Like Tree6Likes
Old 09-07-2014, 08:03 PM   #4501
Default Dogbone length
Originally Posted by svndayNZ View Post
A quick question, I recently bought my first ever yokomo (after owning Associateds, Tamiyas and Serpents over the years) and can honestly say I'm an official convert and won't be going back.
I built my 14 Black Series on the weekend, and the rear end doesn't seem right, I have the camber links built to the suggested length of 50.5 mm but it fits so snug that the rear drive shafts are pushing heavily into the rear out drives. The rear belt is sitting snug not too loose or tight. The rear arms don't move up and down freely because the out drives and diff are effecting being "pinned" by the drive shafts.
Has anyone else experienced this and if so how is it fixed?
Cheers
Maybe you can check whether the right dogbone length is used. Yokomo front dogbone length is 46mm and the rear is 44mm. I did that mistake when i was building mine.
Rgds
thesaint is offline   Reply With Quote
Old 09-07-2014, 08:24 PM   #4502
hanzo3's Avatar
Trader Rating: 55 (100%+)
What do 1.1 3 hole pistons do and how do they compare to stock 1?
hanzo3 is offline   Reply With Quote
Old 09-07-2014, 08:42 PM   #4503
1.1mm is stock with the 14 kit.
1.1mm has less high speed dampening (pack) compared with the 1.0mm pistons.
frozenpod is offline   Reply With Quote
Old 09-08-2014, 06:05 AM   #4504
stro3579's Avatar
Trader Rating: 20 (100%+)
Cheers
Make sure you have the upper n lower bulkheads in the right place. Post a picture of the rear of the car
stro3579 is offline   Reply With Quote
Old 09-08-2014, 07:04 AM   #4505
beidle99's Avatar
My BD-7 will be arriving today I will be running 17.5 Blinky on carpet with a Tekin RS gen 1 and D4 "MAXZILLA" motor. I got my gearing somewhat sorted out for the track I will be running at (FDR 3.6 to 4.0). My question is what is a good range of motor timing to set and what C rating and Mah should I be looking for in my batteries? I was thinking something around 70C and 6000mah, but not sure. I am a club racer, doing indoor carpet to keep a TX in my hand this winter.
I haven't run touring or carpet since the Corally RDX first came out
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 09-08-2014, 07:44 AM   #4506
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Aluminium battery holder from Radtec
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-08-2014, 03:47 PM   #4507
Potoczak's Avatar
Trader Rating: 111 (100%+)
If anyone is looking for a 2014 black edition
FOR SALE 2014 Yokomo bd7 black editon Band new
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-09-2014, 04:05 AM   #4508
svndayNZ's Avatar
Rgds
that was it. its actually looking to good to want to drive now.
svndayNZ is offline   Reply With Quote
Old 09-09-2014, 10:01 AM   #4509
How do measure if the left shocks are harder than the right, measure the ride height of the left and right side at the middle of the chassis? Adjust till equal
Marc
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 09-09-2014, 12:42 PM   #4510
John.C's Avatar
Trader Rating: 36 (100%+)
Marc
You adjust and set equal preload by:
1) building all 4 or pairs (front & rear) of shocks to equal length.
2) turn the shock adjuster nut equal amount of turns to ensure that both shocks (L+R) have equal preload. The way my shocks are built it's generally 2 1/4 turns for Pinks in front and 2 1/2 turns for Blues in rear.
Ride height is generally measured at the 4 corners of the chassis. If there is a difference L to R on either the front and/or rear, then you'll want to check on the following.
1) chassis tweak
2) distribution of weight on the chassis
3) shock towers/bulk heads tweak
4) setup board flatness
5) springs
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 09-09-2014, 09:12 PM   #4511
Thanks John.c
Old 09-12-2014, 06:12 AM   #4512
dawgmeat's Avatar
What spare parts are needed for the BD7 2014 Black edition?
dawgmeat is offline   Reply With Quote
Old 09-12-2014, 06:20 AM   #4513
stiltskin's Avatar
Trader Rating: 102 (100%+)
My son hasn't had any issues with his bit I've heard the steering blocks and hubs are fragile on carpet where they meet the boards more often. Haha. Shaving the axles will probably help with that.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-12-2014, 06:38 AM   #4514
dawgmeat's Avatar
Thanks Tony
I notice that BD7's rear A-arm come in different lengths 39.5, 40 etc., which one come with the black edition, also is the kit castor block 2', 4' or 6'?
Old 09-12-2014, 06:54 AM   #4515
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Rear arms are same length, only shock location is different with option hole location
Kit is 4* caster
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
