Old 08-17-2014, 02:06 PM   #4411
Originally Posted by niznai View Post
As for plastic shocks, etc, remember Xray cars come with plastic shocks and nobody thinks they're inferior.
Not anymore, they only came with plastic shocks in the past. But that changed for the T4 platform which features aluminium shockbodies as a standard.
For some the plastic shocks worked, for others not so much. Because of the super fine and also soft thread on the shock body they were a nightmare to build(they also leaked a lot of oil in many cases). IMHO the change to aluminium was much needed.
Originally Posted by ShaunMac View Post
Could someone tell me the approximate length of the front camber link measuring from center of ball-stud to center of ball-stud? In the long and short positions.
@-1,5° camber I measured exactly 47mm in the short position.
I have never seen the inner position in use anywhere but its about 6,6mm further inside...
Hope that helps
Regards,
David
niemand is offline   Reply With Quote
Old 08-17-2014, 02:18 PM   #4412
Originally Posted by stro3579 View Post
Its for High bite carpet tracks. The bd7 2014 has the tendency to traction roll due to it having a lot of mechanical grip. The carbon chassis is very good on asphalt and lower traction carpet. Hope this helps
Picking up on that:
I just bought my first Yokomo and I'm super content on how it works on asphalt.
But I'll attend a big carpet race (ETS Pilot Race at the Nürburgring) in a month.
The race being in September, it'll be near impossible to get some decent carpet testing done beforehand.
Needless to say grip levels will be quite high on the usual ETS carpet and approved methods to get rid of traction roll on this car would be greatly appreciated
( traction roll was NEVER an issue with my xray, getting traction however was from time to time )
Regards,
David
Old 08-17-2014, 02:22 PM   #4413
peter.'s Avatar
forsale
all new option / spare parts in unopened bags for the Yokomo BD 7
price $230,-
BD-414C
B7-413W2
YS-8HD
3xBD-010PW
ZC-206SHS
BD-412RA
BD-011C
B7-64116
BD-501GG
BD-503G
BD-010455
B7-207
YS-53s-T4
2xBD-189L
3xBD-516L
ZC-A3620
BD-008T
BD-008RG1
ZC-206SH
BD-414B
B7-001FS
2xD-046
BD-415RG
BD-008FG
2xBD-01440
BD-413G
B7-415W6
BD-010455
BD-503D
peter. is offline   Reply With Quote
Old 08-17-2014, 03:38 PM   #4414
ShaunMac's Avatar
Hope that helps
Regards,
David
Perfect. Thanks.
ShaunMac is offline   Reply With Quote
Old 08-17-2014, 04:50 PM   #4415
antivert's Avatar
Anyone have a base setup I can go off of for carpet high bite tracks? Just got a BD7 found a few setups off Yokomo's site but they are so different I don't know which direction to start. Any help is greatly appreciated.
P.S. Running 17.5 rubber tire.
antivert is offline   Reply With Quote
Old 08-17-2014, 05:48 PM   #4416
Potoczak's Avatar
Trader Rating: 109 (100%+)
Does anyone know where I can get the pins for the yokomo ecs's. the c-clip ones?? Or another brand that will work with them. Thanks. Yokomo Europe is out of stock. Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-17-2014, 11:43 PM   #4417
I think u can use the pins from tamiya, but also the org. yokos have "big" and small. So it might only fit the "big" side.
Cp Grafix is offline   Reply With Quote
Old 08-18-2014, 02:13 PM   #4418
Potoczak's Avatar
Thought I would share some info, the tamiya ecs's are a direct fit on the bd7.
http://www.tqrcracing.com/shop/produ....asp?p_id=3303
Pete Potoczak
Old 08-18-2014, 02:26 PM   #4419
evochick's Avatar
yes they do fit, but...... the pin that goes into the spool outdrive is too small, you end up wearing out the spool outdrives at an alarming rate, plus the massive amount of slop.
Roche ecs's and spool outdrives for the win !!!!
UnRetired
evochick is offline   Reply With Quote
Old 08-18-2014, 03:34 PM   #4420
Carranza76's Avatar
Here you go:
http://www.petitrc.com/reglages/yoko...YokomoBD7.html
Pegasus Raceway
IERC Raceway
TLR & Tekin are my main squeeze's!
Yokomo BD7
Carranza76 is offline   Reply With Quote
Old 08-18-2014, 08:05 PM   #4421
stro3579's Avatar
Trader Rating: 20 (100%+)
Having issues with the diff leaking. He car came with the new orings, but still leaking. This is my second time out with the car and I find myself rebuilding the diff every time I race.
stro3579 is offline   Reply With Quote
Old 08-18-2014, 08:06 PM   #4422
stro3579's Avatar
Originally Posted by peter. View Post
forsale
price $230,-
BD-414C
B7-413W2
YS-8HD
3xBD-010PW
ZC-206SHS
BD-412RA
BD-011C
B7-64116
BD-501GG
BD-503G
BD-010455
B7-207
YS-53s-T4
2xBD-189L
3xBD-516L
ZC-A3620
BD-008T
BD-008RG1
ZC-206SH
BD-414B
B7-001FS
2xD-046
BD-415RG
BD-008FG
2xBD-01440
BD-413G
B7-415W6
BD-010455
BD-503D
Give use a breakdown of what these parts are.
Old 08-18-2014, 08:34 PM   #4423
Appears to be a common problem with manufacturing tollerances. I have 3 diffs, 2 leak with original black orings and 1 was perfect.
Of the 2 that leaked one doesn't leak with kyosho P5 orings, also the kyosho P5 orings provide less resistance on the shaft so you may need to go up in diff oil to compensate.
frozenpod is offline   Reply With Quote
Old 08-18-2014, 08:38 PM   #4424
Agreed alloy shocks certainly are a step ahead. If you are going to buy the RS there are other brands of alloy shocks you could buy that maybe cheaper and work well.
Old 08-18-2014, 09:38 PM   #4425
stro3579's Avatar
Diff came with the p5 orings.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
