Old 10-25-2014, 01:28 AM   #4831
Run my BD7 2015 yesterday the first time and it was really nice.
Before I drove my 2014 and then I changed to the new with almost the same setup and it was 1 tenth faster in the first turn. It has more corner speed with more steering.
Today I will try more.
My "basic" indoor setup for a small and technical track with a lot of grip:
Spring: Pink / Blue
450 MuchMore Oil, 10% rebound (2 orings and black bladder)
Second hole from the inside front and rear
Droop: 6mm / 4,5mm
4.2mm FF mount
HB Mazda MPS, LRP CPX tire and LRP Carpet 3 additive
0.5mm bump steer
0.5mm under the front and rear chamber link inside
1mm under the front and rear outside
0.5mm at the center link
walzjer is offline   Reply With Quote
Old 10-25-2014, 06:46 PM   #4832
Jeff773's Avatar
Does anyone know what spur gears are compatible with the yokomo bd7 2015? I'm looking to replace the stock 116t spur with something much smaller like a 96t spur and just was wondering if any other brand of spurs work because I can't get a yokomo one shipped to me before my next race. I race on a medium sized carpet track so the stock one is way too large. Thanks
Hot Bodies Racing-Hpi Racing-REDS Racing-PM Hobby Craft
D815
D8T TTE
Pro5
Jeff773 is offline   Reply With Quote
Old 10-25-2014, 07:01 PM   #4833
miller tyme's Avatar
I use Team Durango
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 10-25-2014, 07:04 PM   #4834
Jochim_18's Avatar
Spring: Pink / Blue
Droop: 6mm / 4,5mm
4.2mm FF mount
0.5mm bump steer
1 10th faster that's like nothing.. but I like the idea car has more steering and corner speed.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-26-2014, 12:24 AM   #4835
evochick's Avatar
I have attached my base setup, its not that radical.
Its for a slightly bumpy track so a little extra ride height,
The only things I have been changing for a medium grippy/smoother track is usually the diff oil and lower ride height.
Edit ooops : I don't run a shim under the front outer ball joint but I do run the slightly longer Associated ballstud part 31284, just for a little extra durability.
I don't have any old school HPI silvers so I usually stick with pink/pink as for me they work.
I have also uploaded a blank setup sheet as there isn't one on Yokomo's website yet.
Beth.
YOKOMO Touring Car BD-7-base-setup.jpg   YOKOMO Touring Car BD-7-setup-blank.jpg
UnRetired
evochick is offline   Reply With Quote
Old 10-26-2014, 12:37 AM   #4836
evochick's Avatar
Originally Posted by dawgmeat View Post
Could you post a pic of this please
I guess its not that silly a question if your just starting out and have never done this before
I usually use hudy droop blocks (with the shocks off)
First pic is with a typical droop gauge measuring to the lower arm.
Second pic is with the ruler measuring to the middle of the outer pin.
I only use leespeed or panaracer
Beth.
YOKOMO Touring Car BD-7-droop-small.jpg   YOKOMO Touring Car BD-7-ruler-small.jpg
UnRetired
Old 10-26-2014, 01:38 AM   #4837
mick355's Avatar
Trader Rating: 14 (100%+)
Thanks for sharing Beth.
Got mine out today with HPI silver front and blue rears and kit oils.
4.8 front droop and 4.4 rear. I would call it a low grip tight outdoor track.
13.5 boosted.
Beth, how so you find running so little droop in the front affects the handling?
Mick
Yokomo BD7'2015 Bmax2MR Factory Edition
Tamiya M05
Bezerk RC Chassis, Hobbywing, Futaba
**BRCCC www.brccc.org**
mick355 is offline   Reply With Quote
Old 10-26-2014, 01:44 AM   #4838
porsche928gs's Avatar
You can use the xray offset spur also.
porsche928gs is offline   Reply With Quote
Old 10-26-2014, 01:52 AM   #4839
mick355's Avatar
Your kidding. Just gave mine all away😡
Tamiya M05
Old 10-26-2014, 01:55 AM   #4840
That sux. They fit perfectly just use two screws to hold it on the pulley.
Old 10-26-2014, 01:57 AM   #4841
I use the xray 92 sometimes on very large tracks
Old 10-26-2014, 02:05 AM   #4842
evochick's Avatar
Mick
because I run the car that much rotation it helps take out some of the exit corner rotation when getting on the power.
UnRetired
Old 10-26-2014, 09:22 AM   #4843
dawgmeat's Avatar
Racing the car today wow it's has a lot of mechanical grip built into it for off power steering
dawgmeat is offline   Reply With Quote
Old 10-26-2014, 12:49 PM   #4844
At that track with times around 9.0 seconds its not nothing. I think on bigger tracks the gap between the two cars will increase.
Old 10-27-2014, 12:58 PM   #4845
Jochim_18's Avatar
Is the chassis on the 2015 line up with the 2014 bulkhead? Thinking of getting the the top/bottom deck, motor/battery mount to convert to 2015 spec.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
