Old 09-03-2014, 05:51 PM   #4486
antivert's Avatar
Originally Posted by stro3579 View Post
Time for some alum chassis and short shock testing all day.
Not sure how you are balancing the weight of that Orion 7200 (my scales have that battery at 320g). I couldn't get the car to balance correctly. I choose to use the 6000's. Even the Orion 6000 is heavier than most lipos.
antivert is offline   Reply With Quote
Old 09-03-2014, 06:00 PM   #4487
stro3579's Avatar
Trader Rating: 20 (100%+)
I added a 15g weight on the front left side in front of the servo. I also slid the battery as close as I could to the center, versus letting it hang off the right side. My other 7600 packs are alot heavier and I cant get them to balance either. Hope this helps
stro3579 is offline   Reply With Quote
Old 09-03-2014, 08:44 PM   #4488
antivert's Avatar
I also added 15g weight to the left side, 20g yokomo center weight and I would still need around 35g on the left behind the motor to get it some what close. Put your car on digital scales its way off. Hope it works out for you.
LRPAmerica | TKO | RugspinGraphix
Old 09-03-2014, 10:18 PM   #4489
G4ZZ4's Avatar
It all depends if you need more traction
Hi stro3579 how much would you raise it by
cheers Garry
YOKOMO BD7, 21.5 boosted • M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 09-04-2014, 05:51 AM   #4490
stro3579's Avatar
I personally wouldnt. The car already has alot of traction. But just to try it, maybe a .05 mm shim or less
Old 09-04-2014, 05:52 AM   #4491
stro3579's Avatar
The rest of the adjustments will have to be done on shock collars. I don't use scales, just tweak station.
Old 09-04-2014, 09:57 AM   #4492
Thanks for the feedback. I need a bit of traction so will try raising the top deck next weekend.
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 09-04-2014, 10:00 AM   #4493
Hey someone that have a good setup on a very technichal medium grip carpet. I'm looking for a setup thats not is agressive and haves alot of steering. I'm thinking that i just can make 3 degrees toe in rear and a speed body and so ad 0,5-1mm to the inner camber link. What do you guys think?
Yokomo bd7 2014 Black Edition - Muchmore - Sanwa
broløs is offline   Reply With Quote
Old 09-04-2014, 12:54 PM   #4494
G4ZZ4's Avatar
Thanks buddy
cheers Garry
S2H bodies
Old 09-05-2014, 02:17 PM   #4495
evochick's Avatar
Ran a couple of diffs in last light with the new DB-500GOB diff rings,
They built ok and are very smooth, more importantly no leakage
Will monitor over the next couple of weeks to see if they swell
UnRetired
evochick is offline   Reply With Quote
Old 09-06-2014, 04:51 AM   #4496
Bar
Always good to hear peoples feedback, don't think we get that enough on this thread. I have been running the new BD-500GOB o-rings for a while, so far so good
Luke Burr
Bar is offline   Reply With Quote
Old 09-07-2014, 01:47 PM   #4497
Ran the ali chassis and short shocks for the first time.Did not know what to expect as last time ran on carpet was 6 months ago been on tarmac.
Car was really good to say dont get to have practice much onlu on race days,but the shocks and chassis will be staying on.
Car was fastest during practise but think i could of done with a harder tyre(rubber) just to get rid of traction.Raised the lower arms etc reduced toe all helped just harder oil to try next in shocks.
Quietman is offline   Reply With Quote
Old 09-07-2014, 03:56 PM   #4498
I have them in one diff, 3 meets old. They don't leak much but they have started to bind. Only used with xceed oil.
frozenpod is offline   Reply With Quote
Old 09-07-2014, 04:12 PM   #4499
stro3579's Avatar
I have 550 oil in my car. I was thinking of going softer, but will probably stay at 550 since you were thinking of going heavier.
Old 09-07-2014, 07:23 PM   #4500
svndayNZ's Avatar
A quick question, I recently bought my first ever yokomo (after owning Associateds, Tamiyas and Serpents over the years) and can honestly say I'm an official convert and won't be going back.
I built my 14 Black Series on the weekend, and the rear end doesn't seem right, I have the camber links built to the suggested length of 50.5 mm but it fits so snug that the rear drive shafts are pushing heavily into the rear out drives. The rear belt is sitting snug not too loose or tight. The rear arms don't move up and down freely because the out drives and diff are effecting being "pinned" by the drive shafts.
Has anyone else experienced this and if so how is it fixed?
Cheers
svndayNZ is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
