Old 10-23-2014, 03:37 AM   #4801
1. It could be OK with an 7.5. I race in an 8th track and a mate is using in mod a 10.5T with lots of turbo and it's having good results. In my opinion with an 6.5T in most of the track people will be quicker than with a 4.5T , pinion?, it depends of the seetings of the speedo. And yes, you should cath a fan for the motor
2. Yes, but you will have some space issues to instal the receiver
3. Yokomo are very hard, I have stock of plastic parts and belts of every car that I've got
4. In summer you can skip it, in winter it's a must as long as warmers. One thing tha people don't have in mind is that the additive increase tire life.
5. If it is good tape it will be more than enough, maybe in some serius crashes you could have one problem, but the idea is not to crash!!!
regards
jimjav is offline   Reply With Quote
Old 10-23-2014, 07:21 AM   #4802
dawgmeat's Avatar
Anybody else experiencing tight movement between the shock end ball cup and shock end ball stud?
dawgmeat is offline   Reply With Quote
Old 10-23-2014, 07:24 AM   #4803
dawgmeat's Avatar
Almost done
Old 10-23-2014, 07:26 AM   #4804
dawgmeat's Avatar
Old 10-23-2014, 07:28 AM   #4805
I ordered the 15 edition already and it's on its way now
Is it really that much of problems building a perfect yokomo?
I think I need know before decided to go on building it or just sell it
donnie_p is offline   Reply With Quote
Old 10-23-2014, 07:31 AM   #4806
dawgmeat's Avatar
Old 10-23-2014, 07:42 AM   #4807
dawgmeat's Avatar
Old 10-23-2014, 08:33 AM   #4808
My 2014 went together easily. Manual it's japanesse style good but naybe not as good as xray ones. In my opinion build it and enjoy it.
Regards
Old 10-23-2014, 08:40 AM   #4809
Jochim_18's Avatar
Standard servo should be fine since the footprint of Tekin RS is fairly small. For FDR right around 6.5 -7.0 check motor temp since the track your running on is big... As for spare parts just stock some Arms, Hubs and specially belt. Belt take a lot of abuse on a big track.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-23-2014, 08:49 AM   #4810
John.C's Avatar
Trader Rating: 36 (100%+)
Yes, you'll need to polish the pivot balls for the shock end/cap. You're most likely experiencing binding in the rear anti roll bar mounts. You'll need to polish those as well. The upper camber and steering links were about the only things that didn't bind.
You'll need to upgrade the shock internal to build them correctly. I'm not sure if these upgrades are included in the 2015. You'll need to upgrade the o-rings on your gear diff. No matter what you do you'll find that they leak. You'll need to polish the ball ends (see above). You'll need to sand the plastic/CF reinforced arms/hubs/knuckles to prevent them from binding up. You may also need to grind down the steering bridge post and the motor mount to prevent the chassis from tweaking.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-23-2014, 08:53 AM   #4811
dawgmeat's Avatar
Shocks came with the 1 clear o-ring and large black insert
Old 10-23-2014, 08:58 AM   #4812
John.C's Avatar
You'll need the following.
YOK-BD-S2W
P3 O-Ring Coller(Thin)
YOK-YS-7HG
High Grade O-Ring (Oil-Free)
YOK-YS-8HD
Fluorine Rubber Hyper Diaphragm
Old 10-23-2014, 09:37 AM   #4813
dawgmeat's Avatar
YOK-BD-S2W
YOK-YS-7HG
YOK-YS-8HD
I have everything but the YOK-YS-8HD Fluorine Rubber Hyper Diaphragm, I used the blue O-rings instead of the large insert, the small insert w/the 2 O-rings was too tight for my liking
Old 10-23-2014, 03:50 PM   #4814
evochick's Avatar
No, but I use the B7-S8H ball studs.... I cant recommend these enough..
No, my 15 went together much better then my old 13/14 did......
It required much less or no shimming on everything.
As a minimum for a build I would buy
B7-S8H
YS-7HG
YS-8HD
BD-S2W
B7-203B (or Roche equivalent)
Roche CVD's
BD-500GOB (experiment for yourself you prefer these over the kit red or Kyosho)
everything else is just a nice to have depending on how much bling you want.
If you don't buy B7-BTCB you can just use 0.1 or 0.2mm shims on the bulk head caps to stop the bearings from being tight.
that's all I can think of for the min...
Its race day....
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 10-23-2014, 03:53 PM   #4815
Built 2 bd7 2014 and neither require sanding of the plastics.
The arms, c hubs knuckles and uprights are the best of the best, a perfect fit with just a touch of play.
Steering post and motor mount were perfect on my cars and I have never heard of anyone grinding them.
How did they create tweak on your car, were they miss manufactured?
frozenpod is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
