Like Tree6Likes
Old 06-08-2014, 01:52 AM   #4141
Geberit's Avatar
Originally Posted by Bar View Post
I cracked a hex recently by over tightening one, I know a few others who have also done this, you do have to be a little careful with them
Happened to me also
Geberit is offline   Reply With Quote
Old 06-08-2014, 05:47 AM   #4142
Bill K's Avatar
Hey guys, going a bit off topic here but was after some advice.
Managed to iron out the 'floating rear end' I was experiencing before, but having some slight oversteer on/off power coming out and going into some of the corners. After doing some reading and receiving some local advice, going gear diff in the front should take load off the front tires and bearings and also eliminate some rear rotation out of the corner.
After thinking about this, if running modified I can imagine the plastic 'C' clips around the shaft would wear quite easily, and removing them completely is not an option.
Would the 1-way HD out drives fit the front gear diff, as from pictures I can see that the shaft end would fit alot tighter in there compared to that of the stock out drives. If not, is there anything you guys do differently when running gear diff in the front?
Cheers,
Bill
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 06-08-2014, 12:08 PM   #4143
SLOW 77's Avatar
Trader Rating: 27 (100%+)
When running a gear diff up front use these.
BD-501GS
Made for no blades, just like the spool.
John Hodges
Yokomo BD8 - KOPropo EX-RR -Xray NT1 -Mooreway Motorsports
SLOW 77 is offline   Reply With Quote
Old 06-08-2014, 01:30 PM   #4144
Interesting reading about the corner weights for the BD7, I have been wondering about these myself. I a wonder whether this is just more on the high grip surfaces that they are racing on though. I have thought about getting the front bd7 corner weights to try, it adds a lot of weight to the car though, they are quite expensive as well. I am wondering if anyone has had any success using them on lower grip tarmac tracks?
Just stick 30g of lead in the front and try it, rather than using the yokomo weights? Would be interesting in knowing your thoughts.
Smartypants is offline   Reply With Quote
Old 06-08-2014, 04:09 PM   #4145
Bar
yes I will do, I can't use the yokomo ones on the right side anyway because of my battery guides(super light weight ones from guy on here). Me and a few others will be trying it this week, I will report back
Luke Burr
Bar is offline   Reply With Quote
Old 06-08-2014, 04:31 PM   #4146
Hi Bill k
I got rid of my floating back end by raising the inner ball, adding shims to give the rear end some pro squat, changed to an Ltcr body and stopped running sorex. Guess it all depends on your set up but maybe one of those helps.
I have run gear diffs since I got my two bd7's to get more turn in, surprised to hear it could settle the rear. I have only used the plastic inserts with the standard drive shafts and no issues.
Marc
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 06-08-2014, 06:29 PM   #4147
Head light and vent looks different.
nepiman is offline   Reply With Quote
Old 06-08-2014, 06:30 PM   #4148
Originally Posted by cyclonetog View Post
What do you think is different about it? Looks standard to me...
Head light looks different.
Old 06-09-2014, 12:26 AM   #4149
Bill K's Avatar
Thanks SLOW, I'll make an order and purchase a couple of those.
Also Marc, I've found that by raising all 4 outer camber links it helped to settle the rear end using RIDE reds. I'll do some experimenting and change the rear only, just to see how the car reacts. Might be for the better
Thanks.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Old 06-09-2014, 03:51 AM   #4150
cyba888's Avatar
maybe because the lights are all custom painted different design?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-09-2014, 09:27 AM   #4151
EricPF's Avatar
Hey Nepiman,
Ronald runs the same LTC-R as is available to everyone else (#1505-25 lightweight), usually mounted 2-3mm forward. I think the differences you're seeing are the custom headlights/grilles that his painter paints in instead of using the regular decals.
Eric Epp
PROTOform // racepf.com
EricPF is offline   Reply With Quote
Old 06-09-2014, 12:53 PM   #4152
When using the high traction top deck on the 2014 do you leave the back screw out on the new car as it does not line up with the motor.
Just making sure?
Quietman is offline   Reply With Quote
Old 06-09-2014, 01:33 PM   #4153
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Just making sure?
imo
You would be better off using a 2013 motor mount to do that
Even the 13 isn't normally happy without that back screw
But I guess it's worth a try first
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-10-2014, 09:06 AM   #4154
Originally Posted by EricPF View Post
Hey Nepiman,
got it! Thanks!
Old 06-11-2014, 04:14 AM   #4155
fatchickterian's Avatar
Default battery guide BD7
Sorry for spam,
black battery stop for BD7 is back in stock
Battery Guide for Yokomo BD7 2013/14
fatchickterian is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
