Old 10-20-2014, 01:30 PM   #4756
dawgmeat's Avatar
Originally Posted by blackshark3 View Post
I am building the 2015 and having a hard time ensuring the lower chassis is flat....I am using the front motor mount kit, and I found that once the front belt is mounted (with the front belt adjust cam on the middle) the lower chassis would wrap. I tried to place the whole chassis on a piece of marble, with the top deck and the front spool out so that no tension is exerted on the lower chassis plate. Then I mounted the top deck then put on the spool that would still wrap the lower chassis a little. Anyone here experience the same?
Your bulkhead are on backwards with the aluminum x cross installed
dawgmeat is offline   Reply With Quote
Old 10-20-2014, 03:01 PM   #4757
Jeff773's Avatar
Originally Posted by nolo148 View Post
What turn motor do you plan on running?
Sorry for the late reply I totally forgot I posted here. I'll be running a 17.5t motor in the stock class. I'm just newer to onroad so I still got to get other people opinions on gearing.
Hot Bodies Racing-Hpi Racing-REDS Racing-PM Hobby Craft
D815
D8T TTE
Pro5
Jeff773 is offline   Reply With Quote
Old 10-20-2014, 04:19 PM   #4758
nolo148's Avatar
Get a 96t spur for 17.5 stock and I would gear between 4.2 - 3.6 depending on track and driver. Get a fan for the motor too
Owen Ren
ll ORCA ll Pro-Spec ll
Overgeared Racing BOD (Facebook - Overgeared Racing)
nolo148 is offline   Reply With Quote
Old 10-20-2014, 06:26 PM   #4759
Jeff773's Avatar
Really that low pinion? I was running a 49t pinion with 96t spur on my t4 14
D815
D8T TTE
Pro5
Old 10-20-2014, 06:43 PM   #4760
EDWARD2003's Avatar
I'm looking to run a nice scaled GT1,GT2 ect styled body on my bd7. Any suggestions?
EDWARD2003 is offline   Reply With Quote
Old 10-20-2014, 07:41 PM   #4761
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Tamiya Subaru BR-Z. This one handles well if you don't want to run the NSX....
Racing4Evo is offline   Reply With Quote
Old 10-20-2014, 09:29 PM   #4762
blackshark3's Avatar
I checked again, I am using the right belts. Bag #4 is still intact. Come to think of it if I use the wrong belts the front would be way loose and the rear would be tight. This is not the case here as it seems that my front belt now is a bit tight.
I also checked the bulkheads and the cam marks are on the outside.
I loosen up the bulkheads, the motor mount, top deck without the the front and rear axles in place. No matter how carefully I fasten them the chassis would warp. Also the front I had to move the cams from the central position so that the belt tension is right. Still the chassis is wrapped, and I was mad.
What I finally did was to twist the whole thing the other way from the wrap. Curiously I found something slipped as I did no, and by chance after I twist it the wrap was fixed! I had a flat chassis! I then check the screws again and they were tight. Brute force finally did it for me
blackshark3 is offline   Reply With Quote
Old 10-20-2014, 10:10 PM   #4763
EDWARD2003's Avatar
I was thinking of the Tamiya 84236 1 / 10RC Opel Calibra Spare Body Set or Tamiya SP.1514 1 / 10RC BMW M3 SPORT EVO or [84137] Volvo 850BTCC.
Old 10-21-2014, 03:15 AM   #4764
Trader Rating: 20 (100%+)
Default im selling a yokomo bd7 2014
YOKOMO BD7 2014 Black Edition
Donny Banks is offline   Reply With Quote
Old 10-21-2014, 03:56 AM   #4765
evochick's Avatar
Made good progress on day 1 as well,
Only issue encountered was the Roche outdrives caused the spool to bind up a little, but no issues with the factory ones. Might have to get the alloy adjusters...
The Yokomo BD-189LB belts are very very smooth, it will be interesting to see if they have a shorter life span.
UnRetired
evochick is offline   Reply With Quote
Old 10-21-2014, 08:54 AM   #4766
John.C's Avatar
Trader Rating: 36 (100%+)
Has anyone successfully replaced the bearings in the steering bellcrank and center link? I was thinking about heating them up to get the bearings out.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 10-21-2014, 08:58 AM   #4767
SLOW 77's Avatar
Trader Rating: 24 (100%+)
I had to use a punch and hammer with it in my vise; they are in there really good! Good luck.
John Hodges
Yokomo BD7 - KOPropo EX-RR -Xray NT1 -Mooreway Motorsports
SLOW 77 is offline   Reply With Quote
Old 10-21-2014, 09:24 PM   #4768
cyba888's Avatar
almost done...just waiting for my yokomo esc to arrive
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 10-22-2014, 02:29 AM   #4769
Bar
What is the new diff like? I know someone who put it together without any sanding of the gears, said it was a bit tight, any feedback, is sanding still needed?
Luke Burr
Bar is offline   Reply With Quote
Old 10-22-2014, 03:49 AM   #4770
If the small parts off the new diff, is the same as the old one, then u need to use a 3 mm armreamer on the small gears. Then u will have a ultra smooth diff
RCmcDriver is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
