Old 08-18-2014, 11:02 PM   #4426
Where is the leak, outdrives one side or both?
You will probably need a new diff casing.
The diff I have that wasn't fixed with P5 orings only leaked on one side and I have made the diff useable by using CA to build up the oring recess providing a better fit.
It was a pain to do (easy to stuff up) but the diff has been good for 30 plus runs with no leakage.
I don't know how long it will last.
frozenpod is offline   Reply With Quote
Old 08-19-2014, 01:57 AM   #4427
Originally Posted by stro3579 View Post
Having issues with the diff leaking. He car came with the new orings, but still leaking. This is my second time out with the car and I find myself rebuilding the diff every time I race.
Is it leaking from the orings or where the belt runs?
If its the oring you could always try using some yokomo red greace(yes they write it with a 'c' ), green slime or similar.
Regards,
David
niemand is offline   Reply With Quote
Old 08-19-2014, 03:38 AM   #4428
Bar
Which colour are the o-rings you got with the car, the red ones which don't fit and bind the diff up or the new neoprene ones which are black and just a fraction bigger than the original black ones?
Luke Burr
Bar is offline   Reply With Quote
Old 08-19-2014, 04:43 AM   #4429
5tylez's Avatar
I asked Corey whiteman, who is Andrew hardman's mechanic from team yokomo say they use the orange o rings from kyosho and have no leak issues. He also says to not over fill diffs as that also causes leaks.
5tylez is offline   Reply With Quote
Old 08-19-2014, 04:53 AM   #4430
Are those kyosho orings better than the new orange ones?
My orange orings did fine on the first few runs so far but you never know...
If the kyosho orings are actually better in some way, a part number would be greatly appreciated
Regards,
David
Old 08-19-2014, 05:44 AM   #4431
Kyosho P5 Oring, orange in colour.
Kyosho part number ORGO5.
Please note kyosho parts numbers often have KYO on the front of them so some suppliers will list them as KYOORGO5.
Old 08-19-2014, 06:34 AM   #4432
Bar
or you could just use the new ones which are a perfect fit and don't leak BD-500G0B
http://www.teamyokomo.eu/yokomo-euro...ear-Diff-Black
Luke Burr
Old 08-19-2014, 09:12 AM   #4433
stro3579's Avatar
Trader Rating: 20 (100%+)
its leaking out the actually pully part where the belt rides.
stro3579 is offline   Reply With Quote
Old 08-19-2014, 09:20 AM   #4434
John.C's Avatar
Trader Rating: 36 (100%+)
The stock Yokomo o-rings (BD-500G0) that came in my kit was a bit tight. I read on this thread that the Kyosho o-rings (ORG05) were also on the tight side. I opt'd to go with the new Yokomo o-rings (BD-500G0B) which was noticeable more free compared to the stock piece. I haven't run my car yet so I wasn't sure if they would eventually leak. It's good to know that they work.
5tylez - Thanks for sharing the info from Corey. I had the pleasure of watching the man do work in the past couple of big races. The car Corey puts down for Andrew is always dialed! I hope that they can obtain the results that they are seeking at the IFMAR Worlds.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-19-2014, 09:23 AM   #4435
Trader Rating: 22 (100%+)
when the set up sheets have "2 o rings" selected... how is that accomplished? it doesnt seem like 2 would fit in there correctly?
gocoogs is offline   Reply With Quote
Old 08-19-2014, 09:29 AM   #4436
S.Stew's Avatar
I posted this a few pages back, but you'll need the corresponding shaft guide in order to use the double (blue) O-rings.
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 08-19-2014, 05:19 PM   #4437
Bill K's Avatar
my car sofast vroom vroom
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 08-19-2014, 05:20 PM   #4438
John.C's Avatar
Just waiting for my electronics to arrive. Than it's off to my local track for the shake down run.
Old 08-19-2014, 05:31 PM   #4439
Make sure both surfaces are flat, although I haven't had that problem with yok diffs other brands have require the casing to be lightly sanded.
You can use a small amount of sealant where the gasket is as well.
Old 08-19-2014, 07:25 PM   #4440
If the neoprene fit properly they should be fine at first but how long until they swell and go hard?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
derbrylac
SEO by vBSEO 3.5.0
