Like Tree2Likes
Old 07-07-2014, 03:33 PM   #4246
stro3579's Avatar
Trader Rating: 20 (100%+)
I read on hear someone had binding issues on the front spool and rear diff assembly. They mentioned the aluminum cam carriers fixes this. Has anyone else experimented with this?
stro3579 is offline   Reply With Quote
Old 07-07-2014, 04:15 PM   #4247
miller tyme's Avatar
I would not say it was "binding" but it was noticeably smoother with the Al cams, i think it is simply a matter of being able to over tighten the plastic ones causeing them to distort
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 07-07-2014, 04:24 PM   #4248
stro3579's Avatar
Are they sold separately or all 4?
Old 07-07-2014, 07:12 PM   #4249
http://www.amain.com/product_info.ph...djust-Cam-Blue
Ken Miller
Old 07-09-2014, 03:40 PM   #4250
stro3579's Avatar
I notice no one is really running the bridge on the bell cranks. Is everyone shiming the screws on top of the bell crank for play or just running the screws direct?
Old 07-09-2014, 11:04 PM   #4251
JimmyMac's Avatar
With the bridge off, I think... I think I have a .1mm shim under the screw. I'll have to measure it later, but that should give you an idea. It's just enough to take out any play in the rack.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-10-2014, 04:33 AM   #4252
stro3579's Avatar
Is it a standard size shim in diameter?
Old 07-10-2014, 04:52 AM   #4253
JimmyMac's Avatar
Depends what standard is to you. It's from a Tamiya shim set. I believe an axle shim. Thickness is 0.10mm. Outer diameter is 7.30mm. Inner diameter is 5.00~5.03mm.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 07-10-2014, 04:58 AM   #4254
stro3579's Avatar
Thanks, I have to see what I have.
Old 07-10-2014, 04:59 AM   #4255
JimmyMac's Avatar
It fits perfectly over the bearing. Acts kinda like a dust shield.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 07-10-2014, 05:00 AM   #4256
JimmyMac's Avatar
I think this is them...
http://www.rcmart.com/tamiya-53587-%...?cPath=421_520
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 07-10-2014, 05:21 AM   #4257
stro3579's Avatar
Sweet I have some of these thanks
Old 07-10-2014, 11:27 AM   #4258
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by G4ZZ4 View Post
Hi mate what do thay weigh?
103g
And it's dead sexy
Old 07-11-2014, 12:38 PM   #4259
stro3579's Avatar
on some set up sheets for the bd7 2014 it shows that there is a optioin for O rings in the shocks. Is anyone playing around with this? Are they being installed under the piston internally or on the bottom of the shock shaft after assembly for downstops?
Old 07-11-2014, 12:48 PM   #4260
S.Stew's Avatar
I think that refers to whether your using 1 O ring and the thick shaft quide or two O rings and the thin shaft guide. I think most people prefer the double O-ring setup. It a shade smoother and offers better sealing.
You would need:
http://www.amain.com/product_info.ph...r-White-4-Thin
and
http://www.amain.com/product_info.ph...ing-Set-Blue-8
Black bladders are recommended as well!
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
