Old 09-12-2014, 07:19 AM   #4516
dawgmeat's Avatar
Originally Posted by RedBullFiXX View Post
Rear arms are same length, only shock location is different with 39.5 option
Kit is 4* caster
So which one of these come with the kit?
http://www.amain.com/Yokomo-Lightwei...-405mm/p242128
http://www.amain.com/Yokomo-Lightwei...-415mm/p242130
http://www.amain.com/Yokomo-Rear-Sus...-395mm/p242253
dawgmeat is offline   Reply With Quote
Old 09-12-2014, 07:23 AM   #4517
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-12-2014, 07:24 AM   #4518
barnacle's Avatar
The last line of 395 states they are kit arms.
Mike Dobbs
Race Opt MTS T'2
WWW.DISCHARGERC.COM
U.S. DISTRIBUTOR FOR RACE OPT BRAND
barnacle is offline   Reply With Quote
Old 09-12-2014, 08:54 AM   #4519
dawgmeat's Avatar
Thanks, I'm ordering my BD7 2014 Black edition next week and just wanted to order the spare parts as well
Old 09-12-2014, 07:22 PM   #4520
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by antivert View Post
Not sure how you are balancing the weight of that Orion 7200 (my scales have that battery at 320g). I couldn't get the car to balance correctly. I choose to use the 6000's. Even the Orion 6000 is heavier than most lipos.
I have been playing around with the weight and figured it out. The battery holders are too heavy. I also had to add 1 oz of weight to the electronics side under reciever and fan and remove the battery stop and shift the battery closer to the center of the chassis without hitting the belts. i am gonna make another battery stop and battery holder out of carbon fiber. I will keep you posted. Also this is with a 330g battery
update!! I actually used the stock battery stop and shaved as much as I could to move the battery close to center without touching the belt.
car is now balancing. It would always fall to the battery side.
YOKOMO Touring Car BD-7-20140830_104400.jpg   YOKOMO Touring Car BD-7-20140913_093115_resized.jpg
stro3579 is offline   Reply With Quote
Old 09-13-2014, 08:01 AM   #4521
Is the car not too heavy now if your driving with an 330g battery and add 30g weight ?
Yokomo bd7 2014 Black Edition - Muchmore - Sanwa
broløs is offline   Reply With Quote
Old 09-13-2014, 08:10 AM   #4522
stro3579's Avatar
I run 17.5 blinky. Running 7600 and 7200 packs. They batteries are 330g.
Old 09-13-2014, 12:08 PM   #4523
Okay. There should be the same power in 6000 batterys its 17,5t it will not need so much amp
Old 09-13-2014, 06:32 PM   #4524
stro3579's Avatar
Yea that is the down fall for larger mah packs. More weight.
Old 09-13-2014, 06:41 PM   #4525
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
higher turn motor should need higher C value lipo
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-14-2014, 09:07 AM   #4526
John.C's Avatar
Trader Rating: 36 (100%+)
Your battery weighs 330g and you’ve added approximately 30g in weight. How much does your car weigh in race ready trim? I have the aluminum chassis, short shocks, ti turnbuckles, ti screws, ti layshaft, 300g battery pack, 20g lead weight on electronics side, low profile Sanwa SRG-BL servo, plastic battery stops, and Protoform Mazda Speed lt wt body and I’m right at the 1380g weight limit.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 09-14-2014, 10:51 AM   #4527
stro3579's Avatar
Haven't weighed it yet. Feels heavy as Sh@t though. I have no choice with the batts I have.
Old 09-14-2014, 08:54 PM   #4528
evochick's Avatar
Take the battery holders out, they don't really do anything,
I haven't lost a battery or had one move since I removed them, the balance of the car was better.
UnRetired
evochick is offline   Reply With Quote
Old 09-15-2014, 08:12 AM   #4529
dawgmeat's Avatar
What best recommend spur gear for the BD7 2014?
Old 09-15-2014, 09:00 AM   #4530
John.C's Avatar
I'm using the Leespeed Spur gears that I purchased at Team EA Motorsports. They've been great in 17.5 blinky TC, I'm sure they are up to the task for Super Stock and modified racing. Another popular option is Panaracer Spur gear.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
