Like Tree6Likes
Old 10-02-2012, 07:37 PM   #451
B00t13g's Avatar
I love this car.
B00t13g is offline   Reply With Quote
Old 10-02-2012, 07:53 PM   #452
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Wow that car looks really nice. Wish they had a good distributor in the US
OnRDPassion is offline   Reply With Quote
Old 10-02-2012, 09:28 PM   #453
Danny-b23's Avatar
Originally Posted by B00t13g View Post
My spare pistons came in so I was finally able to drill them out to 1.1 except the closest drill bit I have measured 1.08 so it's not exact.
Keep in mind that the 1.08 drill bit will drill slightly over its size. Although in all honesty even with the small volumes of oil we're dealing with 0.02 is going to make little to no impact.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 10-02-2012, 09:54 PM   #454
B00t13g's Avatar
That was my thoughts. I also measured it with a cheap caliper.
Old 10-03-2012, 02:16 AM   #455
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
I love this car.
i would suggest to remove the middle bellcrack holder...and also use aluminium servo horn ..
remove the middle bellcrank holder will make the car more easy to drive...and the original plastik servo horn very easy to strip...
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-03-2012, 02:28 AM   #456
Hi,
how to lock the battery?
I avoid contact with the belt I put the center weight of 20g of BD5, is there any better way?
andrease is offline   Reply With Quote
Old 10-03-2012, 02:41 AM   #457
kschu's Avatar
Originally Posted by andrease View Post
Hi,
i think that is the best way....
Old 10-03-2012, 02:43 AM   #458
Stilo's Avatar
Hi,
I made similiar front&rear stoppers that the TRF guys use, so just a random servomounts and screws to adjust the gap. In the center I just use wheel weights and tape those in the correct spot.
Team EuroRC.com
Stilo is offline   Reply With Quote
Old 10-03-2012, 06:01 AM   #459
B00t13g's Avatar
Are you saying to remove the entire aluminum piece that goes on top of the steering bellcranks and attaches to the top deck, or just the screw from the top deck? Any recommendations on an aluminum horn?
Old 10-03-2012, 06:24 AM   #460
snoopyrc's Avatar
I love Yokomo products, but they are killing me on the price. Just can not justify getting near $700 on some of their drift kits. The BD5 was always out of my price range unless I go used.
I am trying to stay in supply on breakables for an old Yokomo MR4TC SD SSG. I think BD5/BD7 arms will fit. If thats the case then I should be able to use the new C hubs and Steering knuckles, rear hub carriers. I wonder what it would take to adapt that new bell crank.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-03-2012, 06:29 AM   #461
NolanP's Avatar
the original plastic servo horn very easy to strip...
Yeah mine jumped a tooth in the main when I was turning and got tapped.
I plan on switching to a servo saver for that reason though.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-03-2012, 07:07 AM   #462
Aaron_M's Avatar
I removed the whole piece and use M3 x 6mm button heads to hold the bellcrank arms / bearings in place.
Makes the car smoother and more consistent due to increased flex.
I havnt had any trouble with the stock servo arm myself yet.
Aaron_M is offline   Reply With Quote
Old 10-03-2012, 07:07 AM   #463
remove the entire aluminum piece!
Makes the car a lot easier to drive! Use some 5mm x 0,1mm shim on top of the bearings and use a 3x6mm screw for the steering posts! ;-)
As you can see on the picture below! ;-)
Philipp1990 is offline   Reply With Quote
Old 10-03-2012, 07:14 AM   #464
B00t13g's Avatar
Ill give it a shot. Any drawbacks?
Old 10-03-2012, 07:26 AM   #465
I am trying to stay in supply on breakables for an old Yokomo MR4TC SD SSG. I think BD5/BD7 arms will fit. If thats the case then I should be able to use the new C hubs and Steering knuckles, rear hub carriers. I wonder what it would take to adapt that new bell crank.[/QUOTE]
first version bd suspension parts will fit
wish i could find a good sd
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
