your usual futaba and sanwa.
I've just got myself a HIGHESTRC dlp670 which feels very smooth and direct
Zhangesh is offline   Reply With Quote
Old 10-30-2014, 08:39 AM   #4883
If you cant get the GOB, I would probably just use the kit ones with a slightly thinner oil. (or Kyosho with very thin oil)
I was curious and had to rebuild all my diffs anyway, so I rebuilt my 1K diff with the kit red seals, and while smooth and doesn't leak, felt about 1600-1800 in weight with 1k oil in it.
The smoothest diff out of the 4 was the new 15 diff with the GOB seals, closely followed by the old diff with GOB seals.
you will need 4 B7-BTCB
Thank you for your info. It really helps :-)
I'll try to use original diff gear set and see how it works
Next questions are:
1. Which shocks that come with the kit? I saw 2 types of shocks, the standard and short one and I like to have another set as spare
2. Which arms I should spare? I saw some with different number on it
What are those numbers refer to?
Thank you
donnie_p is offline   Reply With Quote
Old 10-30-2014, 09:28 AM   #4884
cyba888's Avatar
finally done
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 10-30-2014, 10:38 AM   #4885
beidle99's Avatar
For a servo I just picked up the Xpert low profile. I havn't raced with it yet, but it is quiet, smooth, and including the floating mount weighs in at 64g. I paid $70 for it at amain. Only downside i can see with it is its only rated to 6.6 volts.
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 10-30-2014, 12:23 PM   #4886
Originally Posted by cyba888 View Post
finally done
Seems to me you mounted the rear battery plate upside down.
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 10-30-2014, 01:32 PM   #4887
AL1983's Avatar
Are the 2014 and 2015 gear diff housings different?
If yes, if I buy the 2015 housing/case (B7-503GH) will I be able to convert my 2014 gear diffs to 2015's?
Thx anyone for replying!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 10-30-2014, 02:07 PM   #4888
Francis M.'s Avatar
I do think it is different since the new diff has channels for 0ring seals.
I think, the new diff will fit the 2014 bulkheads.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-30-2014, 09:04 PM   #4889
niznai's Avatar
Would be interesting to follow up on this. I understand the bulkhead holes in the main chassis have different spacing, but don't know if this means they're wider or just moved around a bit. Not that a little bit of shimming (or some machining of the diff casing) couldn't fix it.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 10-31-2014, 03:34 AM   #4890
cyba888's Avatar
thanks!
Futaba 4PX
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
