Like Tree6Likes
Old 09-30-2014, 01:27 AM   #4621
niznai's Avatar
I did something similar by buying a BD7RS and upgrading it to a 2014. Total cost under the price of a kit, with everything (including bulkheads, damper stays, dampers, motor mount, etc).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-30-2014, 02:08 AM   #4622
H4gI's Avatar
Sure?
hmm.. also arms etc. in graphite? thats new included in the 2015....
And there are some other parts you may need but isnt included in RS or 2015 like:
Rubber Hyper Diaphragm
High Grade O-Ring
P3 O Ring Coller (Thin)
Double Joint Drive Shafts
SLF short shocks
Team NFC
LRP
CAP
Nitro-mechanic-bitch of E.D. and R.V.
H4gI is offline   Reply With Quote
Old 09-30-2014, 03:08 AM   #4623
Jorge T's Avatar
This is my take on the 2015:
New diff case to fix the leaking diff, roll bar stopper w cosmetic change, x braces to help with flexi bulkheads on the 2 mm narrower chassis. New motor mount that don't break.
New lighter front spool, optimized shock angle on shock towers and the ability to move motor mount forward on the new chassis.
RSD
Jorge T is offline   Reply With Quote
Old 09-30-2014, 03:37 AM   #4624
niznai's Avatar
Originally Posted by H4gI View Post
Sure?
High Grade O-Ring
SLF short shocks
The plastic arms work fine (on my track they're actually the arm used by all Yok drivers), and you're buying those as spares anyway, so you can get whatever you like.
Same for C-hubs, etc.
Everything else (that doesn't come in the full blown kit) you would have to buy even if you get the kit, so where's the gain?
Yokomo got it wrong by not including the DCJ driveshafts in the kit. That's another 50$ to spend if you buy their kit which basically means you spend above the cost of an Xray/Tamiya kit to bring the BD7 on par. Plus DCJ compatible C-hubs (not that the kit ones can't be used).
And if you want another gear diff (for the front) you have another 50$ to spend.
Team Greasy Weasel
Old 09-30-2014, 03:54 AM   #4625
TB03Racer09's Avatar
The Xray T4 2015 does not have DCJ drive shafts in the kit either, the Tamiya TRF419 does. I don't understand why top of the range touring cars don't come with them as standard in the front of the car. After experiencing the smoothness, I don't think I can go back to normal CVD's anymore
TB03Racer09 is offline   Reply With Quote
Old 09-30-2014, 05:02 AM   #4626
H4gI's Avatar
Intressting..... i've never heard that before! So you're lucky guys enjoy racing!
Team NFC
LRP
CAP
Old 09-30-2014, 07:39 AM   #4627
b20btec's Avatar
Went ahead and pre ordered one from mibosport.
The new 2015 seems to come with aluminum front axles now. I ran standard and and DCJ on the 2014 and didn't notice that huge of a difference in times but car is smoother on power out of the apex.
The TRF kits comes with everything, tamiya doesn't nickle and dime you as bad as other brands Dcj, carbon bumper, floating servo, aluminum rear axle, ti coated shock shaft, 418 came with extra spares, great car on carpet.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 09-30-2014, 07:43 AM   #4628
fitforbattle's Avatar
I also don't get that we don't get (crucial) updates proven to be absolutely needed OOB this time either. Like DCJ's up front, or alu rears. The floating servo mount? Is it still an option with the '15? And why not gear diffs for both front and rear? A front gear diff can be made almost spool solid w/o the tear and ripping effect of the solid spool.
I guess the make the big bucks from the options and the spare parts. Nevertheless, I'm sticking with Yokomo, and I'll probably stick with my '13.
Yokomo BD7 / SpeedPassion Reventon Pro AJ Edition / LRP x12 Vector Octa-wind 5.5T / Futaba S9352HV / Gens Ace 5000mAh
fitforbattle is offline   Reply With Quote
Old 09-30-2014, 08:30 AM   #4629
Seriously, there is no floating servo mount! How is the servo attached then, in the photo, the outer side of the servo has the ears removed. I feel better that I'm getting the Tamiya now hahaha
Old 09-30-2014, 08:34 AM   #4630
S.Stew's Avatar
In the instructions for the '14 it has you use a plastic mount on the inside only and servo tape.
Looks like the floating mount is still an option.
- Steven Stewart -
S.Stew is offline   Reply With Quote
Old 09-30-2014, 08:53 AM   #4631
dawgmeat's Avatar
My pre order includes the Roche DCJ's. Are they any good?
dawgmeat is offline   Reply With Quote
Old 09-30-2014, 09:17 AM   #4632
niznai's Avatar
Given that you guys are in the US where I hear spec classes are the majority, you might want to run Tamiya DCJ which I can confirm fit the BD7. Mine is running them because I also changed to the Tamiya 37 pulleys to reduce the internal ratio (spec class bliny 13.5). I used the Tamiya spool shaft as well simply because I had one.
Team Greasy Weasel
Old 09-30-2014, 09:29 AM   #4633
S.Stew's Avatar
I've heard the Roche DCJ's work just fine. I've been using the Old style Yok DCJ's with no issue.
- Steven Stewart -
Old 09-30-2014, 09:39 AM   #4634
b20btec's Avatar
Old style yok dcj, new style yok dcj works fine. On my 14 I settled with the spec r p8 version, been really good for awhile now.
I didn't catch to see if the 15 was running short or standard slf shocks, can anyone confirm?
Soap
Old 09-30-2014, 09:55 AM   #4635
grapejuice's Avatar
Trader Rating: 133 (100%+)
I've been using them for a while now, definitely seem to be the strongest.
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
