Like Tree6Likes
Old 07-20-2014, 05:22 PM   #4291
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by wstuart View Post
Just picked up a bd7 (non-2014)
It has the 116 tooth spur
Any guess on 13.5 gearing for a large medium to high grip outdoor track - CVRC to be exact
I guess it depends on the motor setup & track size
At Tamiya and Camarillo 4.0-4.5 is about the avg gear
I run a 100t spur 64p with more than enough room for adjustment on the 13' model
Old 07-20-2014, 08:08 PM   #4292
Gridworks Racing's Avatar
Will,
Heritage is only slightly larger than Camarillo and lacks the straightaway of Tamiya.
The motor you are running will come into play, but RedBull's recommendation will probably get you pretty close with a number of motors.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 07-21-2014, 12:10 AM   #4293
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
At Tamiya and Camarillo 35-4.0 is about the avg gear
Originally Posted by Gridworks Racing View Post
Will,
Thanks guys. I'll start with a 4.0 and go from there
Just out of curiosity, was the 14' noticeably better. I was thinking about picking up,a set of those shocks. I bought a used 13' for $220 and I'm thinking about updating/upgrading.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 07-21-2014, 12:12 AM   #4294
JimmyMac's Avatar
Originally Posted by Potoczak View Post
Where is the best place to get the black suspension blocks???
Any HK shop such as RCMarket, RCMushroom, or from Europe such as ToniSport.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-21-2014, 07:38 AM   #4295
Cool
The 13' is an excellent car
More than enough to get the job done
Haven't driven a 14' outdoors don't plan to ether
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-21-2014, 03:32 PM   #4296
Potoczak's Avatar
Trader Rating: 112 (100%+)
Originally Posted by BlackedOutREVO View Post
Yes, you can.
Perfect thanks!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-21-2014, 07:05 PM   #4297
Potoczak's Avatar
Has anyone ordered from yokomo Europe? Just wondering what the ship time is to the U.S.??
Pete Potoczak
Old 07-21-2014, 08:51 PM   #4298
JimmyMac's Avatar
ToniSport... 2 to 3 days from the time they ship. I believe they use DHL.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-22-2014, 02:36 PM   #4299
Hi
I upgraded one of my 2013s to a 2014 and I felt a difference. The car just seemed more responsive and bit more stable.
If I could find a kit I would upgrade the other 2013.
Marc
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 07-22-2014, 07:27 PM   #4300
Potoczak's Avatar
Which ecs's are recommended for the car? (Yokomo, spec r)??
Pete Potoczak
Old 07-22-2014, 08:46 PM   #4301
Professor's Avatar
apart from the original, 3 racing fit & are pretty good, t.o.p. fit and are quite good also both of these are well priced also
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 07-22-2014, 09:04 PM   #4302
evochick's Avatar
The newer Yokomo clip ones or Roche. The Roche are more durable, the yokomo develop a little slop initially but nothing after that, 7 months and still going strong...
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 07-25-2014, 01:48 AM   #4303
skyball's Avatar
Originally Posted by evochick View Post
With the original mount you are a little limited. In 13.5 Blinky I have been running from 3.5 to 3.7 depending on track size. With the 2014 I have just been running 96T spurs as they are easy to get and 51-55 T pinions, but again I am not sure you can run that big without modifying the mount.
...hmm, I think that depends very much on the track and the motor. With 13.5 blinky, we mostly go for a ratio of around 4.5, only on very wide outdoor tracks we go down to 4 or below (but just a little). In any case you should watch your motor temperature before you gear so high...
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 07-25-2014, 07:56 AM   #4304
I recently grabbed a BD7-2014 Black Series. What are the must-have hop-ups for the car that I should buy?
Thanks.
GTi-6 is offline   Reply With Quote
Old 07-25-2014, 08:54 AM   #4305
peter.'s Avatar
Thanks.
B7-TBS (BD-7 Titanium turnbuckle set)
B7-TSSS (Titanium/Steel Screw Set)
BD-010FWC (C-Clip Front Double Joint Universal Shaft Shaft)
B7-203B (Aluminum Special Servo Mount (Black)
peter. is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
