Old 07-02-2014, 08:56 AM   #4231
cyba888's Avatar
Originally Posted by ronaldo-1234 View Post
Hi, can anyone help me measure the length of this stabilizer stopper?
22mm
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-02-2014, 10:21 AM   #4232
Trader Rating: 16 (100%+)
Originally Posted by cyba888 View Post
22mm
Thanks for your help!
ronaldo-1234 is offline   Reply With Quote
Old 07-03-2014, 02:15 AM   #4233
RC MARKET's Avatar
YOKOMO was release Alum Main Chassis
RC MARKET is offline   Reply With Quote
Old 07-03-2014, 02:38 AM   #4234
Originally Posted by masterhit View Post
Apparently not!
RC Champ says they are in stock! And my drug of choice, Futaba RC Pro Shop.
Mike
I have seen afew different yokomo variants of the alu chassis plate around, i would wait for this one with the recesses and machined edges ....
Smartypants is offline   Reply With Quote
Old 07-03-2014, 03:10 AM   #4235
Jorge T's Avatar
All the packaged chassis pics above show the bottom. The bevel an recess is on the top. Yokomo would not say this on their product description:
" Further more, using black almight on surface, it will go perfectly with BD7 Black Series. This will also create luxurious feeling with bevel edge aluminium processing!! "
I got mine from Banzai.
RSD Speedway
Jorge T is offline   Reply With Quote
Old 07-03-2014, 04:06 AM   #4236
G4ZZ4's Avatar
Hi mate what do thay weigh?
G4ZZ4 is offline   Reply With Quote
Old 07-04-2014, 05:21 PM   #4237
stro3579's Avatar
Trader Rating: 20 (100%+)
Got mine from Banzai also
stro3579 is offline   Reply With Quote
Old 07-04-2014, 05:31 PM   #4238
stro3579's Avatar
Do you guys think the aluminum chassis will be best on high bite carpet or strictly for asphalt.
Old 07-04-2014, 11:41 PM   #4239
Thanks for confirming!
Old 07-05-2014, 02:05 AM   #4240
Du to the stiffness of the alum , I would think the would be mainly for carpet
brokenspirit is offline   Reply With Quote
Old 07-05-2014, 04:34 AM   #4241
kschu's Avatar
Send a message via MSN to kschu
i believe it also suitable for high grip asphalt
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-05-2014, 04:42 AM   #4242
kschu's Avatar
Originally Posted by walzjer View Post
It was a boring sunday and I built the "steering" in my rear. Did anyone have the same and have some experience?
Today is tested it and it felt quite good. In slow corners there is much more traction in the rear and the car rotates better. But in fast corners it is a little bit unstable.
I adjusted a 2° toe angle and when it is deflected it moves to 3°.
Here are some pictures:
https://www.flickr.com/photos/766718...7645035737197/
can you snap the motor mount side where u put the steering linkage ?
thanks
Old 07-05-2014, 09:12 AM   #4243
Jorge T's Avatar
As soon as I get it I will weight it, unless someone gets to before me.
RSD Speedway
Old 07-05-2014, 02:06 PM   #4244
G4ZZ4's Avatar
Thank you
Old 07-06-2014, 05:41 AM   #4245
thanks
At the moment I have the normal rear in my car again to test the difference. But I will take a photo when I switch back next weekend.
At this side it is not so much space between the motor mount at the linkage, but it is enough.
walzjer is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
