Like Tree2Likes
Old 06-14-2014, 03:27 AM   #4156
cyba888's Avatar
anyone notice ETS - Luxembourg setups both Prumper and Volker are running ff44.2 and fr43.5 front suspension block. This angles the front arms outwards are there any benefits to this?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-14-2014, 03:46 AM   #4157
chasingthepack's Avatar
thats arm sweep,improves turn in and on power exit steering
read here http://forum.teamxray.com/viewtopic.php?f=8&t=13756
and here lets talk about arm sweep and its effects
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-14-2014, 07:28 AM   #4158
cyba888's Avatar
Thanks!
Futaba 4PX
Old 06-14-2014, 09:25 AM   #4159
That's pretty standard on bd7 setups tbh.
Smartypants is offline   Reply With Quote
Old 06-14-2014, 09:32 AM   #4160
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is there an hk shop that has the 2014 conversion on the shelf?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 06-14-2014, 07:59 PM   #4161
JimmyMac's Avatar
I looked everywhere for ya, but I cannot find any. I wonder if Malaysia would have any? Check with HobbyHaven.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-15-2014, 12:56 AM   #4162
CraigM's Avatar
Trader Rating: 34 (100%+)
I also think with that setup the 1.5mm under the camber links is with the lowered ball studs, so that would be the same as kit with no spacers
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-15-2014, 12:37 PM   #4163
Bar
Luke Burr
Bar is offline   Reply With Quote
Old 06-15-2014, 01:18 PM   #4164
Bar
Luke Burr
Old 06-15-2014, 01:20 PM   #4165
Bar
I'm not sure, I think the short ball studs are 2mm lower, his starting setup for Luxemberg says 0, so I guess that would be 2mm lower, at least I think so
Luke Burr
Old 06-15-2014, 03:24 PM   #4166
1.5mm, which setup are you looking at?
I see 1.0mm on the outer camber link only and the pics indicate lower ball studs on the inner camber link.
frozenpod is offline   Reply With Quote
Old 06-15-2014, 03:39 PM   #4167
CraigM's Avatar
Pretty sure they are 1.5 lower, I'll check tonight. I doubt they'd ever run no spacers under the lowered studs, that would put the links on a huge angle
Yokomo FB
Old 06-15-2014, 03:53 PM   #4168
Thanks.
Out of interest what roll centers do people normal use with the BD7 14.
I have found with matched shims front and rear the rear rolls around alot more than the front leading to traction roll.
ATM the best setup I have found to prevent traction rolling is 1mm shims on the upper rear outer links with no shims on the front links. Car feels good, balanced and stable but is slow.
Old 06-16-2014, 05:26 AM   #4169
Bar
Yokomo FB
Just had a look the standard inner and outer ones are the same length. The shorter ones on the rear roll bar links are 1.4mm shorter
Luke Burr
Old 06-16-2014, 01:29 PM   #4170
Carranza76's Avatar
Looking for a good gearing suggestions for 17.5
Running the following:
Tekin Gen2
Reedy 17.5 first Gen motor
Right now I am geared 116/38
I am new to on road so is there a FDR I should stick to with this car? any help would be greatly appreciated.
Pegasus Raceway
IERC Raceway
TLR & Tekin are my main squeeze's!
Yokomo BD7
Carranza76 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
