Old 10-23-2014, 04:00 PM   #4816
Originally Posted by dawgmeat View Post
Anybody else experiencing tight movement between the shock end ball cup and shock end ball stud?
Mine were tight at first but became free after a couple of race days.
frozenpod is offline   Reply With Quote
Old 10-23-2014, 04:30 PM   #4817
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by frozenpod View Post
Hi Craig,
The 500GOB oring that arrived was black in colour and appeared to be neoprene. Whilst the 500GOB appear to be the same dimensions as the kyosho P5 oring it was not the same material. Worked fine at first but didn't last.
Kyosho P5s are orange in colour and I have not yet seen one effected by diff oil.
Sorry I thought GOB was the orange yokomo ones. They appear to be the same as p5, and I've had them swell and bind unfortunately. Its strange because they work perfectly in the Tamiya diff
CraigM is offline   Reply With Quote
Old 10-23-2014, 05:02 PM   #4818
Same oil?
I've never had the tamiya/kyosho ones swell - unless - you get brake cleaner near them! Then they increase in size dramatically. I've used VG and Muchmore oil - opposite ends of the spectrum.
A few weeks sitting around and they go back to normal size.
cplus is offline   Reply With Quote
Old 10-23-2014, 05:13 PM   #4819
evochick's Avatar
must be a Sydney thing
UnRetired
evochick is offline   Reply With Quote
Old 10-23-2014, 05:16 PM   #4820
Which oil have you used.
I used the kyosho P5s with Nova oil kyosho oil and xceed without any issues.
The black GOB was used with xceed only.
Old 10-23-2014, 07:35 PM   #4821
NR
NR's Avatar
Trader Rating: 52 (100%+)
Anyone know how many holes I can cut the body posts down by so they're not too long?
I thought I would ask before I mount them and check to save myself a bit of time
Cheers
Nathan
NR is offline   Reply With Quote
Old 10-24-2014, 12:23 AM   #4822
Les
Les's Avatar
Default Buy
Shocks came with the 1 clear o-ring and large black insert
Geez I was going to buy Yokomo but not so sure, bit worried !!!!!
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 10-24-2014, 12:27 AM   #4823
Don't worry it is a great car. Built to be super fast but with 1 shock oring the shocks are super free and smooth but requires frequent shock rebuilds.
For club racers the extra oring increases the life of the shock.
Old 10-24-2014, 01:30 PM   #4824
dawgmeat's Avatar
How do you measure droop to reflect the Yok set-up sheet
dawgmeat is online now   Reply With Quote
Old 10-24-2014, 02:49 PM   #4825
evochick's Avatar
The verdict. .. fast
Using the same setup us my 14 I set a pb in qualifying. And only 2 seconds off the state champ.. (TQ was a mod driver so he doesn't count)
The car carries more corner speed and puts the power down quicker. Overall just quicker.
No diff leak yet
Two thumbs up for me.
Beth.
UnRetired
Old 10-24-2014, 03:42 PM   #4826
evochick's Avatar
droop gauge to the bottom of the arm or ruler to the centre of the pin to the setup board,
UnRetired
Old 10-24-2014, 03:47 PM   #4827
dawgmeat's Avatar
No diff leak yet
Beth.
Could you post your set up please
Old 10-24-2014, 03:49 PM   #4828
dawgmeat's Avatar
Could you post a pic of this please
Old 10-24-2014, 07:07 PM   #4829
John.C's Avatar
Trader Rating: 36 (100%+)
Everyone measures droop differently, the most practical way is to measure droop over ride height. For example if you run 5mm ride height and you want 2mm of droop, you would adjust your down stop screw so that as you lift the chassis you can achieve 7mm of clearance before your wheels lift.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-25-2014, 12:55 AM   #4830
niznai's Avatar
That is not a way of measuring, but the effect achieved. Doesn't matter how you measure it, it's all the same. The only point I would make is that changing suspension things such as say adding anti squat (or adding/taking out shims under the suspension blocks) can throw off your droop measuring system (it's not going to be consistent with previous measuring under the arm) if you measure under the arm. I always measure to the axle centre because that is always going to be in the same position in relation to the wheel circumference no matter what else you change in the suspension.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
