Old 10-15-2014, 08:39 PM   #4711
dawgmeat's Avatar
dawgmeat is offline   Reply With Quote
Old 10-15-2014, 09:32 PM   #4712
evochick's Avatar
Originally Posted by dawgmeat View Post
I'm calling it a night
SOFT !!!! sleep is over rated
how does the new diff feel ?
still waiting for mine to arrive (possibly tomorrow)
UnRetired
evochick is offline   Reply With Quote
Old 10-15-2014, 10:33 PM   #4713
Jochim_18's Avatar
Originally Posted by evochick View Post
guys the battery mount will not fit on a 14 chassis, unless you are willing to drill your own holes..
Arm part numbers are not out yet.
the part number for the battery bracket is B7-11815
all the part numbers are on yokomo's website.
I am not sure what you guys are whining about, yes the car only has incremental improvements, but I think they will be worth it.
For the record I am still keeping my 14 as my spare/VTA car because its a great car, but really looking forward to seeing what the 15 can do.
Beth.
It's not that hard to drill a hole in the chassis.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-16-2014, 12:34 AM   #4714
Beth.
By the looks of it the battery mount do fit the 14 chassic, since u need two holes in the back and one in the front of the battery. I think that it one of the main points to make new front weight blocks.
I agreed with u on the people are whinning a little to much, its starting to be more like the Xray theard. Aleast Yokomo make there own ideas, insted of borrowing others and optimze it
I have a friend who going to build a 15 really soon. I really looking forward to see the on the track
RCmcDriver is offline   Reply With Quote
Old 10-16-2014, 11:38 AM   #4715
dawgmeat's Avatar
Gear diff is as smooth as butter, Yok supplied #700 diff oil for gear diff and #400 for the shocks.
I had the same S411 for the past 3 yrs which was a good car but needed a little finessing with suspension parts/diff gear smoothness. I haven't started installing the suspension on the YOK yet "waiting on titanium screws /Teflon coated shock shaft", Everything went together flawlessly.
Old 10-16-2014, 01:43 PM   #4716
The BD7 2015 is available here with €60+ in the alu servo mount & the included Roche drive shafts.
Anyone taken it for a drive yet?
Thaan is offline   Reply With Quote
Old 10-16-2014, 02:20 PM   #4717
Mine will be here Tuesday. I will update you next weekend!
HEWITT is offline   Reply With Quote
Old 10-16-2014, 04:08 PM   #4718
evochick's Avatar
that's good to hear, ill probably install the GOB diff seals, I still don't trust the red ones.
I have the opposite problem, I have all the hopup parts here, just waiting for the car
UnRetired
Old 10-16-2014, 04:43 PM   #4719
dawgmeat's Avatar
I didn't check which o=rings are install due to the gear comes 80% assembled
Old 10-16-2014, 07:18 PM   #4720
b20btec's Avatar
In from mibosport yokomo Europe, highly recommend, fast shipping. To other American customers, did ups get you on brokerage fee?
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 10-16-2014, 08:00 PM   #4721
dawgmeat's Avatar
A note when building:
When installed the hinge pens are tight by design when installed in the front and rear a arms. Also hand fitting is required when installing the rear hub carriers and front caster blocks into the A arms. I was able to accomplish this by lightly sanding the cast the block and the rear hub carriers
Old 10-16-2014, 08:01 PM   #4722
dawgmeat's Avatar
Old 10-16-2014, 08:02 PM   #4723
dawgmeat's Avatar
Old 10-16-2014, 08:03 PM   #4724
dawgmeat's Avatar
Old 10-16-2014, 08:05 PM   #4725
dawgmeat's Avatar
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
