Old 07-18-2014, 09:40 AM   #4276
Bar
Originally Posted by RedBullFiXX View Post
Saw that too
They look the buisness
managed to find a photo, should have mine next week, hope they fit this time
http://www.rcmxstore.com/index.php?m...ducts_id=33380
as well as here
http://hs-misaki.blogspot.co.uk/
Luke Burr
Bar is offline   Reply With Quote
Old 07-19-2014, 08:04 AM   #4277
Potoczak's Avatar
Trader Rating: 107 (100%+)
What extra arm mount are needed to cover me for alot of setups?? What are the most popular ones for the car?? Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-19-2014, 06:26 PM   #4278
JimmyMac's Avatar
If I only had to pick 2 I would go with 4.2 for the front front and 5.7 for the rear rear. The 4.2 will give you 0.5 arm sweep with the stock 3.5 front rear block. The 5.7 in the rear will give you 2.5 rear toe with the stock 2.0 rear front block.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-19-2014, 07:40 PM   #4279
Potoczak's Avatar
Cool thanks.
Pete Potoczak
Old 07-19-2014, 09:27 PM   #4280
stro3579's Avatar
Trader Rating: 20 (100%+)
0.5 arm sweep gives more steering?
stro3579 is offline   Reply With Quote
Old 07-19-2014, 09:40 PM   #4281
JR Race's Avatar
What pitch gearing is the most popular?
I run 48pitch
Is 64 better? If so Why?
Give it the JANDAL!!!
Adelaide RC Team Driver
www.adelaiderc.com.au
JR Race is offline   Reply With Quote
Old 07-19-2014, 10:34 PM   #4282
hanzo3's Avatar
Trader Rating: 55 (100%+)
64 because it gives you more ratio options.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 07-20-2014, 03:26 AM   #4283
JimmyMac's Avatar
I believe you get less steering going in but more mid corner.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 07-20-2014, 07:50 AM   #4284
Potoczak's Avatar
Where is the best place to get the black suspension blocks???
Pete Potoczak
Old 07-20-2014, 02:58 PM   #4285
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Just picked up a bd7 (non-2014)
It has the 116 tooth spur
Any guess on 13.5 gearing for a large medium to high grip outdoor track - CVRC to be exact
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 07-20-2014, 04:12 PM   #4286
evochick's Avatar
With the original mount you are a little limited. In 13.5 Blinky I have been running from 3.5 to 3.7 depending on track size. With the 2014 I have just been running 96T spurs as they are easy to get and 51-55 T pinions, but again I am not sure you can run that big without modifying the mount.
UnRetired
evochick is online now   Reply With Quote
Old 07-20-2014, 04:36 PM   #4287
I run 48pitch
Popular may depend on your location.
48p slightly greater tolerance to gear mesh if you have a crash and the motor moves slightly you will still finish.
64p slightly smoother although not noticeable on track and provides smaller ratio changes.
A lot of racers here were 64p but quite a few have converted back to 48p.
frozenpod is offline   Reply With Quote
Old 07-20-2014, 04:37 PM   #4288
Blinky or boost?
Old 07-20-2014, 04:43 PM   #4289
Potoczak's Avatar
Does anyone know if you can run regular length springs on the short shock conversion??
Pete Potoczak
Old 07-20-2014, 05:17 PM   #4290
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Yes, you can.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
