Old 10-28-2014, 06:05 AM   #4861
dawgmeat's Avatar
Manual http://teamyokomo.com/download/manua...5b_141003e.pdf
Exploded View http://teamyokomo.com/download/exp_v...b_exp_view.pdf
Blank Set-up Sheet http://teamyokomo.com/download/setup...rtc_bd715b.pdf
dawgmeat is offline   Reply With Quote
Old 10-28-2014, 09:48 AM   #4862
Jochim_18's Avatar
Originally Posted by pajenova View Post
'14 and '15 chassis doesn't line up, the distance between the bulkhead screws are different.
MJ
Thanks guys I just sold bunch of stuff yesterday so I'll be getting the BD7 2015
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-28-2014, 11:00 AM   #4863
Toma2525's Avatar
Default BD7 RS stock shock springs
anyone know what weight the stock shock springs are on the BD7RS? Just got it and am looking to set it up to my local track TQRC in Chino. i found a setup on Petit that calls for pink and blue Yokomo springs. any suggestions?
thanks
Yokomo BD7...TQRC Raceway Chino, CA
Toma2525 is offline   Reply With Quote
Old 10-28-2014, 11:03 AM   #4864
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
thanks
Stock are "Black" super soft, won't work to well at TQ I'm afraid
Blue front, Pink rear are the default BD7 springs
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-28-2014, 11:13 AM   #4865
Toma2525's Avatar
Super! Thanks for the info.
Old 10-28-2014, 11:26 AM   #4866
John.C's Avatar
Trader Rating: 36 (100%+)
Not sure what works well at TQ Raceway but the typical Yokomo TC spring setup for carpet is Pink fronts and Blue rears. I ran Blue springs front and rear at IIC which worked very well for me. You can pick up 2 sets of Blues, 1 set of Pinks, and 1 set of Yellows to deal with the various grip conditions and layouts at your local track.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-28-2014, 11:49 AM   #4867
Toma2525's Avatar
Ill give it a shot and see what happens. Thanks for info!
Old 10-28-2014, 01:46 PM   #4868
I raced my 2014 BD7 for the first time last weekend. I was impressed by how much speed it carries through the corners and to the sharpness of the steering. Adjusting it was also very easy as it reacts to every setup change. I knew instantly if what I had done worked or not. Very very impressed by the car so far.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 10-28-2014, 02:07 PM   #4869
Originally Posted by cyba888 View Post
Try rcmarket
Thanks for the info
donnie_p is offline   Reply With Quote
Old 10-28-2014, 02:13 PM   #4870
I finally got all options for my BD7 15 except for BD-500GOB
What other option that I could use in place of BD-500GOB?
If I would like to go for B7-BTCB, how many of those do I need to complete the car? Sorry for asking this question because my kit isn't arrive yet but I want to be ready when it does
Thanks for sharing
Old 10-28-2014, 03:11 PM   #4871
You can use the oring that comes with the diff and see if it leaks. (I am not sure which oring comes with the 2015 kit)
I have found the orange P5 orings to work best, which can be purchased under the kyosho brand from amain.
http://www.amain.com/Kyosho-Silicone...nge-10/p166437
frozenpod is offline   Reply With Quote
Old 10-28-2014, 03:19 PM   #4872
Thank you for your info. Ordered already
Old 10-28-2014, 04:30 PM   #4873
evochick's Avatar
Thanks for sharing
If you cant get the GOB, I would probably just use the kit ones with a slightly thinner oil. (or Kyosho with very thin oil)
I was curious and had to rebuild all my diffs anyway, so I rebuilt my 1K diff with the kit red seals, and while smooth and doesn't leak, felt about 1600-1800 in weight with 1k oil in it.
The smoothest diff out of the 4 was the new 15 diff with the GOB seals, closely followed by the old diff with GOB seals.
you will need 4 B7-BTCB
Originally Posted by mick355 View Post
So if i want to run two orings in the shocks which ones do i need to get Ys-7hg?
Do you need to run a different guide to fit it all in?
Mick
Yes you will need to run the thin guide BD-S2W with Ys-7hg orings.
UnRetired
evochick is offline   Reply With Quote
Old 10-28-2014, 05:18 PM   #4874
mick355's Avatar
Trader Rating: 14 (100%+)
Anyone got a kit apart that can measure the length of the hinge pins, or know what they are? I need to make up a set of spares.
Mick
Yokomo BD7'2015 Bmax2MR Factory Edition
Tamiya M05
Bezerk RC Chassis, Hobbywing, Futaba
**BRCCC www.brccc.org**
mick355 is offline   Reply With Quote
Old 10-28-2014, 06:05 PM   #4875
evochick's Avatar
Mick
Dimensions are on the yokomo part list site
Outer Suspension Arm Pin (φ2×23mm) BD-009A
Front Inner Suspension Arm Pin (φ3×42mm) BD-009BF
Rear Inner Suspension Arm Pin (φ3×45mm) BD-009BR
UnRetired
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
